Advertise on Bikeforums.net
Results 1 to 5 of 5
  1. #1
    Senior Member claude's Avatar
    Join Date
    Oct 2000
    Location
    Malta, Europe
    Posts
    59
    hi..... after two weeks or so of having arranged my brake sqeal (Avid Arch Rival 5's gripping on MavicX512's) i've got this misterious thud on every revolution of the rear wheel. It does not happen unless I brake hard on a downhill at around 30KM or over, so I cannot locate the exact position where the thud is. I examined the rim thoroughly - no defects - I cleaned it but still.
    any ideas anyone ??
    cheers
    claude
  2. #2
    Moderator
    Join Date
    Apr 2000
    Posts
    531
    If it hapens once every time it rotates then most likely on the seam. It may be off by a little. Sadly see this often. Mavic rims are not the best things out there as many may think. Check the seam out for that.
    Is the wheel out of true?
    - www.bullteksports.com
  3. #3
    Join Date
    Mar 2000
    Location
    Southwestern Ohio
    Posts
    22
    I had a similar problem back in '95 when I had gotten a pair of the Mavic 217s on my new kona kula. The shop called mavic and they replaced the rims after receiving my old ones. My LBS ate the expense of rebuilding my wheels. It wasn't their fault. I think Kona should have caught the problem before they shipped the damaged rims out. They refused to help with the process at all.
  4. #4
    Sumanitu taka owaci LittleBigMan's Avatar
    Join Date
    Mar 2001
    Posts
    9,000
    Me too, Claude. Live and learn, I guess. Still (anybody correct me if I am wrong about this), it doesn't seem to really hurt me all that much, except that it is annoying.
    Then again, if it's a dangerous scenario, someone alert me!
  5. #5
    Senior Member pat5319's Avatar
    Join Date
    Sep 2000
    Location
    Spokane WA
    Posts
    1,126
    Find a good mechanic to look at your wheel, if the seam is misaligned the rim can be "bent" into "shape". I've done it before myself.
    Pat5319
Posting Permissions
  • You may not post replies
  • You may not edit your posts
