hand numbness
hand numbness
My hands get numb when i ride more than 20-25 miles. It's usually mostly my left hand, and the numbness mostly goes away temporarily if i shake my hand vigorously for 30 seconds or so. I've tried altering hand positions and putting less weight on my hands but that doesn't seem to do much. Any suggestions?
heres a good link for some explanation - https://www.nlm.nih.gov/medlineplus/e...cle/000433.htm
vary your hand position get your wrists off the top bends, ride the tops with your hands across the tops and arms tucked in, ride the hoods, spend some time in the drops.
last year I also had problems with numbness in the hands - not sure what caused it, but it took almost 2 mos of really paying attention to hand position and very frequent changes before it started subsiding.
Could it be related to your job? Cycling might just be putting the finishing touches on the main cause of the problem.
Thanks for the help. The numbness is in my index and middle finger, just as expected from carpel tunnel. Hopefully now that i understand the location of the nerve etc, i can try to keep pressure off it. Do you have any suggestions for positioning the drops? would rotating them higher or lower potentially help?
Being that I prefer non-anatomic (classic bend) bars I like to have a slight downward tilt of the 'drop' so that a sight line down the drop towards the rear of the bike goes a goodly amount above the rear hub, closer to wheel top. But it really depends on the bars - some bars 'finish the bend' more than others.
You just gotta 'fish' til you find a position that you like. Often the bar makes a real difference. Of all the anatomics I've tried I like the Spec Carbon bars that came on the Tarmac and Roubaix well enough to not bother changing them. I also found the old Supergo Anatomics were reasonably acceptable - for me...
I just way prefer the classic bend - Reynolds Ouzo Bars, DaKine!
Bikes: Moots RCS, tandem, beach-cruiser, MTB, Specialized-Allez road-bike, custom track-bike
Also bend your elbows for suspension. This lets your upper-body remain stationary when hitting bumps and not getting hit with the full force of the bumps.
And rotate your hands where you grip the bars so that the weight is carried on the meaty outside heel. This relieves any force from the middle valley in the palm where the median and carpal nerves run.
...the numbness mostly goes away temporarily if i shake my hand vigorously for 30 seconds or so....
Gotta relax from the neck down and let the arms be suspension rather than a more rigid structure.
There's a simple test that doctors can use to diagnose whether it's carpal tunnel. It's not something that you really want to mess around with.
Eric
2005 Trek 5.2 Madone, Red with Yellow Flames (Beauty)
199x Lemond Tourmalet, Yellow with fenders (Beast)
Read my cycling blog at https://riderx.info/blogs/riderx
Like climbing? Goto https://www.bicycleclimbs.com
Eric
