Advertise on Bikeforums.net
Results 1 to 5 of 5
  1. #1
    Join Date
    Jun 2007
    Posts
    4
    Thumbs down Hub Drive Rolling Resistance
    Hi Guys
    I'm posting from Western Australia and looking for some advice on my new Front Hub drive. It’s a 400W brush less, gearless Chinese model (don’t know the brand). I've mounted the drive on the front forks with the bike upside down. In this situation, the instructions (in poor pronunciation) say that it should spin freely with some slight resistance. I'm not sure what this 'slight' resistance is, it seems to be very tight, moving 1/3 of a turn max when spinning by hand. It feels like it is a kind of staggered resistance (tight then loose then tight again...). It makes no difference if the wheel nuts are tight or loose. Funnily it spun fairly freely when I first took it out of the box. Any suggestions? Maybe I've got a dud product
    Cheers:
  2. #2
    e-Biker
    Join Date
    Aug 2006
    Location
    Mississauga, Ontario, Canada
    Posts
    951
    If that hub is anything like the Bionx, spinning the wheel should get you a few complete revolutions, about 10 or so, with one single hand powered thrust.
    Are you spining the wheel with the power on?
  3. #3
    Join Date
    Jun 2007
    Location
    Vancouver, BC
    Posts
    273
    Sounds like cogging torque. Power it up and see if the no load speed seems ok, and then give it a test ride.
  4. #4
    Join Date
    Jun 2007
    Posts
    431
    Quote Originally Posted by Bluepup
    Hi Guys
    Cheers:
    Are the motor wires connected to the controller? Does the motor run with everything hooked up? Bionix freespins easier than most hub motors either because the controller powers up the motor slightly or it has a squewd stator and a large airgap between the magnets and stator to help eliminate COGGIING which is the magnetic detent from the magnets sticking to the stator teeth with no power applied.All hub motors COGG unless they have a machcanical freewheel.Your stator wires may be touching each other ?
  5. #5
    Join Date
    Jun 2007
    Posts
    4
    Thanks guys, I'l power it up tonight and see how she goes and I'll feed back. Happy Ebiking
Posting Permissions
  • You may not post replies
  • You may not edit your posts
