Advertise on Bikeforums.net
Results 1 to 11 of 11
Thread: Tange Prestige?
  1. #1
    Join Date
    Aug 2005
    Posts
    1,153
    Tange Prestige?
    Any opinions on this tubeset?
    It seems like a good deal, at $88 for a full set at Nova, way cheaper than columbus or deddacia (sp?). Another benefit is the availability of round tange fork tubes (can you tell I lust after a custom fixed?).
    I've heard that these tubes are flexy, but I only weigh about 140 lbs, so it might work in my favor.
    While we're at it, Long Shen arrowpoint lugs, nagasawa track ends, glossy black with orange pinstriping. Uhh
  2. #2
    Senior Member Nessism's Avatar
    Join Date
    Jun 2004
    Location
    Torrance, CA
    Posts
    2,303
    "Prestige" denoted a heat treatment process Tange used. These tubesets came in a varity of thicknesses and diameters so you need to do your homework to determine what the exact specs are and then you can go from there. Good stuff by the way if the specs suite your needs.
    From my experience, Nova is expensive. You can do better price wise from Joe Bringheli - he imports Dedacciai tubing. Also, check out Henry James and take a look at True Temper prices. Verses HT is similar to Prestige to give you some idea where you are.
    http://www.henryjames.com/home.html
    http://bringheli.com/
    Becareful buying/selling bike parts on-line. I learned the hard way. :(
    Good/Bad Trader Listing
  3. #3
    Senior Member bellweatherman's Avatar
    Join Date
    Aug 2005
    Location
    Austin
    Posts
    2,082
    Quote Originally Posted by moki
    HAHA! You call THAT flexy?! Please! Prestige? Man! Have you seen the new stuff out there today? All the steel manufacturers have tubesets that are razor thin! Literally .5mm on the butted sections!
  4. #4
    Join Date
    Jun 2004
    Location
    Torrance, CA
    Posts
    2,303
    Quote Originally Posted by bellweatherman
    A tubeset like True Temper S3 (with .5mm butted ends and a 38mm down tube) will build into a stiffer frame than one with thicker but small diameter tubes. By increasing the diameter of the tubes the stiffness go up significantly.
  5. #5
    Join Date
    Aug 2005
    Posts
    1,153
    This is the tubeset I was thinking of:
    prestige OS
  6. #6
    Join Date
    Jun 2004
    Location
    Torrance, CA
    Posts
    2,303
    prestige OS
    That Prestige tubeset would build into a nice frame. You are not going to have much in the way of lug and bottom bracket choices though considering the uncommon tube sizes so keep that in mind.
    Good luck.
  7. #7
    Senior Member zonatandem's Avatar
    Join Date
    Dec 2003
    Location
    Tucson, AZ
    Posts
    9,382
    Tange Prestige? Great tubing! Perhaps a bit of 'old school' compared to what's available now.
    Had Co-Motion build us a full custom tandem in 1993 with Tange Prestige tubing. Put 58,000 miles on that tandem before we sold it. Got a custom carbon fiber ariZona tandem now. Nice!
  8. #8
    Senior Member smurfy's Avatar
    Join Date
    Jun 2003
    Location
    Cincinnati, Ohio
    Posts
    1,126
    Speaking of Prestige, I got a question about my two Bianchi frames...
    My '87 Eros and '90 Axis both are Japanese built and have Bianchi "Superset II" tubing. I was told that this was actually Tange Prestige that was relabeled or it was Bianchi's version of Prestige. Does anybody know which is correct?
    "You handle it like you handle a bicycle" - Jacques Rosay, Airbus A380 test pilot
  9. #9
    barnfullagts
    Join Date
    Oct 2005
    Location
    WI
    Posts
    611
    Have a Tange Prestige road bike and had three Prestige mountain bikes in the past before Ti. Great tube set and you can find their more complete product listing at:
    http://www.tange-design.com/tange_2005/index.htm
  10. #10
    BIKE MECHANIC king koeller's Avatar
    Join Date
    Jun 2005
    Location
    Dayton, Ohio
    Posts
    187
    Tange Prestige was some of the finest tubing ever offered on the early first generation mountain bikes
    in fully lugged, brazed, and then later tig welded.
    Strong, Responsive, Tange Prestige was, if I'm not mistaken, Japan's version of Reynolds 531 tubing.
    I have 2 centurions, Super Lemans, 1976 and an Elite, 1984 ,the later with Tange Prestige, both lugged, and this frame set rocks! Back in the pre-carbon days!
    On my 1986 Tange equiped Focus ,the quality is evident ,both by the workmanship
    and the silky smooth ride! Long live Tange!
    Here in Japan pronounced tan (rhymes with john),and ga (rhymes with duh)...John-duh...tan-ga!
    So many tubing makers and so little time!
    Go for it!
    1976 Centurion Super Lemans 23"C-T Double butted chrome-moly Nervex style lugs Campy NR Wright Leather fiamme red label tubular rims Metallic silver, 1984-BCA 21.5"c-t Tange double butted lugged Shimano bio-pace Leather Brooks B-17 Champion Standard honey Black w Red head tube Lugged frame, 1986 FOCUS 22"c-t Tange double butted lugged Suntour XC Sport Sugino VP triple Dia-Compe Canti's Brooks B-17 Champion Standard, Trek Elance 400D 1986 Reynolds 531 Full Shimano SIS Black metallic silver
  11. #11
    More Energy than Sense aroundoz's Avatar
    Join Date
    Aug 2005
    Location
    155 miles north of Spokane
    Posts
    710
    I am going to buy a cross bike. Currently they use Reynolds 631 and are in the process of chaning to Tange Prestige. Should I wait for the Tange or buy the bike w/ Reynolds or will even notice the difference. I need a strong bike because I am 225 and tour.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
