Go Back  Bike Forums > Bike Forums > Triathlon
Proper Cadence
Triathlon Swim / Bike / Run your thing? Drop in our new triathlon forum for the latest in training & gear. From beginner to expert, and sprint to ironman.
Proper Cadence
Old 07-30-07 | 07:57 PM
Fritzle
Bikes: Giant OCR
Proper Cadence
I finally broke down and got a bike computer that has a cadence sensor. What is the correct cadence range? I find 60-70 rpms seems to be where I ride most of the time. Is this to slow or should I change gears to increase/decrease my cadence?
fritzle is offline
Reply
Old 07-30-07 | 08:35 PM
20 Anniversary
Bikes: Trek 5300
I too ride at 60 to 70 rpm, but I am a one legged 86 year old biker who is about ready to give up biking because of my infirmatives. The proper cadence is one which you can ride continuously without becoming winded. You must experiment and try for a high cadence. You will find that the higher the gear the you will have to pedal slower to avoid running out of air. There is no proper cadence that applies to everyone. It is an idividual thing even among proffessional bikers. I have had cadence on my computer for many years and I think it is quite a help in improving your performance.
Robert Gardner is offline
Reply
Old 07-30-07 | 08:36 PM
Bikes: Litespeed Ultimate 2006, Litespeed Pisgah , Specialized Roubaix 2008, Trek Madone 2011
On the flats I ride at 90-95. Take a look at gear tables with different cadence.
jimblairo is offline
Reply
Old 07-30-07 | 08:46 PM
Miguelangel's Avatar
Bikes: Lemond Tourmalet
Heres a couple of links regarding cadence...
https://www2.bsn.de/Cycling/articles/cadence.html
https://www.beginnertriathlete.com/cm...?articleid=433
I went up from 76 to 88-90 range. Uphills depending on lenght I try higher rpm. Find it to be actually more efficient . Some spinning trainning might help you move your cadence up..... god luck hope it helps a bit
Miguelangel is offline
Reply
Old 07-30-07 | 09:46 PM
dapittbull69's Avatar
Blow up expert!
Bikes: 2006 Giant OCR C3
i like a high cadence going up hill and a lower one on flats but spinning a bigger gear. it's all about personal prefrence.
dapittbull69 is offline
Reply
Old 07-31-07 | 06:24 AM
Fritzle
Bikes: Giant OCR
Thanks for the article
The cadence article from the tri website was great info. I tend to be a masher, which I believe comes from years of playing hockey. I'm going to step up my cadence and experiment a little, it appears spinning faster might help me in my run portion of the race.
fritzle is offline
Reply
Old 07-31-07 | 07:33 AM
Roadie/Duathlete
Bikes: Colnago ExP, Look 595, Look 496, plus a few more...
Everyone has an ideal cadence... just because the current trend is high cadence, does necessarily mean that this is correct for you. There is definitive benefits in increased cadence (wattage per revolution is lower, hence you will have a theoretical ability to generate higher wattage), but also drawbacks (you tax your cardiovascular system much more). You need to find your comfort zone, where you have the correct balance. In general, 60-70rpm is a bit low though... you can probably work on getting that up to at least mid. 80's and still be comfortable.
audiojan is offline
Reply
Old 07-31-07 | 11:48 AM
bigger riders tend to have lower cadences and push bigger gears and small riders get in more rpm at
carbonjockey is offline
Reply
Old 07-31-07 | 12:52 PM
Too Much Crazy
Bikes: Eriksen 29er, Gunnar Roadie, Niner RLT, Niner RIP 9
I tend to have much fresher legs on the run (especially in 1/2 IM distance)when keeping the cadence at or above 90 rpms. and i am a big guy (6'2'' 185lbs). I guess it is personal preference though, but I have noticed better run times when I spin instead of mash.
it takes practice to feel comfortable at a higher cadence.
C Law is offline
Reply
Old 07-31-07 | 11:34 PM
WxGuesser's Avatar
15 Anniversary
Bikes: 2015 Cervelo S3, Fuji SL1, Felt TK2, Cervelo P2C
how long of rides are you doing at your current cadence? i bet you're tired when you're done. I usually ride at 85-95 rpm... that's about perfect for me to not tire myself out.
WxGuesser is offline
Reply
Old 08-01-07 | 04:40 AM
fueledbymetal's Avatar
Bikes: Cannondale SuperSix & CAAD9, Singlespeed Seven
I was around 70 when I first started out but have since moved up to ~90. The biggest benefit for me with a higher cadence is that it puts way less strain on my back. Also, as mentioned above, my legs now feel fresher when I get off the bike (all while my average cycling speed has increased as well!)
fueledbymetal is offline
Reply
Old 08-01-07 | 09:05 PM
rplong's Avatar
Bikes: Specialized Allez Pro, Trek 2300, Specialized Rockhopper, Cervelo P2SL
85-110
rplong is offline
Reply
Old 08-09-07 | 07:39 AM
Fritzle
Bikes: Giant OCR
I bumped my cadence up into the lower 90 rpm range and found that after getting used to the "spinning" vs "mashing" feeling my speed did pick up with much less effort. Thanks for all your postings !
fritzle is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
