Advertise on Bikeforums.net
Page 2 of 2 FirstFirst 12
Results 26 to 27 of 27
  1. #26
    Senior Member TwoFourOne's Avatar
    Join Date
    Dec 2011
    Location
    Florida
    Posts
    147
    Quote Originally Posted by MilitantPotato View Post
    Graphite in the keyhole, teflon spray on the other bits. Doesn't need to be bicycle specific (same goes with every other type of lube used on a bike, but that starts a debate.)
    If ya have some dry chain lube laying around, use what ya got.
    So the dry lube can go in the keyhole?
  2. #27
    Commander, UFO Bike K'Tesh's Avatar
    Join Date
    Dec 2008
    Location
    Subject to change
    Posts
    1,320
    Phosphoric acid is part of the acid found in soft drinks. The Mythbusters tried to use it to clean rust, and called it "Busted" but this is one that I disagree with. If you do try it, I strongly recommend you flush with water immediately afterwards, then re-lube.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
