Carbon Handlebars for Cross
human
Bikes: 2005 Litespeed Teramo, 2000 Marinoni Leggero, 2001 Kona Major Jake (with Campy Centaur), 1997 Specialized S-Works M2, 1992 Specialized Rockhopper
Considering the amount of abuse a 'cross bike typically sustains, I don't think it'd be a particularly good idea... especially since I'm not sure I see a heck of a lot of benefit there, except maybe in a marginal weight saving. And if you're a tech-worshipping weight weenie, 'cross probably isn't your sport...
when walking, just walk. when sitting, just sit. when riding, just ride. above all, don't wobble.
The Irregular Cycling Club of Montreal
Cycling irregularly since 2002
easton carbon bars work great and it's a good idea for a cross bike- never thought about it until now. I know a couple guys that have them on the road bikes and say good things. They certainly are comfortable.
I have a carbon bar on my xc bike and love it. The Monkey lite riser carbon is really popular too.
That might be a good idea! I think 3T or someone just came out with a full carbon road bar too.
oh yeah, I've seen alot of alloy bars snap- doesn't mean I won't buy one. Never seen a carbon bar snap but have heard of all kinds of bars breaking.
DEADBEEF
From: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
human
My concern wouldn't be snapping, necessarily. But I've seen carbon bars become compromised to the point of unusability by having the surface coat scuffed and the beginnings of delamination. I'm not sure exactly what the advantage would be of a carbon bar -- the weight saving would be unnoticeable in cross and the vibration damping? I'm just not convinced it's worth the pricetag. But, hey, it's your money.
The only thing you have to worry about with carbon is not to score the surface- as in starting a stress cut where cracking may begin.
Scuffs and dings on the surface can be sanded or ignored. You only need worry about deeper damage or scoring (as you would with a lightweight alloy bar).
Carbon bars don't "de-laminate". I have seen carbon forks, steerer tubes, cranks, frames, seatposts and wheels take alot of abuse just fine. I don't see how even the superficial "aesthetic" layer of carbon weave could de-laminate. The ends of the bar are the weak point but that's what plugs are for. I don't like these old wives tales. Everything can break. So what.
Not only is the Easton light but try to compare the fatigue life, impact strength or stiffness to alloy. Not to mention the infinite "tuneability" carbon tubes have.
Weight (surprise!) does matter for cross. Unless you like carrying as much weight as possible for barriers and run-ups. Why do you think so many pros ride Antares, Zipp or Cane Creek deep V carbon wheels? Weight, mud shedding, acceleration? Yes to all the above. Full carbon forks are coming in now too. Why? Because they are frickin light and strong!
Easton carbon bars last at least 3 times longer than a comparable 180g alloy bar or even a 250g alloy bar.
Carbon bar for cross is a great idea. I think when the time comes, I'll try it. Thanks Alan!
human
Carbon bars don't "de-laminate...
Good to know.
Carbon definitely delaminates. I only know this for a fact because I recently read an article about the Airbus that crashed in New York. It's entire tail is composed of Carbon Fiber, the fear is that a bubble formed during the lamination process, it was missed, and the tail detached in flight. There is now a push to use ultrasound to check composite parts for potential points of failure. The military, apparently, has been doing this for years. Dr. Anthony J. Vizzini, an expert on " ... delamination and compressive response, fracture and failure of composite structures,smart structures." was quoted in the article so, out of curiousity, I sent him an e-mail asking his opinion on carbon fiber bicycle components. If he chooses to respond I'll post it.
Jeff
Jeff
Well, he responded quite quickly.
So, you are right about scratches and nicks racerx.
Return-Path:
<vizzini@eng.umd.edu>
Received:
from steinberg.umd.edu
Surface nicks and scratches have little effect on the overall performance. There is generally a resin rich zone near the surface anyway. However, after sufficient aging, there may be a problem. Thus composite components should probably be retired at regular intervals.
Received:
Jeff
Jeff
It's the fight in the man
Bikes: Pace RC200 F2 (British Built!)
I currently run a carbon bar on my MTB, and don't think I'd worry too much about having one on a cross bike.
Could be a comfy option too, but to fork out that kinda money you'd either have to be some kinda bike candy nut nut, or have a bank balance as healthy as Lance Armstrongs media machine!
As to de-lamination, hopefully you'd be the sort of person that would inspect their bike after races to check such things...again, I haven't come across this happening...not to say that it doesn't
Cheers
Rich
Cheers
Rich
Making New Zealand a safer place :)
Jeff
Jeff
Originally posted by Rotifer
The reason he recommends that you retire the components at regular intervals (as do most manufacturers) is that problems (delamination) occur where you can't see them. Thus, the use of ultrasound when inspecting composite aircraft.
Rich
Personally, I think quality carbon fiber parts are beautiful ... right up their with Merlin titanium.
