Advertise on Bikeforums.net
Results 1 to 14 of 14
Thread: Home Built
  1. #1
    Addicted to Tinkering NuTz4BiKeZ's Avatar
    Join Date
    Mar 2003
    Location
    New Zealand
    Posts
    192
    Home Built
    Hey...
    Any of you guys ever built a tandem?
  2. #2
    Senior Member bentbaggerlen's Avatar
    Join Date
    Sep 2002
    Location
    New England
    Posts
    725
    Yes, I built it from two single bike frames and a few pieces of tube. I was 16 or 17 and wanted a tandem, and with no money it was the thing to do. It was a little flexable, but it could be ridden safely.
    For some good infomation on building your own tandem take a look at Sheldon Brown's web page at: http://www.sheldonbrown.com/tandem/
    Bentbaggerlen
    "When the spirits are low, when the day appears dark, when work becomes monotonous, when hope hardly seems worth having, just mount a bicycle and go out for a spin down the road, without thought on anything but the ride you are taking." - Arthur Conan Doyle
  3. #3
    Join Date
    Mar 2003
    Location
    New Zealand
    Posts
    192
    Yup... It was the articles on Sheldons site that got me started in all this.
    Note at the time I took the pic I had dodgy forks on the thing... these have since been changed... Steers a whole lot better.
    The whole rig is a little bit odd but so far it seems to work pretty well.
    A friend would bail you out of jail... A good friend sits there beside you and says "Damn that was fun"
    Backyard Bents
    My Cycling Blog
  4. #4
    Senior Member matimeo's Avatar
    Join Date
    Feb 2006
    Location
    Beaverton, OR
    My Bikes
    Windsor Cyclo, Nishiki Seral
    Posts
    621
    I'm building one now and it has been probably one of the funnest DIY projects ever. As soon as this semester is over I'm going to finish building it up- looks awesome so far. I have pictures at: http://picasaweb.google.com/mas247/Tandem
  5. #5
    Join Date
    Oct 2005
    Posts
    1,737
    That looks rather nicely done matimeo. I hope the alignment works out. Do you have eccentric(s) to fit or are you going to use a tensioner?
  6. #6
    Join Date
    Feb 2006
    Location
    Beaverton, OR
    My Bikes
    Posts
    621
    I think I'm going to use a ghost chainring if the chain tension is a problem...
  7. #7
    Senior Member zonatandem's Avatar
    Join Date
    Dec 2003
    Location
    Tucson, AZ
    My Bikes
    ariZona carbon fiber tandem & single
    Posts
    9,422
    We hear tandems can be a bit of a rarity in Kiwiland . . . so the natural thing is to build your own.
    Way to go!
  8. #8
    Join Date
    Dec 2005
    Posts
    16
    I have built 2 the upright is carbon fiber while the recumbent is 6063 aluminum with carbon fiber lugs.
    The recumbent looks a little rough but I built in a week to see how it would work out, it is now a year and a half later and holding fine.
    I have more bike pics here http://s98.photobucket.com/albums/l249/brianharnett/
  9. #9
    Join Date
    Dec 2003
    Location
    Tucson, AZ
    My Bikes
    Posts
    9,422
    bharnjett:
    Nice c/f 2 seater. What is the weight?
  10. #10
    Join Date
    Oct 2005
    Posts
    1,737
    Quote Originally Posted by bharnett
    What is the process you use to do carbon fiber work? The only carbon fiber work I am remotely familiar with is in aircraft manufacturing and even then only in passing. From what I know there, they have to lay it and then cook it under pressure. How do you set up your c/f?
  11. #11
    Join Date
    Dec 2005
    Posts
    16
    The weight of the cf tadem is 36# the aluminum one is 45#
    I use west systems epoxy in my cf layups the west system sets up in temps ove 60 degrees.
  12. #12
    Join Date
    Feb 2006
    Location
    Beaverton, OR
    My Bikes
    Posts
    621
    Here it is, minus the stoker handlebars which should be enroute via ebay purchase. I'm happy with the result- it has been a fun do it yourself project. Ended up spending about $150+ on it, which I'm happy with. Anybody else have pictures of their homebuilt? One thing that I knew about before was that the stoker would be short on room, but that's ok because my wife likes to sit up straight on a bike and flick me if I misbehave. I have step-by-step of how I did it here: http://mattsbikes.googlepages.com/my...etandembicycle
  13. #13
    Senior Member BikeManDan's Avatar
    Join Date
    Jul 2006
    Location
    Oakland, CA
    Posts
    1,304
    Have you guys brazed yourself or brought to a shop?
    If done yourself, how much experience did you have when first attempting the project?
  14. #14
    Join Date
    Feb 2006
    Location
    Beaverton, OR
    My Bikes
    Posts
    621
    I actually had my brother in law weld mine with a MIG welder. I know they recommend TIG or brazing, but in reality MIG is cheaper and isn't going to break or anything. Someday I'd like to learn how to weld myself.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
