Pace line efficiency?
Maximus
When riders that are not familiar with the "system" get involved, it frequently turns into a cluster**ck.
What is this rotating paceline you all speak of?
A paceline doesn't rotate. An echelon does. Look at the illustration CDR posted. It's pretty clear.
If there is a crosswind then the number of riders in an echelon is limited by the width of the road.
Look at some of the Spring Classics. The race will break up into echelons in the strong cross winds and riders will fight to jump across the one closer to the front echelon and then try to fight their way in.
Artificial Member
Bikes: Retrospec Judd, Dahon Boardwalk, Specialized Langster
Maximus
and to this, as an echelon
ech·e·lon (sh-ln)
n.
1.
a. A formation of troops in which each unit is positioned successively to the left or right of the rear unit to form an oblique or steplike line.
The key is the riders are "pulling through" from behind. In a pace line with longer turns at the front the lead rider "pulls off" the front. Pulling through keeps the pace higher and encourages greater effort for a shorter period of time. This type of rotating paceline requires more concentration and teamwork. If done well with the right guys, the miles melt away.
Single paceline you lose the front person about every 20 seconds, so you lose half the distance. Disadvantage is that you're not sheltered when dropping back so typically the hardest effort is getting back into the paceline. Advantage is you have the most resting time. Better for surging type riders.
Bikes: 2010 Jamis Xenith Comp
Done properly, there's no effort - you slip into the line without chasing the last rider; once drafting, your pace increases to match the speed of the line without an increase in effort. It's difficult to master technically, but there's no increased physical effort in the manoeuvre.
haha, yeah. OP is right. fiery - you do need to accelerate, so there's some increased effort. maybe if you do it perfectly, that effort is very little, but it's still there. i've ridden in a rotating paceline with a small group for part of a race, and my legs definitely burned every time i had to make that acceleration. however, i think the energy you save from the aerodynamic advantage of the paceline far outweighs the energy you spend getting on that last wheel every minute or two.
I've seen geese but never ones riding a bike.
I'd pay money to see that.
Third example from the left, second from the right is a rotating paceline. I remember you called a rotating paceline an echelon in the Tour for the 41 thread one morning. The difference between the two would be the direction of the wind. I do agree they are similar and one can turn into the other as the direction of the wind changes.
I think, in my mind, what is different between a 'rotating paceline' and an echelon is that in an echelon you move to the front and then immediately to one side (based on wind direction) whereas in any kind of paceline each rider spends some time at the front and then pulls off to one side (based on wind direction).
I my experience an echelon is much harder to keep going because you need a certain skill level with ALL the riders wheras you can teach a monkey to ride in a paceline (minus the bloody surges
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Trek Marlin 6, Scott Sub 35, Kona Rove, Trek Verve+2
Bikes: Look 585
This depends on the strength of the individual riders. Stronger riders will normally pull longer, weaker ones less. The idea is to not pull so long that you tire and get dropped off the back.
Je pose, donc je suis.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Bikes: Tsunami road bikes, Dolan DF4 track
I'm not sure which book says it but one book on bike racing points out that all rotating pacelines are echelons - it's just the angle that makes people change what they call it. An echelon straight on is usually called a rotating paceline, but unless you're in traffic (i.e. group ride) or you're going head on into the wind, many rotating pacelines angle one way or another, if only from slight tire overlap.
I would say that properly done, there's a hell of a lot of effort. It's just that it's at a level that's manageable, recoverable, and repeatable for each rider in the rotation.
Bikes: CAAD9-6, 13' Dawes Haymaker 1500
I always used to think that pacelines were BS and there would be no advantage, But now I know. It makes a huge difference for me, especially because I am small compared to other riders so I get full advantage of their draft. It always fun................until it's your turn to take a pull.
Hammering in a paceline down PCH with a tail wind is the best feeling ever. It's just amazing.
kewlkevkev
Road Cycling
9
03-18-17 08:53 PM
worldtraveller
2
07-10-11 10:51 PM
TrainerMicDude
Road Cycling
5
07-26-10 09:58 AM
karjak
Road Cycling
72
01-10-10 03:57 PM
