Advertise on Bikeforums.net
Results 1 to 19 of 19
  1. #1
    Spawn of Satan
    Join Date
    Mar 2003
    Location
    Grand Rapids, Michigan, USA
    Posts
    756
    Are all ball bearings the same quality?
    I rode on dura ace all last year for the first time. I cleaned and repacked the hubs once. I normally replace the bearings in my hubs the in the spring. My question is, do I need special bearings, or can I use the ones you get from any of the big mail order catalogs.
    In other words, are all bearings created equal when it comes to bicyle tolerances??????????????
  2. #2
    I am a lonely visitor RegularGuy's Avatar
    Join Date
    Feb 2002
    Location
    Where even Richard Nixon has got soul
    My Bikes
    Michelle Pfieffer, the Carbon Fiber Wonder Bike: A Kestrel 200 SCI Repainted in glorious mango; Old Paintless, A Litespeed Obed; The Bike With No Name: A Bianchi Eros; RegularBike: A Parkpre Comp Ltd rebuilt as a singlespeed.
    Posts
    2,879
    All bearings are not created equal. I believe you want grade 25 ball bearings. I don't know where you order them from but one source would be Bike Tools Etc.
    Religion is a good thing for good people and a bad thing for bad people. --H. Richard Niebuhr
  3. #3
    Join Date
    Nov 2001
    Posts
    1,655
    I was just wondering about that the other day.. Glad you asked it captsven..
    What does the grade mean? I went to the web site say Grade 200 and Grade 25..
  4. #4
    Join Date
    Feb 2002
    Location
    My Bikes
    Posts
    2,879
    The lower the number, the higher the quality. I'm not sure exactly how it works but I know that Grade 25 balls are harder than Grade 200.
  5. #5
    have bike will tour catfish's Avatar
    Join Date
    Sep 2001
    Location
    Wisconsin
    My Bikes
    Trek 5200, Trek 520, Trek 2120
    Posts
    380
    i looked in the phone bookand found a bearing company in our town Called them and they had grade 25 steel balls i bought 250 balls to overhaul a number of pedals and hubs (different sizes of course) the charged me 3 cents each and got them instantly
    catfish
  6. #6
    aka old dog greywolf's Avatar
    Join Date
    Oct 2002
    Location
    tauranga New Zealand
    Posts
    1,181
    I beleive theres a big diff. between steel balls (not so good) & ball bearings (the best) !!
    :D
    dont worry be happy ????
  7. #7
    Join Date
    Aug 2001
    Location
    upstate New York
    Posts
    1,690
    OK, there are several things to look for in ball bearings. First is the amount of polish. The finer the surface, the greater the cost...
    Secondly, there is the plating or anodizing. Better materials cost more.
    Steel balls are not ball bearings. Ball Bearings have a soft metal interior, with a harder metal covering. Steel balls are steel throughout. Not good for shock bearing surfaces-you'll kill the races very quickly.
    Je vais à vélo, donc je suis!
  8. #8
  9. #9
    Spawn of Satan
    Join Date
    Mar 2003
    Location
    Posts
    756
    I went to the Bike Tools Etc. link. From what I can tell, I would use the Grade 25 bearings in my Dura Ace hub.
    What would the stainless steel bearings do. Would they harm the races, or would they be a superior choice?
  10. #10
    Join Date
    Feb 2002
    Location
    St. Paul, MN, USA
    Posts
    98
    Below is an close up (60X) image of a ball bearing. Even this bearing is smoother and more precise than the cone or cup surface. The bearings, even "low" quality, tend to be the most precise part of the system.
    It is generally recommended to use the Grade 25 bearings when available.
  11. #11
    Join Date
    Sep 2001
    Location
    Wisconsin
    My Bikes
    Posts
    380
    ok you wizerds of knowledge got me. i called ball bearings steel balls
    CF
  12. #12
    Join Date
    Feb 2002
    Location
    My Bikes
    Posts
    2,879
    CF
    Let's get really technical. The ball bearing is an assembly made of the races and the bearing balls. We all call the balls "ball bearings," but we're wrong.
