Advertise on Bikeforums.net
Results 1 to 4 of 4
  1. #1
    Join Date
    Apr 2005
    Posts
    15
    Excessive bottom bracket friction
    I just had a bike put together for me by a friend of mine who lives a couple hours away. Its a vintage frame that's been converted into a single speeder. I have a brand new Phil Wood bottom bracket in it, and when I ride at low speeds its incredibly smooth, like I'm riding on a cloud. When I start pedalling faster, however, I definately feel some friction coming from the bottom bracket, like its vibrating slightly. It only happens while I'm pedalling. Sometimes I think I can hear it, althougth its mostly a sensation that I feel. Its very slight, but I spent a lot of money on this bike and I feel that it should be perfect. As far as I know, the chainline is perfectly straight. Does anyone know what could possibly be causing the bottom bracket to vibrate, or what could be causing unneccesary friction? Thanks.
  2. #2
    Join Date
    Apr 2005
    Posts
    15
    Obviously, this thread was intended for the "bicycle mechanics" forum, sorry for the mix-up..
  3. #3
    Licensed Bike Geek Davet's Avatar
    Join Date
    Oct 2002
    Location
    Spokane, Washington. Bicyclist's heaven!
    Posts
    904
    Quote Originally Posted by maverick_21
    If the cups of the Phil Wood bottom bracket are over-tightened, they will feel gritty, or feel like it is turning hard(er).
  4. #4
    Join Date
    Apr 2005
    Posts
    15
    Since I don't have a Phil Wood tool, I took the bike to a few bike shops hoping that they would have one. I explained the situation and suggested that maybe the cups were overtightened. Two shops said that with a sealed cartridge that is impossible, although they also admitted little to no expirience with a Phil Wood, so I don't completely trust them. I then took the bike to Urbane in Toronto, and they don't think its the BB at all, rather they just think I need some grease in the crank bolts and chainrings, or something to that degree. Hopefully that will help, if not, perhaps I should order a new Phil tool and try to re-adjust the cups myself. Thanks for the advice.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
