Advertise on Bikeforums.net
Results 1 to 16 of 16
  1. #1
    A1A cyclist
    Join Date
    Oct 2004
    Location
    Ft. Lauderdale
    My Bikes
    Schwinn, American Bicycle Company, Jamis, Huffy
    Posts
    255
    Rear Wheel on a Recumbent ( Pick One )
    A) 26 x 1-3/8" or
    B) 26 x 2.125"
  2. #2
    Recumbent Evangelist
    Join Date
    Mar 2005
    Location
    Kitchener, Ontario
    My Bikes
    Rebel Cycles Trike, Trek 7500FX
    Posts
    2,991
    How many places did you post this question??
    www.rebel-cycles.com
    The official Canadian dealer of TW-Bents recumbent bicycles!
  3. #3
    Banned. N_C's Avatar
    Join Date
    Oct 2002
    Location
    Bannation, forever.
    Posts
    2,932
    Are you asking what we have? Or asking what we would choose? If you are you may want to consider making this into a poll.
    BTW, I run a 26" x .875" on mine. And a 20" x 1.35" on the front. I wish I could find a narrower tire for the front in the Primo brand. I have tried other brands, but do not like the way they feel, handle the road surface. Or I have had to much bad luck with premature wear & side wall blow outs. With the Primo's I have never had a problem with any of this. They are a very good tire as far as I am concerned.
  4. #4
    Senior Member BlazingPedals's Avatar
    Join Date
    Dec 2004
    Location
    central Michigan
    My Bikes
    Trek 7500, RANS V-Rex, Optima Baron, Velokraft NoCom, M-5 Carbon Highracer, homebuilt recumbent
    Posts
    6,234
    I don't know anybody who has a 2.125" tire on the back of their recumbent. Of more than 100 bents in my club, the majority use 28mm or less, with a significant minority using up to 1.5" and a handful using 1.75". I have a 25mm on my go-fast wheels and a 32 on my training wheels.
  5. #5
    Take Your Lane MaxBender's Avatar
    Join Date
    Sep 2005
    Location
    Atlanta, GA
    Posts
    292
    BlazingPedals, what kind of bent is your primary ride?
    just a sig test !
  6. #6
    A1A cyclist
    Join Date
    Oct 2004
    Location
    Ft. Lauderdale
    My Bikes
    Posts
    255
    A Labent by Ladue just got finished powder coating after the frame was built to my specs. 225lbs here. He did a fantastic job on it. I can't wait.
    All flat terrain in South FL. 100% asphalt riding. And I'm trying to get ready for it.
    I had no idea that these wheels had diff. diam. rim. So I just learned that the 26 is the total overal diam. I thought it was the diam. of the rim. Boy learn something every day. The brakes I guess will determine which rim I use.
  7. #7
    Join Date
    Dec 2004
    Location
    central Michigan
    My Bikes
    Posts
    6,234
    Quote Originally Posted by MaxBender
    My primary ride is an Optima Baron. Go-fast wheels are Velocity Thracians, the training wheels are Vuelta Airline rims built on Shimano XT disc-compatible hubs.
  8. #8
    Slow But Handsome Mild Al's Avatar
    Join Date
    Nov 2005
    Location
    North Carolina
    My Bikes
    Old steel Roadmaster
    Posts
    141
    Quote Originally Posted by World Tour
    As a newbie, I often find tire sizes confusing. The best resource I've found is Sheldon Brown's article on tire sizes:
    http://www.sheldonbrown.com/tire-sizing.html
  9. #9
    A1A cyclist
    Join Date
    Oct 2004
    Location
    Ft. Lauderdale
    My Bikes
    Posts
    255
    Thanks, that's a good reference. I think I'm more confused now though.
    We'll see where the brakes are. That'll pertty much decide it. I think he said he's using a mtb rear triangle, so that'll probably mean the wider rim.
  10. #10
    Join Date
    Nov 2005
    Location
    North Carolina
    My Bikes
    Posts
    141
    Even among MTB's, there's a lot of variation in tire width. My son's MTB has 26 x 2.125 tires; my MTB has 26 x 1.75. The rims are the same diameter, 559mm (measured from bead to bead, not outside edge to outside edge), so they should accept similar brakes. I'm still new at this, but as far as I can tell, you can get 559 tires in much narrower widths (down to 1" or less). These should work with the MTB rear triangle and brakes. So, my guess is that you can run whatever width you want, more or less, as long as you stick to the 559 rims and tires (26-inch with the width expressed as a decimal, e.g., 26 x 1.25, 26 x 1.5, 26 x 1.95, etc.)
  11. #11
    Join Date
    Dec 2004
    Location
    central Michigan
    My Bikes
    Posts
    6,234
    Quote Originally Posted by Mild Al
    ...my guess is that you can run whatever width you want, more or less, as long as you stick to the 559 rims and tires (26-inch with the width expressed as a decimal, e.g., 26 x 1.25, 26 x 1.5, 26 x 1.95, etc.)
    ...so long as the tire will physically fit in the frame. If World Tour's bent uses a MTB rear triangle, I would expect it to handle at least 1.95 wide tires, as long as the rim can handle it - you don't want to mismatch the width of the rim and tire.
  12. #12
    Join Date
    Nov 2005
    Location
    North Carolina
    My Bikes
    Posts
    141
    Quote Originally Posted by BlazingPedals
    ... as long as the rim can handle it - you don't want to mismatch the width of the rim and tire.
    I've never tried changing tire sizes on a given set of rims. How much leeway do you have, roughly? Obviously, you can't replace 26 x 2.125's with 26 x 1.0's--but how much can you you up or down in tire size?
  13. #13
    Join Date
    Dec 2004
    Location
    central Michigan
    My Bikes
    Posts
    6,234
    As with most cycling subjects, Sheldon Brown has a page on mixing tires and rims. It's at http://sheldonbrown.com/tire-sizing.html
    Here's what he says about tire widths:
    Quote Originally Posted by Sheldon Brown
    A general guideline is that the tire width should be between 1.45/2.0 x the inner rim width.
    If you flatten out a tire and measure the total width from bead to bead, it should be approximately 2.5 x the ISO width.
    If your tire is too narrow for the rim there's an increased risk of tire/rim damage from road hazards.
    If its too wide for the rim, there's an increase risk of sidewall wear, and a greater risk of loss of control in the event of a sudden flat.
    Near the bottom of the page is a chart showing his guidelines of what width tires to use with what width of rim.
  14. #14
    Join Date
    Nov 2005
    Location
    North Carolina
    My Bikes
    Posts
    141
    Somehow I missed that chart. That's what I get for skimming.
  15. #15
    A1A cyclist
    Join Date
    Oct 2004
    Location
    Ft. Lauderdale
    My Bikes
    Posts
    255
    You guys have been great in helping me understand and learn about this stuff. I had no idea.
    Well, I put a 26x2.0 on a 559 rim to use on the rear of the bent. Listen to me, a week ago, I didn't know what 559 meant. hehehe.
    Thanks.
    ps, Denny Ladue (Labent by Ladue) is a master craftsman. My frame is awesome.
  16. #16
    Join Date
    Nov 2005
    Location
    North Carolina
    My Bikes
    Posts
    141
    Enjoy! And let us know how it goes!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
