Advertise on Bikeforums.net
Results 1 to 8 of 8
  1. #1
    Join Date
    Feb 2007
    Posts
    135
    Rear Light falls apart over bumps.
    I am on my 3rd Rear Light in about 12 months. (i find the batteries last longer than the light itself)!
    The problem is that the Attachment/Bracket and the Body of the lights all seem to be joined together with no real thought to the bumpy and rough nature of actual riding.
    I find that after a little bump / speed hump or dropping off a gutter the back half of the light will pop off and smash onto the ground. They seems to survive the first few smashes but eventually a car will run them over or a similar fate will befall them.
    So anyone know a real tough and intelligently built rear light?
  2. #2
    Plays in traffic tsl's Avatar
    Join Date
    May 2006
    Location
    Rochester, NY
    Posts
    5,743
    It depends on how you're mounting it. Screwed to a standard reflector bracket, my CatEye LD-1000 has even survived a crash without falling off or falling apart. It got scraped up some, but otherwise it and its mounting are just fine. Same light mounted to its plastic QR seatpost mount flew out occassionally, which is why I screwed it to the reflector bracket on the rack.
    I'm currently saving my pennies for a DiNotte taillight. it mounts the same way as their headlights, which for me, stay put really well.
    My two favorite things in life are libraries and bicycles. They both move people forward without wasting anything.
    The perfect day: Riding a bike to the library.—Peter Golkin
    Lucky for me, I work at a library and bike to work.
  3. #3
    Guy on a Bike TreeUnit's Avatar
    Join Date
    Mar 2006
    Location
    C-Bus
    Posts
    249
    You could just use the belt clip on the light.
  4. #4
    Join Date
    Jun 2005
    Posts
    1,176
    Quote Originally Posted by lukeC
    Don't know why your light is falling apart, but, if that were happening to me, I'd take some cellophane tape and wrap it around the entire assemply - end of problem.
    I did have some metal brackets that were specially designed to mout rear lights . . . and they were not up to the task. They would develop fatigue, break, and, poof, there goes my light.
    I am using plastic (or whatever the OEM material is) brackets now, and am having much better luck with them.
    Caruso
  5. #5
    Senior Member ken cummings's Avatar
    Join Date
    Dec 2005
    Location
    northern California
    Posts
    5,676
    I know a tough one, powerful too. If you do not mind a Do It Yourself item the size of a muffin. Take one of the strobes from www.allelectronics.com, secure the innards with a commercial or homebrew potting compound, zip tie it to your rack or saddle rails, and wire it to a 9 to 18 volt battery. Mine has lasted some 18 years and several crashes. I also use it as a safety light when I go out into San Francisco Harbour at night on the 4th of July to watch the Sausalito fireworks up close.
    By the way, my wife has to work early the next morning and can't go this year. Any NorCal BFers interested? I'll bring the wine.
    This space open
  6. #6
    Senior Member Ziemas's Avatar
    Join Date
    Nov 2004
    Location
    Riga, Latvia
    Posts
    10,255
    Cateye mounts are pretty good. I regularly ride over lots of cobblestone roads and I've never lost a light. The Planet Bike mount also looks good, but I only have a couple of weeks experience with it, not several years like the Cateye.
  7. #7
    2 Wheel Junkie
    Join Date
    Sep 2004
    Location
    SoCal
    Posts
    345
    The mount on my Cateye EL-200 (3-led) broke yesterday. I noticed that as I was riding the light was vibrating a lot. So when I got into the office I took the light off and noticed that sections of the rail mount on the light broke off.
    It's broke, so now it's time to fix it. As in get a new light. Duct tape is being used as a temporary fix.
    Ooooooooo, upgrade to HID bike light time! Oooooooooo, expensive. Hmmmm.
  8. #8
    Senior Member neilfein's Avatar
    Join Date
    May 2007
    Location
    Highland Park, NJ, USA
    Posts
    4,044
    I've had the same problem, but mostly with headlights. I did lose one taillight that way, but the ViewPoint flashback 5 has stayed on pretty well, even going over potholes or gravel.
    Tour Journals, Blog, ride pix
    Our brand-new 3-song studio EP on Bandcamp, our blog, and our concerts. Also still available, the full album Live at Mannion's.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
