Advertise on Bikeforums.net
Results 1 to 9 of 9
  1. #1
    Join Date
    May 2003
    Location
    Texarkana, AR
    Posts
    671
    Can anyone help me identify this?
    I restore old bicycles as a hobby. Recently a friend of mine gave me my first paid project. Neither of us has any idea of what this is, but it looks to be early-50's-ish. The crank and sprocket are non-original, they were taken from an old Royce Union several years ago, so they're no clue, and the rear wheel is also a frankenstein.
    I find the lines of the frame to be quite distinctive, and thought maybe somebody might know what it is. Also note the placement of the bottom bracket, I've never seen one recesses like that.
    Quote Originally Posted by DX-MAN View Post
    it's 'leaving the scene of an accident' because no state government has passed a law against 'leaving the scene of an on-purpose'.
  2. #2
    Join Date
    May 2003
    Location
    Texarkana, AR
    Posts
    671
    UPDATE:
    Does anybody know if there were ever any bicycles made with a brass frame? As I'm cleaning the corrosion and tar (don't ask) from the frame, It looks like it's BRASS underneath, and I swear it looks like the joints are brazed instead of welded.
    Anybody?
  3. #3
    Join Date
    Aug 2001
    Location
    upstate New York
    Posts
    1,690
    Most better-made bikes of yore were brazed. It's how lugs work. From your pic, though, it looks like some ham-fisted backyard mechanic welded/brazed a broken BB shell onto or off of this frame at some point. Probably has little strength there....
    Je vais à vélo, donc je suis!
  4. #4
    Join Date
    May 2003
    Location
    Texarkana, AR
    Posts
    671
    I am fairly sure it's an original bottom bracket, the joins at the top are flawless, it's only on the bottom that you can see any lumps from the brazing.
    Also, I've determined through use of a magnet (duh) that the frame is indeed ferrous.
  5. #5
    Lagomorph Demonicus stumpjumper's Avatar
    Join Date
    Sep 2001
    Location
    Dayton, Ohio, USA
    Posts
    802
    Thats the exact same chainguard on one of my bikes, and old Sears cruiser.
    Lord Bowler: Uh oh. You hit the sheriff
    Brisco County Jr.: Yeah, but I did not hit the deputy.
  6. #6
    Join Date
    May 2003
    Location
    Texarkana, AR
    Posts
    671
    The chainguard is also a frankenstein from another bike, it's held on with brackets, and when I removed it, there are old weld nubs left from the original. Thanks though.
  7. #7
    Join Date
    Sep 2001
    Location
    Dayton, Ohio, USA
    Posts
    802
    Weelllll... since all of the easily identifiable parts are from other bikes, I'd say you may be SOL.
    That reflector looking thing on the front... is it an actual reflector, or an ornament of some kind? If its not a reflector, then does it have a capital 'H' stamped in it by any chance??
    Can you post close-up pics of the fork crown, rear dropouts, and bottom of the BB? I might be able to work with those. Also, does it have a serial number? where is it stamped on the frame?
  8. #8
    Join Date
    Feb 2001
    Location
    England
    Posts
    11,728
    Brass brazing is used for lugged and lugless joining in bikes, but has been replaced by welding in recent years.
    Cruiser-style bikes are usually made of heavy-duty tubes in a workmanlike manner. I seriously doubt that it was made by a master frame-builder. To see what brazing artistry looks like, take a look at
    http://www.bohemianbicycles.com/Gallery's.htm
  9. #9
    Join Date
    Sep 2001
    Location
    Dayton, Ohio, USA
    Posts
    802
    I seriously doubt that it was made by a master frame-builder. To see what brazing artistry looks like...
    ...come to my house and I'll show you the worst fillet-brazing job in the world
    Its on the later of my two brazed schwinn supersports. The older one is nice. The newer one looks like crap. |P
Posting Permissions
  • You may not post replies
  • You may not edit your posts
