Advertise on Bikeforums.net
Results 1 to 5 of 5
  1. #1
    Join Date
    Oct 2002
    Location
    Boston MetroWest
    Posts
    273
    Shorts suggestions
    I'm doing a sprint triathlon in June...don't foresee doing many more. Water will be cold...air will be warm. Will use a wet suit.
    What should I wear under wet suit? Do people strip down and put on new shorts for the bike/run, or just peel off wet suit to reveal what's underneath? Any particular suggestions for shorts?
    TIA
  2. #2
    TriBob
    Guest
    No stripping during a race.
    For a sprint you could use your swimsuit. A lot of people do. If you think you will need some padding checkout http://titanwear.com/
  3. #3
    Junior Member back bacon's Avatar
    Join Date
    Feb 2004
    Location
    Canada
    Posts
    12
    [QUOTE=TriBob]No stripping during a race.
    TriBob, do you mean no stripping during a race because it is slow or because its not in good form. I've seen it, and not just guys. I don't know about the stripping racer but it definitely slowed me down!!!!!! ( I knew I shouldn't have looked!!)
  4. #4
    Member Ratface's Avatar
    Join Date
    Dec 2003
    Location
    Gothenburg, Sweden
    Posts
    34
    The normal rule is that nudity in the changing area will result in disqualification, though it does happen occassionally.
    I use an all-in-one tri-suit with a light padding in the butt for the cycling. It dries out quickly enough on the bike, though like everything else in triathlon it takes a little getting used to. I would recommend practising your swim-run transition at some point to get used to changing when wet (things like "should I take the time to put on socks?" get sorted out when you actually try it out).
    If you're not worried about padding, then probably best to cycle in your swimming trunks and just pop on a top after the swim.
    http://www.cookstour.org
  5. #5
    It's not easy being green FatBomber's Avatar
    Join Date
    Mar 2002
    Location
    Chicago
    Posts
    437
    I recommend Pearl Izumi's tri-shorts. They look like bike shorts, will not "bunch up" under a wetsuit, but they have a lighter pad and they dry out quickly. They usually run $50 or so and I have replaced my regular bike shorts with them because they are so darn comfortable.
    Never trust a limping dog or the tears of a woman.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
