39 tooth Shimano 600 yes or no ?
Bikes: Vitus
I've got the old Shimano 600 group, with a 52/42 or maybe 53/43. I've seen a couple of complete cranks on ebay with a 39 tooth ring. Is it possible to purchase just a 39 tooth ring that would work with my current crank?
FalconLvr
Bikes: 62 Falcon, 58 Raleigh Lenton Gran Prix, 74 Raleigh Pro, 75 Raleigh Int, 75 Raleigh Comp, 76 Colnago Super, 75 Crescent, 80 Peugeot PX10, plus others too numerous to mention!
Quoted: 51 Post(s)
Liked 112 Times
Sure, just find one with the correct BCD, and styled as an "inner" chainring (I doubt there are many 39 tooth outer chainrings!) and you are good to go, brand does not usually matter.
Bikes: 1978 Nishiki Superbe, 1982 Miyata Team, 1987 Miyata 912, 1987 Davidson Challenge, 1993 Bridgestone RB1-7
Originally Posted by vpiuva
Your BCD is 130mm and will fit down to a 38t ring.
Originally Posted by ga_mueller
But you will have to do some Dremel-ing on your crank arms, assuming it's an older-style 600.
??? What ???
Not sure about old Arabesque, but any style after that I know it just bolts right on. I had a 38t Real ring on one.
Quoted: 3811 Post(s)
Liked 6,708 Times
The two Arabesque cranks I've had were 130bcd; nothing odd-sized about them.
Neal
Neal
Prodigal road guy
Bikes: '72 Bob Jackson; '82 Austro-Daimler Starleicht; '85 Scapin; '80 Peugeot PKN-10; '81 Trek 610; '87 Hunter Corsa; '72 Italvega and '75 Motobecane Grand Jubillee frames built into freewheel singlespeeds.
I ride 52/39 on one of my 600 cranksets, this particular set bearing date codes from 1986 ; no issues. My ride home from work has a 14% grade at one point, and the difference between a 39 and the more usual 42 is noticeable, and welcome.
Originally Posted by vitus_blue
it's the "newer" style, with the green,blue, black bar under Shimano 600.
