Advertise on Bikeforums.net
Results 1 to 4 of 4
  1. #1
    Senior Member Cadillac's Avatar
    Join Date
    Jan 2003
    Location
    Chilliwack, BC
    My Bikes
    Trek 2000, Catrike, Gitane tandem, no-name mountain bike
    Posts
    224
    Scheuermann's neck
    One of the problems I have seen, particularly after long riding is a sore neck as a result of having to bend your head (esp. when you are in the drops).
    As a result, the neck is "kinked" usually to one side.
    Some call it Scheuermann's neck (also "Shermann's neck).
    It is apparently temporary although it may be a form of "Scheuermann's disease" or "Scheuermann's kyphosis."
    Have you ever suffered from it? If so, what did you do to correct it?
    "Weary with toil, I haste me to my bed,
    The dear repose for limbs with travel tired;
    But then begins a journey in my head,
    To work my mind, when body's work's expired"
    -- Shakespeare Sonnet XXVII
    Click here to visit Motorera.com
  2. #2
    Senior Member Richard Cranium's Avatar
    Join Date
    Jun 2002
    Location
    Deep in the Shawnee Forest
    My Bikes
    LeMond - Gunnar
    Posts
    2,747
    As usual right on top of things --- you and M.........so much riding, aw nevermind.....
    http://www.ultracycling.com/training/neck_pain.html
  3. #3
    Join Date
    Nov 2004
    Posts
    372
    Quote Originally Posted by Cadillac
    I bought a recumbent. Ok, ok, I will stop now.
  4. #4
    Long Distance Cyclist Machka's Avatar
    Join Date
    Jan 2003
    Location
    The Beautiful State of Victoria
    My Bikes
    Lots
    Posts
    33,882
    First of all, the serious neck problem is called Shermer's Neck after Michael Shermer's affliction on the 1983 RAAM, as seen in the link RC posted.
    As for alleviating neck problems though, there are a number of things a person can do:
    1) Do NOT wear a heavy helmet light. I used a rather heavy one on the PBP, and ditched it at the first control because I had already begun to develop some neck pain by then. Shortly after removing it, my neck felt fine again.
    2) Stretch. Look up and down and from side to side frequently throughout the ride. Sit up and stretch, move your arms around and behind you etc. I try to do this as frequently as possible as I ride and when I remember, my whole upper body feels much better. Don't forget to stretch when you get off the bicycle as well.
    3) Develop upper body strength through weightlifting or working at a job where you essentially do a form of weightlifting. You might also consider doing yoga or pilates throughout the year.
    4) Raise your handlebars. If your handlebars are too low, you'll end up craning your neck too much to see.
    5) Don't wear a visor on your helmet. I've tried to wear those visors and while they are great for blocking the sun and helping to stop me from squinting, I find I have to crane my neck too much to see properly and I end up with neck pain.
    6) Keep glasses on bridge of nose so you are not looking over or under the frame.
    7) If you sleep on a long randonnee, use your helmet, camelbak, handlebar bag, rolled up sweatshirt, inflatable pillow, or something that works for you to keep your spine straight and head comfortable.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
