Advertise on Bikeforums.net
Page 2 of 2 FirstFirst 12
Results 26 to 49 of 49
  1. #26
    Senior Member swc7916's Avatar
    Join Date
    Sep 2007
    Location
    Machias, WA
    Posts
    682
    These are the cantilevers on my tandems. They are the best and easiest-to-adjust I have ever used.
    (This photo was taken when the bike was just built and the brakes were not adjusted yet.)
    2011 Rodriguez Rohloff tandem
    2008 Rodriguez Rainier Lite sport/touring
  2. #27
    Senior Member GrayJay's Avatar
    Join Date
    Sep 2009
    Location
    EagleRiver AK
    Posts
    1,045
    Looking at pictures of the Avid Ultimates (Velonews review), it looks like the narrow position is around 30° cantilever angle (As defined by circleacycles paper) and the wide position is around 88° (arms angled 12° above the horizontal line between the mounting post) so a difference of 58° between the two postions. These "measeurements" are just from pictures and probably represent resting brake position the more meaningfull measurements would be taken when pad contacts the rim so are probably a bit narrower. Actual angle would also depend on individual placement of the cantilever mounting stud on the frame (narrower width between post yields increase in cantilever angle).
    Looks like thar PA arm length is around 1.3X the PR length.
    Rough calculation of the mechanical advantage would be around 3.2 for the narrow and 2.1 with the wide stance (with low saddle cable) but the MA of the narrow stance setup falls off really fast as the brakes are actuated and the cable hangar is raised. Avid says that narrow stance is 20% more braking force.
  3. #28
    Senior Member meanwhile's Avatar
    Join Date
    Jun 2008
    Posts
    3,522
    Quote Originally Posted by swc7916 View Post
    I've heard of these - they're Rodriguez Elephants???
  4. #29
    Join Date
    Jun 2008
    Posts
    3,522
    Quote Originally Posted by GrayJay View Post
    Thanks - didn't Zinn like these a lot? The price of a pair (ie enough for one wheel) of ASUs in the UK is an insane $145, btw!
  5. #30
    Team Water Andy_K's Avatar
    Join Date
    Jan 2008
    Location
    Beaverton, OR
    Posts
    5,960
    A couple of minor editing comments...
    Quote Originally Posted by meanwhile View Post
    2. Single speeds and bar con bikes can get easy compatibility by using v-brake road levers
    Special v-brake compatible drop bar levers are available. These will work directly with standard v-brakes and disc brakes. These levers do NOT include shifter controllers, but if you're riding singlespeed or with bar cons they may be a good choice.
    This is misplaced in the mechanical advantage discussion. It should be moved to the V-brake section.
    1. The ultimate reference and other useful links
    Squeal and judder:
    http://velonews.competitor.com/2010/...o-cross_101807
    You've got this in there twice.
    Also, there's nothing on link wires vs. straddle cables in the current main post.
  6. #31
    Join Date
    Jan 2008
    Location
    Beaverton, OR
    Posts
    5,960
    It occurred to me this morning that a section on brake levers and hand position might be beneficial, particularly for people with small hands. Here's my first try at it. Pictures might help here.
    X. Brake levers and hand position
    As their name implies, brake levers use leverage to translate hand force into braking force. Your actual leverage will vary depending on where you squeeze the lever. For instance, if your hands are on the brake hoods, you may be applying your hand force very close to the pivot point of the brake lever, particularly if you have small hands. This will result in much less braking force than you would have if you squeeze the lever closer to the end, as you would when riding in the drops. Much of the perceived difference in braking power between V-brakes and cantilever brakes may be attributable to this difference in leverage.
    Cross levers provide another option which allows you to utilize greater leverage than you may get when braking from the hoods, while still allowing an upright riding position. You will have better control over the bike, particularly at high speeds, when braking from the drops than when using cross levers, but for some situations such as coming to a stop in traffic, the cross levers offer an excellent alternative.
    If you have small hands, you may have difficulty reaching the brake levers when riding in the drops. Shimano STI levers come with a reach adjustment pad that can be used to set up the brake lever closer to the bars. This pad effectively reduces the travel of the lever by having it partially pulled in the rest position, so it offers no advantage when you are braking from the hoods, but it can help with braking from the drops.
  7. #32
    coprolite fietsbob's Avatar
    Join Date
    Jun 2010
    Location
    NW,Oregon Coast
    Posts
    25,594
    one addition to the Type of calipers , is a category long a part of classical Mechanics,
    where the fulcrum, or pivot is..
    Type 1 .. Mafac and many subsequent L shaped calipers,
    the work (brake pad) and the effort arm (ends where the cable fittings are)
    are on opposite sides of the pivot..
    U brakes are also of this type lever.
    Type 2 .. V and low profile calipers , the pivot is on the end,
    the work being done is between the fulcrum, and the end of the effort arm .
