Bottom Bracket tips?
Old 08-20-09 | 01:34 PM
So I've gotta get it done. Tips?
Which side should I start on, the left non-crank side, or the right crank side?
adlai is offline
Reply
Old 08-20-09 | 01:44 PM
Booger's Avatar
Bikes: KHS Flite 750
Parktool.com
Booger is offline
Reply
Old 08-20-09 | 01:45 PM
bikeman715's Avatar
Bikes: Bike Nashbar AL-1 ,Raligh M50 , Schwinn Traveler , and others
it doesn't matter as long the job get done.
bikeman715 is offline
Reply
Old 08-20-09 | 01:50 PM
I'm thinking I'll start on the non-crank side right now, since it might be marginally easier to get off. Also is cleaner overall.
This is gonna be a *****.
adlai is offline
Reply
Old 08-20-09 | 02:07 PM
bikeman715's Avatar
did you clean you chainring teeth like a good little boy ?
Reply
Old 08-20-09 | 02:26 PM
done! It wasn't that bad.
I used a piece of pipe as an extender for the wrench.
adlai is offline
Reply
Old 08-20-09 | 02:47 PM
how much should I tighten it?
adlai is offline
Reply
Old 08-20-09 | 02:54 PM
For most square taper and Octalink/ISIS cartridge bottom brackets the recommended torque is 50 - 70 N-m or 400 - 600 inch-pounds. That is VERY tight. A regular wrench won't normally approach it for most mechanics.
BTW, for most cartridges it doesn't matter which side you remove first. For Shimano cartridges with the plastic non-drive-side cup, remove the drive side cartridge first. Otherwise you stand a good chance of destroying the plastic cup.
HillRider is offline
Reply
Old 08-20-09 | 02:59 PM
Eh, my torque wrench goes up to like 900. Thanks for the tip.
adlai is offline
Reply
Old 08-20-09 | 03:00 PM
hey hillrider, I used to live in PGH.
It's a surprisingly bikeable city when you consider that it's in Appalachia.
adlai is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
