Advertise on Bikeforums.net
Results 1 to 13 of 13
  1. #1
    Join Date
    Jun 2002
    Location
    San Jose & Los Angeles
    My Bikes
    Mercier Kilo TT (sold), Cannondale R900 2.8, Mongoose RX10.9 (sold), Xootr Swift, Schwinn Moab 1, Giant TCR C2, GT Zaskar, GT Forte Ti, GT GTB, Bianchi San Jose, Bianchi Fremont, Redline 925, Specialized Langster
    Posts
    2,164
    using chainring/large cog as tensioner?
    i've seen this being done by either somebody here or someone on MTBR.com. they put a ring/cog in the chain near the rear cog to tension. i did this to my bike (although i could have just took out a link because i got horiz drops, but that meant readjusting the vbrakes) and it seemed to hold pretty well. question is, is this an effective solution (even for vert drops) and does the ring/cog fall out (my chainline is pretty near perfect)?
  2. #2
    Join Date
    Dec 2002
    Location
    Wheat Ridge, CO
    Posts
    305
    That was me, it never fell out.
  3. #3
    Mr. Cellophane RainmanP's Avatar
    Join Date
    Nov 2000
    Location
    New Orleans, LA
    Posts
    3,037
    Are you doing this on a fixed gear or ss freewheel setup? To think I just spent about 50 bucks to put a Surly Singleator on my ss freewheel bike when I could have just stuck a cog in there for free! Bet it gets some funny looks, too, eh?
    If it ain't broke, mess with it anyway!
  4. #4
    Spawn of Satan
    Join Date
    Mar 2003
    Location
    Grand Rapids, Michigan, USA
    Posts
    756
    It looks like the only thing holding it in place is the tension between the two chain lengths. If this is the case, I can't imagine that it will stay in place. One good bump and it will come dislodged.
    Is this a serious setup, or are joking?
  5. #5
    Join Date
    Dec 2002
    Location
    Wheat Ridge, CO
    Posts
    305
    'Tis a serious set up. I ran it for three years with nary a problem.
    And it is good and bumpy around here.
    RainmanP, t'was a freewheel setup.
    A
  6. #6
    Join Date
    Jun 2002
    Location
    My Bikes
    Posts
    2,164
    i am doing that now too. thing is my chain always was a bit slack, and on the bumps it would fall out when i pedal. it actually works quite well though. and i dont know about you, but i think it looks kind of neat =]. imagine putting an anodized chainring or cog haha.
    i won't deny it i'm a straight ridah
  7. #7
    Join Date
    Jun 2002
    Location
    My Bikes
    Posts
    2,164
    OK tried it on a different bike and it ran flawlessly for about an hour (lots of bumps and rocks) it didn't fall out. then out of nowhere i was going down a paved road and it falls out, into my rear wheel, snaps some spokes, derails the chain. just had that wheel re-built too %@#$!!! this was a couple days ago, i threw on an old rear der. worked well during today's ride. rounded nipples caused wheel not to stay true though.
  8. #8
    crazy_DH
    Join Date
    Oct 2004
    Location
    Ottawa, Ontrario, Canada
    My Bikes
    Norco Rampage, and an old Hardrock specialised for stunts
    Posts
    46
    I say go for a chainring they work pretty well and arent too pricy. Thats actually the next step for me on my bike because the chain is starting to loosen up a bit.
  9. #9
    Retrogrouch in Training bostontrevor's Avatar
    Join Date
    Sep 2004
    Location
    Knee-deep in the day-to-day
    Posts
    5,485
    Apparently it's not an uncommon solution on tandems in the chain between the captain's and stoker's cranks. It's called a phantom chainring. Here's some more info:
    http://www.mtbr.com/faq/ssfaq.shtml
    In theory if it's done right, it shoud stay put (though you'll lose some mechanical effeciency). You'll want it to be tight enough that you can't get the chain to lift off the teeth of the phantom ring at all.
  10. #10
    Join Date
    Oct 2004
    Location
    PGH
    Posts
    306
    My friend has a tall bike that uses this method. I think its an awesome way to get chain tension. It looks really cool and gets alot of looks. Anyone else here into tallbikes?
  11. #11
    Join Date
    Sep 2004
    Location
    Posts
    5,485
    I see a few around, but don't have any myself. got any pics?
    You should also probably use a ring with "more" teeth than one with "less" (exactly what more nad less are, I don't know). You want to limit the angular separation between teeth so that you can always be sure that you have good tooth engagement in the chain, to hold the ring in place. At the same time, more teeth = more friction. It could also have some lateral sway that would annoying.
  12. #12
    Join Date
    Oct 2004
    Location
    PGH
    Posts
    306
    Sadly, no. I personally think tallbikes are rad as hell. I've got this idea of making a tall bike with a triple chain. Using a multicog freewheel and 2 sets of 2 ring cranks(one on the bottom frame without arms, one on the top to pedal) and making a triangle with a chain from one back cog to one ring on the bottom crank, then a chain from the other ring on the bottom crank to a ring on the top crank, then a chain from the other top ring, to another cog on the back. You would lose a ton of pedaling energy, but it would look damn cool, considering you could weld the frame straight enough to keep chain tension. I've never seen it done.
  13. #13
    Join Date
    Oct 2004
    Posts
    165
    That does look cool, I wonder if you could use consecutive "phamtom rings on a tall bike? for instance
    one smaller, about a foot further one larger, then another foot further one the same size as the first?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
