Advertise on Bikeforums.net
Results 1 to 6 of 6
  1. #1
    Join Date
    May 2003
    Location
    chicago
    Posts
    1
    MTB w/slick tires vs hybrid
    hello all, just wanted to say this is a great forum. searching through the various threads have answered the majority of my questions, however, now i need some opinions.
    i am planning on purchasing a bike for mostly road use (maybe the occassional light trail). unfortunately, a road bike is well out of my range ($300-400). initially i was looking at hybrids, but after reading some negative comments regarding them (i.e. it's not a good road bike, nor is it a good MTB) and hearing other suggestions about putting slicks on an MTB, i was wondering if maybe i should go that route. i plan on riding a couple times a week for fitness purposes and the occassional 10-15 mile trip to the lake.
    what suggestions do you guys have? should i go with a hybrid or find an MTB and put city tires on? i'm in the process of visiting some lbs, so hopefully they can clear up some of my confusion as well
    btw, i saw the specialised sirrus, and although it's slightly out of my range ($450), the styling and feel is really drawing me towards it any opinions on that bike as well?
    sorry for the long post :-T
  2. #2
    A Heart Needs a Home Rich Clark's Avatar
    Join Date
    Oct 2001
    Posts
    1,387
    The best thing about the Sirrus is that it doesn't have a suspension fork. As hybrids go, I think it's one of the better designs for that very reason; it's closer to being a "flat-bar road bike" than other current hybrids, most of which seem to just be comfort bikes with slightly larger wheels.
    A MTB with slicks is a perfectly good compromise if you think you may want to do more off-roading in the future, but the truth is that a $450 MTB probably won't stand up to much of a beating. Whereas a Sirrus, used on pavement, paths, and gravel, should last indefinitely.
    Road bike prices are coming down: there's a whole class of entry-level road bikes in the under-$500 range now. But if that's not what you want, the flat-bar road bike -- or "fitness bike" as they're starting to be called -- is a reasonable compromise. Personally, I'd stay away from low-end MTB's, even with slicks.
    RichC
    Training: 2002 Fuji Roubaix Pro (105 triple)
    Commuting/Daytripping: 2001 Airborne Carpe Diem (Ultegra/XTR, touring wheels)
    Commuting/Touring: 2000 Novara Randonee (Sora/Tiagra/LX, fenders, lights)
  3. #3
    Senior Member joeprim's Avatar
    Join Date
    Jan 2002
    Location
    Northern Neck Tidewater Va.
    Posts
    1,704
    Spook
    Just to be contary I'll point out that for what you describe a low cost MTB with or without slicks would work fine and last a long time. I like the drop bars on my road bike, but I can live with the flat bars on my cheap mtb.
    It seems like more money gets you lighter but for 10 or 15 miles who cares and if weight is a problem it is usually easier for the rider to loose weight.
    Pay money for smooth components and quality wheels.
    Consider a used bike.
    You may not like the sport so start gentley both physical and monetry stress.
    Joe
  4. #4
    Join Date
    Apr 2003
    Location
    St Louis, Missouri
    Posts
    91
    Fit comes first, everything else comes later. How you fit on the bike will affect your comfort, efficiency and fun every single minute that you are diring the bike. Nothing else even comes close in importance.
    That's why I have a problem with most inexperienced riders buying a used bike. If you don't already know what a well-fitting bike feels like, how can you know if this is it? My advice is to go to the best local bicycle shop to get fitted for a bike, and try to find an old guy to wait on you.
  5. #5
    Join Date
    Feb 2001
    Location
    England
    Posts
    11,785
    $450 MTBs or hybrids can take a lot of beating. People do extended tours using them. The only weakness is potentially poor wheel-build, which any good bike shop can check.
    Take a test rise on a hybrid and the best ridgid MTB you can find. The quality ofthe ridgid fork makes alot of difference. An fat hi-tensile steel fork will beat you up much more than a lighter chromoly one such as found on Kona bikes.
    You can change the styres on any budget bike to get a huge improvement in performance. The difference between an MTB on 1.5 slicks and a hybrid on a 32mm slick is not so big.
  6. #6
    Join Date
    Nov 2002
    Location
    Ontario, Canada
    Posts
    51
    I've been riding a cheap ($300) steel MTB with 1.5 slicks for a long time (the bike probably has about 20,000 km) and I'm very happy with it's durability.
    Another advantage to using an MTB is the wider range of parts and accessories available (e.g. fenders).
Posting Permissions
  • You may not post replies
  • You may not edit your posts