  8. #33
    Senior Member nayr497's Avatar
    Join Date
    Nov 2004
    Location
    Nilbog
    Posts
    1,392
    This is awesome! Never come across it but wish I had read it before my first season of cross racing
    I have a question about brake pads - how do I tell (by looking? or do I need to pull them?) what type of brake pads I need? I'd like to replace them on each of my cross bikes.
    One set of brakes is the Tektro Oryx with stock pads. Here is that brake:
    http://www.jensonusa.com/Tektro-Oryx
    The other brakes are some FSA SL-Ks. Here they are:
    http://www.universalcycles.com/shopp...s.php?id=32394
    I'm trying to figure out which type of Kool Stop pads/holders to go with. Smooth:
    http://www.biketiresdirect.com/produ...st-pad-holders
    Or threaded:
    From looking at the brakes and the photos of the holders/pads it would appear that both are threaded. But, I'm not positive. Sorry, I'm sure this is an dumb question but I don't have much experience with cantilever brakes, but I am getting better!
    On a related note, a dude I know who used to work as a mechanic and knows his stuff told me I'd need a cross/connecting wire for the rear FSA brake made by FSA. He couldn't really tell me why. I needed one before a race and tried just any old brake cable. It worked and has been working just fine.
    Was he just trying to give me a hard time or could there be some merit to this?
    Deda Newton Anatomic bars/40cm
    Pls. PM me if interested, trying clear out parts bin!
  9. #34
    Join Date
    Nov 2004
    Location
    Nilbog
    Posts
    1,392
    Any help, anyone?
  10. #35
    Team Beer Cynikal's Avatar
    Join Date
    Apr 2004
    Location
    Sacramento CA
    Posts
    5,551
    You want the threaded style pad for both those brakes. Get the short ones like you posted and not the longer vbrake type. They will clear the fork blade better.
    I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
  11. #36
    Join Date
    Jun 2010
    Location
    NW,Oregon Coast
    Posts
    25,594
    Yea there are road insert, short tail pad holders for Cross setups
    with V brake type bolts on mounts .. to have the spherical washer set going on.
    that is what these are: http://www.biketiresdirect.com/produ...st-pad-holders
  12. #37
    Join Date
    Apr 2004
    Location
    Sacramento CA
    Posts
    5,551
    My only gripe with the koolstop holders is that the bolt is too short. I had to replace mine with longer bolts.
  13. #38
    Join Date
    Jun 2010
    Location
    NW,Oregon Coast
    Posts
    25,594
    Before the big Taiwan factories picked up the idea and mass conmsumer-ized it
    the Race mechanics just sawed off the long tails of the Available pads.
  14. #39
    recovering californian bigbenaugust's Avatar
    Join Date
    Feb 2005
    Location
    KIGX
    Posts
    1,386
    I love this thread. I think I got Z-link cables a touch too long for my Tektro Oryx cantis.
    --Ben
    2011 Motobecane Fantom Cross Uno, 2009 Motobecane Fantom CX, 2011 Windsor Shetland (prototype)
    Previously: 2000 Trek 4500 (2000-2003), 2003 Novara Randonee (2003-2006), 2003 Giant Rainier (2003-2008), 2005 Xootr Swift (2005-2007), 2007 Nashbar 1x9 (NB-SF2 frame)
  15. #40
    Join Date
    Nov 2004
    Location
    Nilbog
    Posts
    1,392
    Cool, thanks for the help folks!
  16. #41
    Join Date
    Nov 2004
    Location
    Nilbog
    Posts
    1,392
    Has anyone tried the Frogglegs cantis? Hard to find much info on them...or anyone who has even heard of them or tried them.
    http://www.probikekit.com/us/compone...dard-pads.html
    I have some Tektro Oryx cantis on a cross bike and they aren't so great. But...could just be the stock pads, which have worn extremely fast. I either need to replace the pads or I could just try the Frogglegs. Those brakes + pads would be about the same price as just Kool Stop pads + holders. But I might be back to square 1 if those stock pads are junk.
    I wonder if it's a lateral move to go from the Oryx to the Frogglegs? Thoughts?
  17. #42
    Join Date
    Jun 2010
    Location
    NW,Oregon Coast
    Posts
    25,594
    TRP copied the Empella Frog legs, Their EuroX, now from TW.
    http://www.cyclocrossworld.com/cyclocross-brakes
    Note the shape, face of edge towards center, .. convex arch..
    I tried the originals , but since my fork bosses
    were too close together , I re-sold them.
    found the Belgian Spooky calipers, close out, they lost market share too.
    like old Mafac/Modolo Cantilevers
    their concave shape lets me rotate the shoe down,
    so they work with my old fork.
    the Ridley 4ZA may have worked too..
    Note you are changing to a lower MA caliper, benefit is:
    it will let you run with more clearance, pad to rim,
    for muddy courses. before the muck builds up..
