Advertise on Bikeforums.net
Results 1 to 6 of 6
  1. #1
    Join Date
    Sep 2003
    Location
    fefe
    Posts
    6
    front Suspension - closing the SID
    going down in xc race, in a flow singletrak without 2 much jumping
    away
    is it right that if i would close a bit the front Fork (SID) i will b faster ?
    or it is just a mistake 'feeling' ???
    thanx
    ela
  2. #2
    NOT a weight weenie Hunter's Avatar
    Join Date
    Dec 2000
    Posts
    1,792
    I am sorry, I do not understand the question.
  3. #3
    Join Date
    Sep 2003
    Location
    fefe
    Posts
    6
    my question is when riding in a singletrek, not very technical but still in a singletrek with sharp curves, is it right or wrong: when I would close the front suspension a bit (a fork like rocksock SID) I will b faster ? - or it is just a wrong feeling that u have and actually u are faster when the fork is 'open' to maximum suspension ?
  4. #4
    C Line.... Dannihilator's Avatar
    Join Date
    Oct 2002
    Location
    Annandale, NJ.
    Posts
    16,541
    When you're going through technical singletrack, the last thing you want to do is lock the front in the minimum setting.
  5. #5
    Join Date
    Feb 2003
    Posts
    1,012
    I have'nt used one of those forks in years so I don't know how to set them up properly but generally on any downhill you want the fork to be as active as possible so it must not be locked out.
    rebound and comppression damping should be a bit quicker and preload will have to be set for your weight.
    Getting the negative spring setting right will help the fork track better as well.
    hope this helps
    An ounce off the wheels is worth 3 off the frame
  6. #6
    Senior Member mindbogger's Avatar
    Join Date
    Jul 2003
    Posts
    945
    i think that the sid only offers a full lock out so it might not be wise to set it on the single track. You may hit a big bump and a rigid bike is not gonna help at all
    00' Cannondale R1000
    01' Devinci Chilipepper
    When sh*t hits the fan, everything I'm not, made me everything I am.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
