Advertise on Bikeforums.net
Results 1 to 6 of 6
  1. #1
    Join Date
    Aug 2009
    Posts
    4
    Help convert my MTB
    I have a Trek 4900 MTB with standard 26x2.1 tires I would like to put some slick tires on it for urban riding whats the thinest tire that will fit MTB rim? THANKS FOR THE INPUT EVRYONE!
  2. #2
    Pro Paper Plane Pilot wunderkind's Avatar
    Join Date
    May 2009
    Posts
    1,622
    My mtb used to have 2.0" tires. Now it is on 1.5" Kenda Kwest slicks. Works great. Highly recommend. It may go down to 1.25" too. But I want a bit of comfort.
    Vancouver Modern Portrait Photography
    Zenfolio.com membership discount code: UBV-HJY-SCY
  3. #3
    Last one to the top... Little Darwin's Avatar
    Join Date
    Jul 2005
    Location
    Wilkes-Barre, PA
    Posts
    6,652
    It depends on rim width... This page has a chart.
    http://www.bicycletires.com/a_49/tire_width/article.htm
    There is also a formula, but I don't recall what it is... You can probably derive it from the table here and/or Sheldon Brown's site. It is like tire width = rim inner width * 1.x Where 1.x is a ratio... a different ratio for minimum and maximum.
    People do not seem to realize that their opinion of the world is also a confession of character.
    - Ralph Waldo Emerson
  4. #4
    Come here often? <wink> exile's Avatar
    Join Date
    Mar 2008
    Location
    West Chester PA
    Posts
    2,770
    I have Specialized FatBoys on my commuterized Mountain Bike. They are 1.25x26 slicks and up to 100psi. They are not the most comfortable tires i'm sure but definetely very fast.
  5. #5
    Senior Member meanwhile's Avatar
    Join Date
    Jun 2008
    Posts
    3,522
    As you've been told, it depends on the rim width.
    Also, tyre speed isn't related as strongly to width as people think - or even in the way that most people think. Read the tech docs on Conti and Schwlabe's sites.
    The best MTB slick at the moment is probably the 1.5 Rubino Pro. It's made of real racing tyre rubber and has much more wet weather grip than the Fatboy, which is about as fast. Conti Sport Contacts are worth considering if you can't get the Rubinos.
    Other thing that you probably haven't been told: inner tube quality and talcing have an effect on rolling resistance also.
  6. #6
    aka Phil Jungels Wanderer's Avatar
    Join Date
    Apr 2005
    Location
    North Aurora, IL
    Posts
    4,217
    A general rule of thumb is 1.5 times the narrowest portion of the inside of the rim sidewall. If it measures 1", 1.5" tires will be fine. If it measures 22mm, 32 (or 1 1/4) would be about the smallest I would put on.
    Get out your calipers, or ruler.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
