Derailleur for 38t rear sprocket
No Money and No Sense
What derailleurs can handle a 38t rear sprocket?
I'm x-posting this with the Bike Mechanics forum b/c I'm pretty sure only Suntour used a rear sprocket this size, but I haven't seen anything matching up this crazy-big freewheel with a derailleur to handle it.
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
Suntour made an AG-Tech derailleur to go with the AG-tech freewheel: https://www.disraeligears.co.uk/Site/...erailleur.html . I'd bet that one of the newer derailleurs for 36-tooth cogs could make that shift.
Jeff Wills
Jeff Wills
The Huret Duopar had a large range, certainly up to 36 teeth, but don't know about 38.
https://velobase.com/ViewComponent.as...m=108&AbsPos=4
Quoted: 3811 Post(s)
Liked 6,711 Times
I was thinking Shimano Mega-range variants, but looks like that's designed to handle up to 34t.
Neal
Neal
I think this might be worth looking into: While their rated as 34t max, they seem to work on 36t just fine. I may be able to get a Tourney Mega-Range to fit over a 38t by replacing its giant pulleys with something normal-size.
spookeaymarine.info
Location: Me, I'm in Central Alabama C.S.A. But my husband is under the bed. He's sure there is a black helicopter orbiting our house.
Bikes: Schwin,Ross,Cannondale.
Bicycle Repair Man !!!
Capacity of a rear derailleur will be affected by the hangar length and bikes designed for wider range touring gearing or off roading have hangars that maximize the possible range of the derailleur.
The Suntour AG (Alpine Gear) and Huret Duopar have massive capacity and the new XT has a rated capacity of 36 and would probably handle 38.
Most long cage mountain derailleurs will handle 34 teeth as will many older GT models like the Cyclone and VX... but only if they have the right hangar.
I would probably have problems with the XT because it's for a 9-speed: I probably couldn't limit the the movement enough on the high end and it wouldn't work with a wide enough chain to fit the cogs.
I live in the Ozark Mountains, which has exactly two directions: Up and down. I've found I either need a granny gear or a high gear to ride around here, and the Suntour freewheel fit the bill while letting me go to a single chain wheel up front instead of using three wheels as I thought I'd need to originally.
Quoted: 765 Post(s)
Liked 660 Times
I use a Duopar with the same 38-tooth Suntour setup and it shifts very well--no problems. I've got a 45-40 in front for a super-wide-range double. Not much of a high gear, but I don't need one.
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
I'm curious why you need a 38t rear cog.
Bikes on Flickr
I prefer email to private messages. You can contact me at justinhughes@me.com
Bikes on Flickr
Freewheel Medic
Quoted: 1453 Post(s)
Liked 2,196 Times
Sometimes you just can't get low enough.
Bob
Bob
Liked 6,711 Times
That's the great-granny gear.
Neal
Neal
After putting different keywords in from this thread (yes, some of us do use search,) I uncovered this:
https://www.bikeforums.net/showthread...-5sp-freewheel
So, a Tourney would work as I thought, but it doesn't need smaller pulleys, it needs an extra spring to get it into place. Bonus for being readily available and cheap, rather than requiring me to hunt eBay.
Quoted: 967 Post(s)
Liked 1,631 Times
I hang out on my 34t gear more than I would like to admit so I can see where you are coming from on needing 38t - Consider welding a hangar onto your dropout and make a little lower to give you more room for your large gears - Then you could possibly use a regular long or medium cage dérailleur... Its a thought...
Frame did not have a derailuer hangar and the SIS bolt on hangar was just way to bulky - Cut off the top of the hangar to line up along the bottom of the drop out and tig welded it in place - A little grinding and done... SIS bolt on derailuer hangar $5.48 - Local Bar-B-Q pit builder welder 6 pack beer... All cool...
Quoted: 765 Post(s)
Liked 660 Times
Get old and go live in some mountains and it will become clear to you, I think.
--Ogden Nash
--Ogden Nash
spookeaymarine.info
As a matter of fact the closest thing to me is a sawmill. While you city slickers complain about unaware drivers, my only cause for concern is logging trucks and the occasional doofus hunter of a 4x4.
I understand the need for low gearing. A 38t rear cog is not how I'd go about getting it.
Really? I mean, if your gear is much less than 1:1 you can walk the bike up the hill about as fast as you can ride it, correct?
Bikes on Flickr
Bikes on Flickr
Just threw a 26 tooth granny into my Trek to go with the 30 in the rear but plan to swap out the 11-30 cassette for an 11-34 to give me a 20 gear inch low for some mountainous touring.
For a single bike the only time I would need that is when I am mountain biking and my mtb has a 22/34 low gear (16 gear inches) and will go straight up walls with that gearing.
Conversely... I can climb pretty much anything on my road bike that has a 40 gear inch low but it only weighs a spec over 20 pounds, carries nothing, and does not see such extreme grades.
Should I mention that I don't have 100% use of my left leg and have to be able to sit and spin up any climb as I cannot stand and hammer the pedals like I should.
There was a time I could go up most things with a 1:1 gearing.
Went to pick up the freewheel from my friend, pulled it out of the (rather large) box...28t max.
I've started my search for alternatives. Does anyone know when/why Shimano made freewheels with what appear to be skipchain cogs for the highest two cogs? Is there any reason to avoid Maillard aside from the odd-sized freewheel splines?
Or is it just time to cold-set the frame to 6-speed spacing and be done with it?
I have a mountain bike with 1:1 gearing and the limiting factor is how long I can spin: On some dirt roads even a brief pause would find me rolling back down the hill. It's still about running pace, which wouldn't be all that realistic on a steep hill anyway.
Perhaps you could search eBay or post a WTB in the sales forum for a freewheel. I know Suntour made a 14-34t 5 speed freewheel. I have one, but it's earmarked for a friends 1x5 city bike build.
Bikes on Flickr
Bikes on Flickr
Quoted: 809 Post(s)
Liked 712 Times
IRD offers a 5-speed 13-32 freewheel: https://store.interlocracing.com/fr76and5sp.html . Not particularly cheap, but probably better than a 30-year-old parts bin denizen.
Jeff Wills
Jeff Wills