  18. #43
    Join Date
    Sep 2009
    Location
    EagleRiver AK
    Posts
    1,045
    I recently got some older 4ZA branded cantilevers, exact same design as Empella Frog legs & EuroX. What suprized me about the design that all these high-end CX brakes utilizing pads with unthreaded post is that the brake has no provision for adjusting pad toe other than bending parts. There are unthreaded post brake pad holders that utilize removeable pads and which have provision for toe adjustment built into the pad holder, probably a very good idea if you are using this style brake, dont cheap out and get the lower end models that come without adjustable & replaceable pad holds.
    Other alternative option for wide stance brakes to consider are those like the Kore Kross and Teckto 720 which use threaded post pads and are easily adjustable for toe with concave washers.
  19. #44
    Join Date
    Apr 2004
    Location
    Sacramento CA
    Posts
    5,551
    If you want those brakes buy these pads to go with them. I did this with a set of orgin8's cantis and they worked great.
    http://store.velo-orange.com/index.p...ree-shoes.html
    Not bad for $18.
  20. #45
    Join Date
    Nov 2004
    Location
    Nilbog
    Posts
    1,392
    Ah, so now I realize the Frogglegs have an unthreaded brake pad post. Is there a pro/con of threaded/non-threaded?
    I'm trying to figure out the best (and most cost-effective) way to improve my braking situation. I have some Tektro Oryx brakes on one of my cross bikes, used mainly for around-town/rain day road rides. I'll likely never race it, as I have a cx race bike. Mud clearance not much of a consideration.
    The stock pads are well worn. I'd either like to get some Kool Stop pads/holders or the Frogglegs. The price would be about the same for either. I just wonder if they Oryx are so bad that I should consider new brakes. They're paired with Shimano 5700 shifters. The set-up seems to be pretty good, just really poor stock pads. (but never used them with nice pads, so really can't be sure)
    Good to know, Cynikal regarding the pads. I guess right now I'd rather just get new pads or get the Frogglegs. But if the FL pads are awful, I'm back to square one.
  21. #46
    Join Date
    Nov 2004
    Location
    Nilbog
    Posts
    1,392
    In reading back through this it seems that you are saying the Frogglegs are unthreaded and don't in fact have any provision for toeing in. And the pads/posts are not replaceable. Hmm, since my Oryx seem to work okay and I know they fit my fork/bike...maybe at this point it would be best to just grab some of the nice Kool Stop pads.
    And, this bike isn't raced or really even ridden too hard, but some road rides in the rain. Would still like the brakes to work well, but not exactly a high-perfomance bike or anything.
  22. #47
    Join Date
    Jun 2010
    Location
    NW,Oregon Coast
    Posts
    25,594
    Back in the day of Mafac cantilevers, and Modolos, for toe in,
    we would just bend the post in relation to the shoe holder..
    TRP also has an in-place angle adjustable brake shoe ,
    though that VO one is cheaper. (+shipping)
    Mafac cantilevers, with the Plain post , work well on touring forks
    which have the bosses set up fairly closely spaced.
    Shoe/post gets rotated downward, relative to the part,
    as the posts get closer together.
    Built a touring bike frame and fork in the 70's
    The first brake adjustment
    was where I put the brake bosses on the frame.
  23. #48
    Join Date
    Sep 2009
    Location
    EagleRiver AK
    Posts
    1,045
    Quote Originally Posted by nayr497 View Post
    Wide angle brakes (Such as frogleggs) inherently have less mechanical advantage than a narrow angle brake such as the Oryx. The post/pad is definitly a replaceable item apart from the cantilever arm. With most cheaper pads, the post is permanently attached to the pad and you just replace the entire post+pad. Nicer systems use cartridge holders to hold the replaceble pad, re-use the post, some of these have the benefit of toe-adjustment.
    The main benefit of wide angle brakes is better mud clearance because the pads can be setup further from the rim. Unless you are racing mud or just prefer the classic look of wide angles, I wouldnt necessarily recommend them in order to improve braking. If setup with good pads and proper (low) position for the yoke cable, your Oryx brakes will be able to generate more braking force.
    With threaded post cantilevers (Using concave/convex mounting washers) it is usually easier to adjust pad toe, possible benefit of untreaded post brakes are perhaps a bit easier to make compensations for pad wear.
  24. #49
    Join Date
    Jun 2010
    Location
    NW,Oregon Coast
    Posts
    25,594
    A story I found on the background of the brakes I just bought, typically a late adopter,
    my wish was for aluminum, but Carbon was all i could find, on close out..
    http://www.cxmagazine.com/spooky-bra...-van-der-burgt.
    the Toe-In is resolved by TRP's Adjust in place Brake shoes/ plain post, holders..
    bolt runs through the post and there is a curved face that allows the shoe to be angled..
Posting Permissions
  • You may not post replies
  • You may not edit your posts
