Any quicky hints for winter/cold riding?
Do you have any quicky hints for riding in cold weather?
Here are a couple:
1) When breathing in cold air, put your tongue on the roof of your mouth and breath through your mouth. Your tongue will warm up the air a bit and help prevent freezing your throat and lungs. Your tongue might get a little cold, but it won't freeze.
2) If your hands get cold, wrap them in a wool or other breathe-able fabric (like a knit hat or your shirt/sweater tail) and breathe warm air from your mouth into the fabric. This will hold the warm moist air on the skin longer and will warm your hands up faster.
This trick works well if you are riding with someone who get's cold ears as well.
3) Similar to the hint above, if you are riding with children who get cold, pull their collar up so that it covers the back of their necks and breathe into the fabric, then put your hand over the fabric and hold it there while you take your next breath. Be careful with this one, some kids will pee their pants because it is so warm.
4) The ultimate hand/feet warmer is a warm belly. If you love your bicycle partner enough and if the situation warrants this drastic measure, let her/him slip their cold hands under your sweater and onto your warm stomach. Of course, this is the ultimate sacrifice, but it is long remembered by the thankful recipient. I let my wife and kids do this once - all at the same time. I was the hero of the day.
Here are a couple:
New to bikeforùms.net
Breathing through the mouth is bad. When mouth breathing, the brain thinks carbon dioxide is being lost too quickly and sensing this, will stimulate the goblet cells to produce mucous, slow the breathing and cause constriction of blood vessels. Breathing
through the nose also limits air intake and forces one to SLOW down. The lungs are a primary control of our energy level. They extract oxygen from the air we breathe primarily on the exhale. Because the nostrils are smaller then the mouth, air exhaled through the nose creates back pressure when one exhales. It slows the air escape so the lungs have more time to extract oxygen from them. When there is proper oxygen-carbon dioxide exchange, the blood will maintain a balanced pH. If carbon dioxide is lost too quickly, as in mouth
breathing, oxygen absorption is decreased. I have been to races in the winter, it is so hard to breathe cold air for so long, especially from the start, I get a sore throat and everything hurts really bad. Its just really hard to breathe at all.
Klein, if you are from Marquette, Michigan, you know that breathing through your nose in extreme cold just isn't an option.
First, the cold air will freeze the tip of you nose and the skin around your nostrils.
Then, your sinuses will plug up.
The theory you mention is interesting, but I'll bet if we saw you sledding at Marquette Mountain on a cold Saturday in January, you would be breathing through your mouth too.
Every lane is a bike lane
From: Gold Coast, Queensland, Australia - passionfruit capital of the universe!
Klein, how much of what you say applies in really hot weather too? You have given me a lot to think about.
I am clinically insane. I am proud of it.
That is all.
That is all.
0^0
Bikes: Redline Monocog,Surly Crosscheck, Lemond Reno
I think I would suffocate if I didn't breathe through my mouth while riding...:confused: If I drink enough water I don't get a mouth full of mucose...
Booyah!!
Booyah!!
Dress appropriately for the wind/temperature (not overdressed), cover extremeties and...
HEAD SOUTH!
No worries
No worries
Bikes: Seven Axiom Ti, Trek 620, Masi cylocross (steel). Masi Souleville 8spd, Fat Chance Mtn. (steel), Schwinn Triple Bar cruiser, Mazi Speciale Fix/single, Schwinn Typhoon
Big scarf around neck and lower face, ends spread out on chest
Wind vest over or newspaper under ( chest) of outer layer is a better choice than a jacket ( or newspapers) between layers if you're in need and/or away from home)
Caps
Ear muffs
(Many) Thin layers; layer hands, legs, feet and head too
Adjusting and having enough ventilation to rid EXCESS heat to Avoid sweating and resulting wetness- "Danger! Danger! Will Rogers"
Drink a LOT of water, you lose it with EACH breath in the cold
WOOL
DO NOT WEAR COTTON, especially next to your skin- see previous "Danger quote" and add 25 % to 50 %
Mitts, Lobster Gloves, loose fitting gloves
Plastic bags over sock toes in "breezy" shoes
Old socks over shoes
Big shoes w/extra socks
Ride Warm
Pat
Caps
Ear muffs
WOOL
Ride Warm
Pat
Bikes: Felt F-70, Terry Madeleine, Novara Safari fully customized by me
If you use gore-tex or similar wind/water proof socks, avoid the use of powder. Like dirt, it can reduce the effectiveness of the pores.
