Home built hitch and rack
Just a small project to make my bike a little more versatile.
The hitch, most of you have probably already seen. I've been adding a rack to it, getting ready to make a pair of pannier bags, and needed someplace to hang them.
Before the start of the addition:
Added the front posts:
Drive side view:
Attachment detail, how I stuck it to the rear triangle:
Adding the first of the top bars:
The front gusset:
Putting the rear gusset and legs together:
Drive side view:
The front gusset:
More of the rack build.
Legs and rear gusset ready to be installed:
Upper and lower side frame gussets installed:
Adding the deck. It is a piece of aluminum printing plate from the local newspaper press:
All done, for now. Had to remove the seat to pop rivet the front of the deck:
In the right lane
While the assembly that goes over the tire (isn't it just a rack?) looks impressive, what's the hitch like? One of the best designs is a ball that allows the trailer to move against the bicycle without tipping it. In this way, the trailer can tip over without affecting the bike.
I have a Burley hitch hooked up to my old trailer at the left rear wheel axle. The original hitch clamped on to the left chainstay. When the bicycle tipped over, or vice versa, everything went with it. With the Burly, the very modest looking plastic attachment allows the bike to move independently from the trailer.
Can you show us a picture of yours?
Sorry, thought i had this in that set.
Here is the swivel portion, soon to be replaced with a heim joint:
This is actually on the first prototype, which has been replaced by the second, pictured in the first posts in this thread.
The swivel is the only thing that I saved from the first, because it worked so well.
Bikes: Bianchi San Remo - set up as a utility bike, Peter Mooney Road bike, Peter Mooney commute bike,Dahon Folder,Schwinn Paramount Tandem
Personal preference, I think. I like my hitch point to be as low a practical.
The arraingement pictured moves in all three axis, allowing the trailer to swivel side to side, up and down and allows the bike to tilt relative to the trailer.
In the right lane
Heim joint? Is it like this? What's the advantage?
Similar to that, yes. Just this portion of it though:
The advantage is that there are less moving parts to wear, and the resulting tighter connection. Also less adjustment points that need to be maintained
Each of the bolts in my current swivel set-up require periodic adjustment/replacement due to wear. The heim should last a lot longer, and only need replacement when worn, hopefully after a period of years.
Quoted: 38 Post(s)
Liked 11 Times
I though the advantage of a trailer was to take weight off of the rear wheel?
Nice work on the hitch,looks nice and strong.
In actuality, loaded with 100+ lbs of goods, the tongue weight should be only about 10 - 15 lbs. The trailer wheels take most of the additional weight.
However, the single wheel type of trailer does put about half of it's load on the bike's rear wheel. That is the main objection I have to the single wheel, due wholly to my own not inconsiderable mass. If i can manage to get back down to my HS weight of 170, that would change the dynamics of the situation.
The only weak point in my design appears to be in the attachment to the rear triangle. When the testing of this prototype is over, in about 6 - 8 months, prototype 3 will most probably have a few design changes in that area. I am seriously considering having a local machine shop make some type of pillow block that will take the place of the weak clamps that I am using now.
Quoted: 38 Post(s)
Liked 11 Times
Instead of mounting to the frame with p-clamps,use 3/16-1/4 U-bolts to capture the tube from behind.Use the strenght of your tubing to your advantage,don't isolate it from you bicycle frame with little tin clamps.You can put rubber or whatever between.You'll have enough clamping force to crush the frame if you want.You'll have to tear the rear triangle off of the bike for it to fail.Simple,solid.
With a rod end(heim joint) you'll get roughly 30* movement total,depending on the bolt head,washers,ect.Should be fine for a trailer but they are not really designed for that type of movement.
https://www.lovejoy-inc.com/,you'll find what you need.You can find their stuff all over the net,been around for 100 years.You can get a small u joint or cv joint.They're the same price as a good rod end.For the big bucks,you can have stainless and needle bearings....Yeah!
Trailer Nut
Bikes: Viking Urban Trail. Schwinn Spoiler
Hi Charlie,
I haven't been on the forums in a while but while browsing I saw that you were thinking of upgrading your trailer hitch...
I saw a neat idea for a trailer hitch (that you might be interested in) a few days ago. I may adopt this method for my trailer(s).
Heres a couple of photos of it and a link to trailer & hitch...
Made from a steel tube and a swivel caster wheel.
LINK:https://www.instructables.com/id/SURF...ILER/?ALLSTEPS
As you can see it has all the movement a trailer hitch needs - Up - Down - Left - Right - plus it pitches (due to the swivel caster) allowing the bike/trailer to tilt when cornering.
I'll keep an eye on your build for any updates
Regards
Tom
Regards
Tom
thank you both for the compliments!
@ timtim2008: welding would save some weight, yes. however, if I recall some of the properties of aluminum alloys, would require a type of heat treatment to relieve stresses at the joints. Otherwise would be prone to cracking near the weld.
@ CrimsonEclipse: no, I don't work for Grumman, but I do understand their philosophy. "Anything worth doing, is worth overdoing".
As I don't have close access to a welder (Yet!) or annealing oven (welder access involves a 50 mile trip), most anything I do will be with screwed fishplates for now.
Not being a school trained engineer, I do rely on the local library and internet for materials properties.
I have been told that if I were to make a production model of this hitch/rack, I could easily sell them for $ 250 - $300 in places like St Louis or Kansas City. I'd venture to bet they would go over big in places like Portland OR as well.
@ Bosscat: Yes, that swivel looks like it would work rather well, but appears to require welding. Not that I can't weld, but as noted above, access is limited at this time.
I built this from scratch, no plans. I had a need, and some idea of how I wanted it to function.
I had tried the axle mounted hitch, and didn't like the restriction on right turns in close quarters.
The best hitch arrangement is actually a "fifth wheel" as used by heavy haul trucks. I didn't want my hitch that high, would be unstable with what I do. Next best is a low mounted ball hitch. This is patterned after that, with the extra freedom needed for a two wheel vehicle.
Made mostly from scrap I had laying around, leftovers from other projects.
