Advertise on Bikeforums.net
Results 1 to 20 of 20
  1. #1
    No Money and No Sense sillygolem's Avatar
    Join Date
    Sep 2010
    Location
    Anderson, MO
    Posts
    705
    How to convert 10sp and freewheel-equipped bikes to SS/FG
    Kilo TT
  2. #2
    Join Date
    Mar 2011
    Location
    In a crate
    Posts
    374
    My Own Opinion:
    I think you have it too wordy, I find myself skipping somethings and getting loss.
    It would be nice to have a checklist for what that is on the 10 speed should have. Like this:
    -tapered crank
    -preferred cable stays are non-braze-ons
    -horizontal drop outs
    -so on
    A parts list would be nice, with some options. Here was my last build:
    -1/8 chain - neon green
    -16 tooth freewheel for single speed
    -Tapered crank bolts - shorter for single gear ring
    -Freewheel tool
    about $40
    I like your Q&A section and how you address some concerns.
    Final opinion:
    More pics. We are like children, because you have some nice pictures, take more pics about everything you talk about so it's easier to understand. I see this flaw in everything, yet it is still well worth it. Saves a noob some time at a LBS trying to rack up enough courage to say something stupid or to find the part they can't remember.
    Sorry to say all this, just this is a good guide I wish I had when I was making my first SS. Just trying to clear up your clutter and add more pictures. I wish I could take pictures of my projects, my camera sucks.
  3. Support our Sponsors:
    Bike Carrier Direct: Bike Racks from major manufacturers with 200% Low Price Guarantee and Free Shipping on All Bike Racks.
    http://www.bicyclewheels.com Best deals in Hand Made in The USA Wheel sets for Fixie-Mountain-Road and Track Bicycles.
    www.bikesdirect.com - Brand Name Bikes SAVE up to 60%
    Official Strida Website
    Shop JensonUSA.com for mountain bike parts, apparel, and accessories.
    Advertise on BikeForums.net. Email the sales department at sales@bikeforums.net for more details.
  4. #3
    Hey Mah, watch 'DIS! Dannihilator's Avatar
    Join Date
    Oct 2002
    Location
    Annandale, NJ.
    Posts
    14,339
    My honest opinion is that too much thought is being put into this, making a conversion is not all that complicated of a thing to do.
    Remove your deraillieur cables
    Remove your shifters
    Remove your derailliers
    Remove wheels(easier to work on with both wheels off.)
    Cut chain
    Remove chainwheel if you have a one peice and put on a single chain wheel or if you have 3 piece remove chainrings select a ring you want to use and get a set of single chainring bolts then put said chainring and bolts onto the crank.
    Get freewheel removed
    Take said wheel if SS throw a SS freewheel on and your good to go. If fixed, if you have a fixed wheelset put cog and lockring on and you're set.
    If you don't have one, leave the brakes on the bike, thread on cog tightly then thread on a bottom bracket lockring on. Until you can get a dedicated Fixed wheelset, don't skid and use the brakes instead. If you back pedal or skid on that setup it is very easy to strip the hub out.
    Then put wheels back on the bike, followed by the chain set a good chain tension. Rule of thumb is good tension is 1/2" depress on either side of chain.
    The look at the chain line. A good chainline should be exactly perpendicular to the bb spindle. On a bike with a chain wheel, you don't get much adjustability in setting chainline. Three piece, you can change out bb to get a desired chainline. On either you can also space the cog out a bit if you have the room on the hub.
    Then go over it and make sure everything is tight then go out and enjoy.
    Pfft, I probably just put too much thought into this.
  5. #4
    Join Date
    Mar 2011
    Location
    In a crate
    Posts
    374
    Well, Dannihilator, there is also the:
    -Aligning hub and axle so that the chain is kept straight
    -Aligning the brakes to move and pinch at the right time and distance
    -Setting the distance bolts in the drop out (Can't live without them)
    -The usage of not using a chain tensioner (I don't, my bike is set up that way)
    -the thoughts between 3/16th or 1/8 inch chains and gear fitting
    -The Fixie set up so someone doesn't die or get their legs ripped off
  6. #5
    Join Date
    Sep 2010
    Location
    Anderson, MO
    Posts
    705
    Quote Originally Posted by Dannihilator View Post
    It's a lot easier after you've done it, but there are always little niggling questions that get asked a lot. Then there are things that you just happen upon with no explanation: I didn't know about the two Shimano freewheel sizes until I got the bike and realized none of my adapters fit it and unless you -know- about this you'd think you got something really weird.
  7. #6
    Smang it. EpicSchwinn's Avatar
    Join Date
    Feb 2011
    Location
    Spoke can
    Posts
    1,756
    Nice detailed write up. Idk about promoting suicide fixies though. Sure you're running brakes but I think running a suicide hub is selling yourself short on the fun fixed gear experience (constant ominous possibility of unthreading your cog and lockring.)
    When I did my conversion I just got a cheap rear wheel with a flip flop hub. It was about $60 for the wheel and $20 for the cog and lockring so it still doesn't break the bank (I have upgraded since then though). IMO, going the right way from the get go will leave one with a much more enjoyable bike.
