Advertise on Bikeforums.net
Results 1 to 4 of 4
  1. #1
    Join Date
    Mar 2009
    Posts
    57
    Re-using Tubular Tires
    What's you're experience with re-using tubulars - how many seasons can you get out of them?
    I ran some Challange Fango's last year - worked great all season. After storing them in my basement through the winter, the glue got weak. So, I peeled them off and re-glued them again for this season. I've read that you can get several seasons out of a good pair of tubulars- but how so? I wouldn't trust the glue for more than a season racing in the wet, north east, and wouldn't prying off and regluing again damage the cloth that you glue to the wheel?
  2. #2
    Team Beer Cynikal's Avatar
    Join Date
    Apr 2004
    Location
    Sacramento CA
    Posts
    5,551
    If they hold air and the tread still works then proceed as usual.
    I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
  3. #3
    Join Date
    May 2006
    Posts
    439
    Rip the tire off & re-glue.
    You shouldn't damage the base tape, most of the glue should be dried out by now & brittle. I take a butter knife to tire & rim to take some of the dry stuff off. After that, I apply a fresh layer to both and re-glue.
    Blue Axino
  4. #4
    Tiocfáidh ár Lá jfmckenna's Avatar
    Join Date
    Dec 2003
    Location
    The edge of b#
    Posts
    5,409
    I've found cross tubs to be much better than road tubs. I don't even mount road tubs anymore on 'spare' wheels because I find that the base tape gives way a lot earlier than the glue joint.
    Been racing on cross tubs for 7-8 years now and I do not see the same thing... have no idea why. I always use Mastik One, road and or cross. I only buy top quality tubs. I find Tufo to be the best for cross, the base tape is solid and you have no tube inside to worry about. I've got some FMB's that have been mounted for two years and they are still rock solid.
    Could be the original mount? You need to use a LOT of glue to mount cross tubs...
    If you don't talk to your cat about catnip, who will? =^.^=
Posting Permissions
  • You may not post replies
  • You may not edit your posts
