Advertise on Bikeforums.net
Results 1 to 4 of 4
Thread: Brakes
  1. #1
    Join Date
    Apr 2000
    Posts
    1
    I have an old bike that is great for stunts and jumps, which i love to do, but the problem is it has pedal brakes and they get in the way. Does anybody know a way to disable them?
    Thanks,
    Mark
  2. #2
    Moderator
    Join Date
    Apr 2000
    Posts
    531
    You will need a new rear wheel. Simply buy one with a normal freewheel. And of course you will now need the brakes. That is all.
  3. #3
    Join Date
    Apr 2000
    Location
    canada
    Posts
    6
    You may be able to get away with disconnecting the brake arm from the chain stay (frame member) or removing the brake arm from the hub all together. I've never tried it and can't imagine the physics of it right now but try it and let us know.
  4. #4
    Join Date
    Jan 2000
    Posts
    8
    <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by squeaky wheel:
    You may be able to get away with disconnecting the brake arm from the chain stay (frame member)<HR></BLOCKQUOTE>
    DON'T DO THIS!!!
    If you do, when you hit the brakes the arm will spin around and cause nothing but havok, it could damage the frame and/or hub.
    Get a new wheel (or have one built) that uses a BMX hub and a BMX freewheel.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