    2011 SOMA Rush2011 Dawes Deadeye1987 Schwinn Traveler
    Quote Originally Posted by cinemattic View Post
    "fixie" sounds like a toy. say, from wal-mart... "fixed-gear" makes it sound like a tool. like "circ-saw"..
    Quote Originally Posted by Scrodzilla View Post
    A lot of people buy Nickelback albums too. That doesn't make them good.
  8. #7
    bedazzled fingernails Ultraspontane's Avatar
    Join Date
    Jul 2009
    Posts
    378
    I disagree. The more detail the better. Some of us like doing things correctly instead of just winging it.
  9. #8
    Join Date
    Oct 2002
    Location
    Annandale, NJ.
    Posts
    14,339
    Quote Originally Posted by Ultraspontane View Post
    I've done it enough that it's second nature.
  10. #9
    Join Date
    Oct 2002
    Location
    Annandale, NJ.
    Posts
    14,339
    Quote Originally Posted by BotByte View Post
    Keeping chain straight: chainline.
    A 10 speed frame wouldn't generally need a chain tensioner since it has horizontal drop outs.
    Size of chain should be up to the person who's converting it. Which is why I did not go down that road, everyone has their preferences.
    There's not much that can be done on a road brake other than mess with the brake pad positioning and cable tension, should be apparent right from the get go. I tend to prefer a really firm feel to the brake lever, but still have ample enough distance between the brake pads and rim in case something happens and knocks the wheel out of true, it can easily be limped home.
    Chaintugs: Hate the ones on my 930 and can easily live without them.
    The should be setup so someone doesn't die or get their legs ripped off, I agree. I mentioned the suicide hub thing but I also stressed keeping the brake on there and would still recommend getting a proper wheelset if going fixed over a suicide hub setup just safer and should have mentioned a sensible, gearing if new to fixed gears.
    To sum it up, I should have remembered that stuff last night, but a tired mind hindered me and plum forgot, wound up not putting enough into it.
    When I converted the 930, I intially kept the rear brake on until I got used to the bike as a fixed gear, then and only then when I got used to it, I ditched the rear brake. I put the rear wheel where the previous wheel had been so I didn't have to adjust the brake at all. Just plain old got lucky with the chainline. My first was a conversion, and was a total headache converting, probably why I strongly dislike schwinns.
  11. #10
    Join Date
    Sep 2010
    Location
    Anderson, MO
    Posts
    705
    Bump from the grave!
    I've got some spare time now, so I'm working on this again.
  12. #11
    Join Date
    Jun 2011
    Posts
    8
    Thanks for bumping this up. Y U NO STICKY?
  13. #12
    Join Date
    Sep 2010
    Location
    Anderson, MO
    Posts
    705
    Quote Originally Posted by zackae View Post
    Because I'm not a mod. Maybe if I add a section on properly rolling up one pant leg the mods will notice.
  14. #13
    Foward Leaning Attitude rithem's Avatar
    Join Date
    Mar 2005
    Location
    RHODE-MF-ISLAND
    Posts
    703
    also ...if you change the axel position you have to re-dish the wheel, equal and opposite reaction applies
  15. #14
    Senior Member dontpassthefenc's Avatar
    Join Date
    May 2011
    Location
    East Valley, AZ
    Posts
    125
    I almost forgot that this very thread is what popped up in my first google search on converting my old busted schwinn nearly 6mo ago. After reading the whole thread, I found it wasnt that hard at all to convert my le tour. Thanks to you, sillygolem, Ive been riding fixed for months and loving it.
  16. #15
    Join Date
    Apr 2009
    Posts
    23
    I'd also like to drop this link for the more technical-minded ones in the group:
    http://forums.mtbr.com/showthread.php?t=373319
    If you know how to take the cogs off a multi-speed freewheel and have spares/junk freewheels to take spacers from, you can probably make a ghetto single-speed freewheel without respacing your hub.
  17. #16
    Join Date
    Sep 2010
    Location
    Anderson, MO
    Posts
    705
    Quote Originally Posted by WeirdOddity View Post
    Thanks! I've been looking for something like this to build a Megarange 5-speed. The link has been added to the guide.
    I ride fixed because I'm mad at my parents. **** you Mom!
  18. #17
    Senior Member Robofunc's Avatar
    Join Date
    Oct 2010
    Location
    St. Petersburg, FL
    Posts
    463
    I want to see someone weld the freewheel and keep the gears and derailleurs, making a fixed, geared bike.
  19. #18
    Join Date
    Sep 2010
    Location
    Anderson, MO
    Posts
    705
    *bump*
    If I'm going to have info on parts brands, I may as well add bikes, too. Maybe it will save some posts on C&V on "ultra-rare" department store bikes.
  20. #19
    Stupid filthy humans! mashtofu's Avatar
    Join Date
    May 2011
    Location
    Boise, Idaho
    Posts
    274
    Quote Originally Posted by dontpassthefenc View Post
    This thread is only two months old..
    You may call me Kerushii.
    PedalRoom / Twitter
    Help me fund my tour! >>Buy my stuff!<<
  21. #20
    Join Date
    Apr 2005
    Location
    Victoria
    Posts
    946
    Nice effort, here's what I used to figure all this stuff out:
    http://sheldonbrown.com/singlespeed.html
    It's all in there, along with work-arounds for almost any challenge you could have converting a bike.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
