Somebody is spreading rumors that sweat and Ultraviolet exposure will cause your helmet to degrade. Sweat will not do that. The standards do not permit you to make a helmet that degrades from sweat, and the EPS, EPP or EPU foam is remarkably unaffected by salt water. Your helmet will get a terminal case of grunge before it dies of sweat. UV can affect the strength of the shell material, though. Manufacturers put UV inhibitors in the plastic for their shells that control UV degradation. If your helmet is fading, maybe the UV inhibitors are failing, so you might consider replacing it. Chances are it has seen an awful lot of sun to have that happen. Otherwise, try another brand next time and let us know what brand faded on you.
