Problem with SKF bottom bracket
Old 11-22-10, 02:49 PM
Hi all,
I have a movement in the axial of the bottom bracket. It's an SKF and I think it's sort of sealed BB. I wanted to remove it so I cut the "cap" so it end to this.
I don't know how to manage this kind of BB. I have a city bike, a Batavus.
I attached some photos.
Thank you in advance
File Type: jpg
File Type: jpg
File Type: jpg
brebe85 is offline
Old 11-22-10, 03:38 PM
Quoted: 1074 Post(s)
Liked 295 Times in 222 Posts
The LH side of a cartridge BB is just a centering ring, the structural assembly and removal is from the RH (drive) side.
dabac is offline
Old 11-22-10, 03:43 PM
just pokin' along
desertdork's Avatar
Quoted: 11 Post(s)
It looks like those are sealed bearings that were pressed into the [unthreaded] bottom bracket shell. Actually, you can see the word "pressed" on the plastic seal you removed. To remove the bearings would probably require striking each axle end with a hammer and something to protect the axle ends (if salvageable and reusable).
The bearing cartridge does look to be in bad shape. If the axle is serviceable, you then need to determine if there's a source for replacement bearings and a shop (or other means) to press them in. Additionally, your chainring appears fairly worn. Ugh! This could be a costly or troublesome repair.
Perhaps some posters on the Vintage or Utility Cycling subforums have dealt with this type of bottom bracket.
desertdork is offline
Rubato
Bicycle Mechanics
5
04-01-17 11:17 AM
chiproth99
Bicycle Mechanics
2
02-20-17 04:56 PM
rimbo
Bicycle Mechanics
44
05-03-13 09:35 PM
cutter57
Bicycle Mechanics
4
07-31-12 01:58 AM
bikejack
Bicycle Mechanics
8
01-28-11 08:35 AM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
