Advertise on Bikeforums.net
Results 1 to 21 of 21
  1. #1
    Don't Believe the Hype RiPHRaPH's Avatar
    Join Date
    Feb 2002
    Location
    chicagoland area
    Posts
    2,568
    do people build up Ti bikes as singlespeeds
    i've always wanted to build up a good bike. i don't have the $$$ to upgrade everything at once, so i wanted to get a decent frameset and place a single speed on it and build up from there at my leisure (who knows - maybe i'd want to keep it that way)
    can you put any tooth cog on the back? a 15 for example?
    this may be an obvious question but i really don't know.
    I have enough words to get me into trouble, but not enough to get me out of trouble.
  2. #2
    Senior Member BikerRyan's Avatar
    Join Date
    Dec 2002
    Posts
    306
    Sounds like a fine idea to me. If you already have some parts laying around then the easiest way to make a singlespeed is to use a standard rear wheel and using a gear from an old cassette and some spacers place the gear in the place where it makes the best chainline towards your crank on the freehub body. Then remove any extra rings on the crank and use shorter chainring bolts to tighten down the remaining ring. Be sure that the chainline is straight from the front chainring to the rear cog, if it isn't then readjust the two as necessary, move the rear cog over a spacer or two. Then use an old rear derailleur and set the limit screws so that the derailleur hangs directly underneath the rear cog. Then thread the chain through as normal and you have a singlespeed. You will want to keep it this way, trust me.
    -Ryan
    Your bike mechanic is wise beyond your wildest dreams.
    If you can't be good at one sport then you can be okay at three.
  3. #3
    Join Date
    Feb 2002
    Location
    chicagoland area
    Posts
    2,568
    can you set your own chain lengths based on what front and rear cog you use?
    which spacers are compatable?
  4. #4
    Senior Member danr's Avatar
    Join Date
    Jul 2002
    Location
    Midwest USA
    Posts
    690
    Here's a Ti SS frame builder
    Matt Chester Ti
    Sp to answer whether people build up Ti bikes as singlespeeds, yes.
    I don't know this person, don't own a frame buy him, nor have I heard any reviews. Just something I found while surfing one day.
    Does the perfect bike really exist?
  5. #5
    Join Date
    Feb 2001
    Location
    England
    Posts
    11,732
    Ti is a vary hard tough metal. Can the rear axle nuts bite into the dropouts sufficiently ?
    Most Ti bikes have vertical dropouts, so axle movement is not a problem, but that is not much help on a SS. Ive never seen a Ti frame with horizontal ones.
  6. #6
    Join Date
    Dec 2002
    Posts
    306
    The chain length will have the slack taken out with the old derailleur you used to tension the chain. But yes you will still need to cut the chain a little to make up for the new gear ratio. Your local bike shop should carry cassette spacers, you will need probably 7 or 8 of them depending on their thickness. Or if you took an old cassette apart (some of them are held together by tiny bolts on the back side) for your rear cog, then use the spacers you salvaged out of it.
    -Ryan
  7. #7
    NCAA - DUAL CHAMPIONS! a2psyklnut's Avatar
    Join Date
    Mar 2000
    Location
    From Sarasota, FL sitting in front of a computer spewing random thoughts!
    Posts
    8,024
    Matt Chester, sweet frames! Not cheap, but beautiful welding and custom geometries!
    L8R
    "Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, What a Ride!" - unknown
    "Your Bike Sucks" - Sky Yaeger
  8. #8
    Join Date
    Dec 2002
    Location
    Wheat Ridge, CO
    Posts
    305
    Yes.
  9. #9
    drev-il, not Dr. Evil! Drevil's Avatar
    Join Date
    Nov 2004
    Location
    UM Maryland
    Posts
    24
    Quote Originally Posted by MichaelW
    ... Ive never seen a Ti frame with horizontal ones.
    It depends on the hub and the type of ti that they use on the dropout. Some ti are harder than others, so some hubs slip on 'em. I have a Chester, and my boys have met the stem once, when I was still running a Phil hub. I threw on a tug to prevent that from happening again. With my Chris Bling, it has never slipped.
    ...Chester, with Paragon horizontal drops:
  10. #10
    cxmagazine dot com pitboss's Avatar
    Join Date
    Jun 2003
    Location
    WI
    Posts
    8,586
    no one does. All these pictures and URLs are fabrication, pure lies. Nothing but steel exists. Nothing...oh, and beer pie.
    Deathlap - cyclocross, training, beer,...escape hatch
  11. #11
    Beausage is Beautiful Fugazi Dave's Avatar
    Join Date
    Oct 2003
    Location
    Chicago, IL
    Posts
    5,736
    Oooooh......beer pie.
  12. #12
    無くなった HereNT's Avatar
    Join Date
    Mar 2004
    Location
    Sci-Fi Wasabi
    Posts
    5,161
    I should be riding one soon....
  13. #13
    Join Date
    Jun 2003
    Location
    WI
    Posts
    8,586
    riding a beer pie? Groovy...
  14. #14
    Join Date
    Nov 2004
    Location
    UM Maryland
    Posts
    24
    Yummm, I love me some bear pie.
  15. #15
    Coasting makes you grumpy
    Join Date
    Oct 2003
    Location
    Indiana
    Posts
    1,420
    What beer pie? Better not let [165] hear you talkin like that, those bars will be flying away.
  16. #16
    Join Date
    Oct 2003
    Location
    Indiana
    Posts
    1,420
    Drevil that is one fine, fine looking rig. Damn, getting dizzy, so dizzy.
  17. #17
    Senior Member IronHorse's Avatar
    Join Date
    Jun 2004
    Location
    London, England
    Posts
    72
    Ti singlespeed? How about one of these:
    http://www.on-one.co.uk/products/tiinbredebb.shtml
    Or Airborne do a Ti track frame if you're feeling rich...
    http://www.airborne.net/eready/janette/store/sobike.asp
  18. #18
    seniorita member sohi's Avatar
    Join Date
    Feb 2004
    Location
    London
    Posts
    731
    dont forget thylacine. he does them as well. although he has no pictures on his website.
    http://www.thylacinecycles.com/
  19. #19
    fast retro grouch
    Join Date
    Oct 2004
    Location
    Seattle
    Posts
    123
    Quote Originally Posted by Singlespeedster
    Yes.
    I see a bike begging for an ENO and a fixed gear! I'll come over and help! (build the wheel, perhaps?)
  20. #20
    Industry Maven Thylacine's Avatar
    Join Date
    Oct 2003
    Location
    Wherever good bikes are sold
    Posts
    2,937
    Thank you, Sohi. 'Tis true, I can do whatever in Ti...fixed....singlespeed....chopsticks...... My welder rides Ti, I'm just a sucker for steel ( mostly because I like pretty colours and can't bring myself to paint Ti )
    Okay, that's a lie - I'm too cheap.
    $1495 for a Just1Fix Ti or 221v Ti, $1650 if you like discs. A bit more for custom.
    Screw beer pie, Guinness pie is where it's at. The also do fried fish in beer batter here. Do you guys have that?
    Have you earned your stripes? <<click here / Questions about custom frames? Chat me! - warwickg71 (AIM/iChat) ThylacineCycles (Skype)
  21. #21
    Join Date
    Mar 2004
    Location
    Sci-Fi Wasabi
    Posts
    5,161
    I think everyone has that.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
