Advertise on Bikeforums.net
Results 1 to 3 of 3
  1. #1
    Join Date
    Sep 2002
    Location
    NC
    Posts
    3,416
    Is this possible?
    Ok guys. Would it be possible to put a SS freewheel on the back , and still use 3 chainrings up front? I was thinking I would take off the middle pulley of the der, and convert it to a singleator type of thing.
    This is for the huffy, and I just want to do it b/c i think it would be neat. I want to put some v-brakes on, and my shifter pods are integrated into the brake levers. I was thinking I would go derailler-less, and I would just use my hand or foot to shift the front. I have been doing a lot of urban stuff, and my seat is usually all the way down, so I basically I have two modes: small ring in front, and big cog in back for the goofball stuff i do when actually urbaning, and middle ring and big cog in back for the ride over. so really I don't need a real derailler. the question that remains is if it can be done.
  2. #2
    Join Date
    Sep 2002
    Location
    NC
    Posts
    3,416
    ok...I'm not going to do that. How about this.
    My rear derailler has just been trashed. ( pulley went flying into oblivion, and it is wrapped around freewheel at this time. So, i was thinking single speed again. I will take off the front derailler, the granny gear, and the rear mech. I might even leave the front chainings intact. I'll then shorten the chain, and lay the chain on the cog of my choice. Later, I will buy a freewheel.
    I have a seven speed freewheel hub on there right now, can I put a single on? Would there be a gap between the dropout and the frewheel? 7 cogs is definitly wider then 1.
  3. #3
    Senior Member BikerRyan's Avatar
    Join Date
    Dec 2002
    Posts
    306
    Yeah there will be a big ol gap where the spacer is on the axle so the chainline is going to be pretty ****ty, but it might work? Maybe.
    -Ryan
    Your bike mechanic is wise beyond your wildest dreams.
    If you can't be good at one sport then you can be okay at three.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