I live in Iron Mountain MI It really gets cold. What I have done is put a layer of thermals on then a wind suit then some sweat pants and shirt then another wind suit. For shoes Iceman boots with wool socks. I also found that mittens were the best to wear to keep contact with other fingers. thermal facemask. Ive been out in -30 riding and have kept SOMEWHAT WARM . GOTTA LOVE IT PEOPLE
I'm not sure if this is so much a tip as an opinion, and a possibly controversial one at that. I don't think it's that important to avoid perspiring under one's layers, even in weather well below freezing. Not that I have found myself sweating heavily in the very cold, but when it comes to moderate perspiration I've never been chilled or even uncomfortable. Nor do I think that clothing that breathes is all that important in very cold weather. In my experience, the pores on newer fabric get plugged with frozen water anyway.
Much more important, in my view, is a wind proof outer layer. If you have that, you can get away with surprisingly few layers in really cold weather. You generate so much heat on a bicycle that if you can simply reduce the rate the wind sucks heat away even a bit you can ride comfortably. A water resistant cycling windbreaker will get you through some bitter days, even with just two or three thin layers underneath. The wind resistant clothing also helps reduce problems associated with sweating in the very cold, too.
Glover liners are an excellent idea, too-- but not just because of warmth. You can handle tools with the liner if you have to make a repair, and you can touch metal without burning your skin.
Originally posted by Merriwether
I'm not sure if this is so much a tip as an opinion, and a possibly controversial one at that. I don't think it's that important to avoid perspiring under one's layers, even in weather well below freezing. ...Much more important, in my view, is a wind proof outer layer.
In colder weather you need really effective windproofing, with good seals at the cuffs , waist and a high neck (4" rather than the usual 1" neck). It's much better to have a highly permeable material, than let the cold draught in through pit zips. On really chill nights, I wear 2 windproofs for extra protection.
A pile and pertex jacket (like Buffalo ) is a great system for really cold damp conditions, or heavy cold rain.
Originally posted by MichaelW
I have pretty much given up on breathable waterproofs
Wind breakers really do help, but most trap the moisture. You won't notice the ill-effects until you stop to rest and your wet clothes start to hyper-chill your body. This is a problem on longer rides where you end up stopping to rest out-of-doors.
For trips that don't require and outdoor rest-stop, though, I agree that a wind-breaker works great - almost too good; too warm.
I'm with you on that. None of the so-called breathable waterproofs (including Gore-tex and all the other hyped products) really let the moisture out if you are doing anything physical.
I've heard good things about them from walkers, and have always been impressed with the quality of their packs.
Richard
Currently riding an MTB with a split personality - commuting, touring, riding for the sake of riding, on or off road :)
I have used vaseline on my face before but lately I have discovered a product called FaceStick made by none other than ChapStick that REALLY does the trick, and you won't get slimy hands putting it on. It comes in a big fat tube (like your tires) and stays on even after a hard sweat. You can find it at the Evil Empire (uh, that's WalMart) or just about anywhere and still have extra deneiro for those upgrades at the shop!
No more peelies!
No more peelies!
No more peelies!
No more peelies!
Very Senior Member
Bikes: 2000 Bianchi San Remo and a mint 1984 Trek 720
I have been wishing chapstick would come out with something for my face. Is in UV protection too? - that would be nice.
It's better to cycle through life than to drive by it.
Very Senior Member
I have summer bike shoes and I don’t want to pay for a winter pair or for booties if I can help it.
I'm using old plastic bags. I put them on after my last pair of socks and just before the shoes. I tuck the part of the bag that sticks out of the shoe into the bottoms of my tights to keep them out of the chain ring. So far my toes have stayed pretty warm but not sweaty.
I'm now grading the stores in my are based on how well their bags fit my feet.
I guess a lot depends on skin type--I have pretty oily skin and have never been bothered by cold except the lips, and for those I use Chapstick or any of the many equivalents.
Plastic bags on the feet are fine for not-too-long jaunts in the cold, I find. I used them before I got good Neoprene booties. The plastic will keep water off your shoes better than booties. You can also use them to help booties on and off your feet easier in case they fit a little too snug. The kind of booties that fasten with velcro on the sides are a lot easier to manage.