    Question: Does anyone know if the copper shot used in underpowered guns are called BBs as an abbreviation for "Ball Bearings"?
  13. #13
    Join Date
    Feb 2002
    Location
    My Bikes
    Posts
    2,879
    Oh, yeah...
    D*Alex is psychic! He answers questions before they are asked.
  14. #14
    Mr. Cellophane RainmanP's Avatar
    Join Date
    Nov 2000
    Location
    New Orleans, LA
    Posts
    3,037
    For cycling purposes there are 3 or 4 grades of bearings. Grade 25 is the highest grade, 300 the lowest, with maybe grade 100 and 200 in between. Even grade 25 cost only pennies each so there is no reason to use anything else. GENERALLY, headsets take 5/32" bearings and bottom brackets and hubs 1/4", but you have to check yours because there are exceptions.
    I guess there are stainless ball bearings or bearing balls, but bearings are supposed to be completely packed in greased and cleaned and re-packed regularly. If you run your bearings dry and dirty they are going to damage the cups and cones whether they rust or not. I feel the same way about stainless steel chains. If a part is supposed to be cleaned and lubed regularly rust should not be an issue so why pay 2-3 times as much for a stainless steel chain? Just the totally irrelevant opinion of an old codger.
    If it ain't broke, mess with it anyway!
  15. #15
    Join Date
    Sep 2001
    Posts
    197
    The standards referred to in the links above seem to refer to the roundness and roughness of the bearing balls.
    The cup and cone bearings used on standard bicycles are a low standard of bearing in any case. I don't believe using high standard bearing balls is any point for those bearings.
    The bearing balls need to be a number of grades softer than the bearing shells, otherwise you will wear out the shells, which are harder and more expensive to replace than the balls.
    I think the highest grades of bearings are designed for precision bearings, such as the bearings on stepper motors of hard drives ?
    I think the most important thing for bicycles is the type of seal that the bearing has.
  16. #16
    Senior Member mike's Avatar
    Join Date
    Jul 2000
    Location
    Snowy midwest
    Posts
    5,393
    Yup, John999 is correct with this point. This is a basic principle of engineering. If the bearings are harder than the cups, they will cut the bearing cups. Bearings are cheaper and easier to replace than cups.
    As a note from experience, I bought a bunch of bearings from a bicycle shop in China a couple of years back. I was just so delighted to see such an abundant supply of various sizes of bicycle bearings that I could not resist buying several packages for my parts collection.
    I used them to repack the hubs of a front wheel. After about a month or so of riding - CRACK.. KaTHUNK; The front axle dropped down onto the bottom of the hub. The problem: the bearings had cracked and disintegrated. They were literally pulverized and crushed into shards as if they were made of clay. Unbelievable.
    Needless to say, no more cheap Chinese bearings go on my bikes anymore.
    Mike
  17. #17
    Upgrade your Turbo Ritalin's Avatar
    Join Date
    Aug 2001
    Location
    Lenoir City, Tennessee
    Posts
    292
    I always wondered this too, that was my assumption
    I looked at Merriam-Webster Dictionary and the first defination for BB is
    Main Entry: BB
    Pronunciation: 'bE-(")bE
    Function: noun
    Date: 1874
    1 : a shot pellet 0.18 inch in diameter for use in a shotgun cartridge
    2 : a shot pellet 0.175 inch in diameter for use in an air gun
    number 2 is
    Main Entry: BB
    Function: abbreviation
    bachelor of business, ball bearing, base on balls, blue book, B'nai B'rith
  18. #18
    Join Date
    Feb 2002
    Location
    My Bikes
    Posts
    2,879
    So, it's actually short for B'nai B'rith?
    Funny that old Merriam forgot "Bottom Bracket"
  19. #19
    Join Date
    Aug 2001
    Location
    Posts
    292
    and bell bottoms, big bird, bouncing breasts... the list goes on!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
