Advertise on Bikeforums.net
Results 1 to 8 of 8
  1. #1
    Senior Member Drakonchik's Avatar
    Join Date
    Dec 2005
    Location
    Pacific Northwest
    Posts
    668
    Are SRAM RIVAL 2010 Shifters Compatible w/SRAM mtb Derailleurs?
    Are SRAM Rival/Force/Red brifters compatible with any SRAM mtb derailleurs? I ask because I'd like to run a SRAM 10 speed drivetrain with 11-30-something rear cassette. So I need a derailleur that can handle a cassette with a max cog of 30-something teeth and at the same time be compatible in terms of cable pull.
    On a side note I gather that 10 speed SRAM, Shimano, and Nashbar etc aftermarket 10 speed cassettes are all interchangable.
    To put the question another way: what do you do for a rear derailleur if you want to run a full SRAM drivetrain & shifters on a cyclocross bike having a standard or compact road double crank? Where the rider in question most definitely wants to run a rear cassette of at least 30 max teeth?
  2. #2
    Join Date
    Mar 2007
    Location
    Louisville, KY
    Posts
    469
    You can get the SRAM XX mountain bike derailleur. It will take the 30 tooth you are thinking about. I believe it will take up to a 36. I am sure someone will corect me if I am mistaken.
  3. #3
    cab horn
    Join Date
    Jun 2004
    Location
    Toronto
    Posts
    28,380
    Someone back me up on this sram road uses 2:1 while the sram mtb stuff uses 1:1 therefore not compatible. You can use a shimano sgs derailleur if you want to run something up to a 34t.
    Mes compaingnons cui j'amoie et cui j'aim,... Me di, chanson.
  4. #4
    Join Date
    Sep 2004
    Location
    boston, ma
    Posts
    2,322
    sram road uses 1:1. i am not sure if the mtb derailleurs will be compatible. if the road and mtb stuff is compatible it wouldnt be too much for the mtb derailleur to take a 36t cog
  5. #5
    Join Date
    Sep 2004
    Location
    boston, ma
    Posts
    2,322
    well you can use the sram xx rear, the xx cassette and 10 spd road shifter http://velonews.competitor.com/2009/...d-parts_100789 i also saw a cx bike with xx stuff on it, dont remmber where and im still looking for it
  6. #6
    Arsehole PlatyPius's Avatar
    Join Date
    Jul 2008
    Posts
    2,312
    SRAM road and MTB both use 1:1 as far as I know.
    From the Road area:
    Exact Actuation
    When we launched our road technology from scratch we reapplied our MTB proven SRAM 1:1 actuation ratio (shifter cable travel : derailleur movement) for 10 speed rear shifting. EA helps to simplify/stabilize the uneasy act of balancing rear derailleur hanger design, tight cog spacing and exact cable tension. The result: the easiest index shifting system to set up and it stays that way.
    Products That Use This Technology
    From the MTB area:
    1:1 Actuation™
    1:1 Actuation™ is simply superior. The very nature of its design makes it this way. For every 1 unit of cable pulled or released, the derailleur moves the same amount. Simple? Yes. Dependable and tolerant? The best. Ease of set-up and adjustment? Easiest. This is why the top athletes in the MTB world prefer SRAM. From the mud infested Cross Country of the Sea Otter Classic, to the rocks and roots of a Fort William World Cup Downhill the 1:1 actuation stays precise and fluid. 1:1 Actuation precision is why you find SRAM on the elite bikes from cross-country flyers to full gravity bombers. 1:1 • Setting the shifting standard!
  7. #7
    Join Date
    May 2004
    Location
    Wilmington, DE
    Posts
    8,284
    This was discussed in another thread a while back and I remember the conclusion was that XX deraillers will work with the SRAM road shifters but previous SRAM MTB rear deraillers will not. I have never experimented with anything SRAM so I can't confirm or deny any of this.
  8. #8
    cab horn
    Join Date
    Jun 2004
    Location
    Toronto
    Posts
    28,380
    Quote Originally Posted by joejack951 View Post
    Oh actually I DO remember that thread. The OP said he had contacted SRAM and said that even though they were compatible on paper the pull ratio was actually slightly different between road/mtb group. I'm not quite sure I believe that but that was apparently the official word.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
