Advertise on Bikeforums.net
Page 1 of 3 123 LastLast
Results 1 to 25 of 69
  1. #1
    pneu a' plat rootboy's Avatar
    Join Date
    Apr 2005
    Location
    Sand Spit East
    Posts
    4,319
    ~ Campy Nuovo Record on the Simplex dropout * Execution
    or, the forty year itch.
    Warning: lengthy content and many pics. I thought I’d post this description of the process in case anyone wanted to try this at home. If you find this account too wordy, skip to the pics.
    When I bought my first good bike, A Peugeot PX-10, in 1971, I had two criteria. It had to be light. And it had to be affordable. The two hundred and fifty bucks was about all I could swing at the time but I was planning a tour of the coast of Washington and Oregon with a friend so I wanted a light bike. I bought the Peugeot and my buddy bought a Gitane Tour de France. Not the best choices perhaps, for fully laden touring, but we wanted lightweight European bikes and couldn’t afford the fancy Italian and English bikes in the shops. The French bikes with their plastic derailleurs served us well but I still coveted those pearly silver Campagnolo derailleurs in the glass case at the bike shop. Those components were the prettiest looking things in the display case and they adorned all the best bikes hanging in the shop. I’ve had a thing for Nuovo Record ever since.
    I eventually saved up the $24.50 for a Nuovo Record derailleur, but it was a few more years before I had a bike it would fit on. I never mounted it on my Peugeot, but many guys did back then. As you know, the adaptation involved grinding on the Simplex dropout hanger and tapping out the hole, something that was beyond my abilities back then and against my better judgement even if I could do it. I happily rode that Simplex Criterium for many thousands of miles with no problems, but I was still intrigued by how to fit a Nuovo Record derailleur on to a French bike with a Simplex dropout. In fact, I still am. Last week, forty years later, I decided to tackle the project. I sold that Peugeot long ago but in a fit of nostalgia I purchased a purple Gitane TdF about twenty years ago and it is this bike that has provided the impetus for this project.
  2. #2
    Join Date
    Apr 2005
    Location
    Sand Spit East
    Posts
    4,319
    THE GOAL: To adapt a Campagnolo Record derailleur to a Simplex dropout, without altering the dropout hanger. Many old French bikes can be found that show the fix performed back then. Grind a stop into the outer circumference of the hanger and tap the hole to M10 x 1 mm. It got the job done, but it somehow ruined the integrity of the bike I thought. As we know now, it also degrades the collectibility of the these nice old frames. I was determined to come up with a method that wouldn’t harm the bike.
    THE CHALLENGES: As you know, the Simplex derailleur is held onto the hanger with a M6 X 1 shouldered bolt with a 5 mm hex drive, from the rear of the dropout. The Campagnolo is attached with a threaded bolt. The adaptation required me to make a new bolt to fit the Campy derailleur but that would accept the Simplex bolt.
    It also required some way to stop the derailleur from rotating too far forward, the function provided on the Campy dropout by a notch forged into the dropout and a boss protruding from the upper body of the derailleur. The boss rests against the stop, keeping the derailleur at the required angle. The stop on the Simplex derailleur is provided by a plate attached to the upper body of the unit which it attached to a spring inside the body and which registers against the outside of the hanger with a bent tab built into the stop plate. The rearward motion of the Simplex is governed by the spring in the upper body of the derailleur. The Record has no such spring and is free to rotate freely on its mounting bolt, tension on the chain provided by the spring built into the lower portion of the body which acts against the pulley cages. This is all common knowledge to most of you but I’m describing the construction details in order provide insight into how the modified stop was achieved, in case anyone wants to try this.
    But I’m getting ahead of myself. First, I had to make a bolt. Shown here are a few pics of the bolt being constructed on my old Logan 10 inch lathe.
    Sorry about the lousy pics.
  3. #3
    Join Date
    Apr 2005
    Location
    Sand Spit East
    Posts
    4,319
    DISCLAIMERS: Although I have two metal lathes, and a small milling machine, I’m no machinist. I am fairly adept with my woodworking machines and tools, but I’m a complete amateur on metalworking machines. I use them to make parts for custom lamps I make, and because I like old cast iron American home shop machinery.
    Nomenclature; I’m going to use terms for various parts which may or not be proper. I aint no expert, just a tinkerer. Hopefully what I’m referring to will be clear enough without providing a glossary.
    Also, this type of modification may have been done before, I don’t know.
    If it has, it sure would have been nice to know so I wouldn’t have had to re-invent this particular wheel. This project was fun, frustrating and very satisfying but may fall into the category of “this guy has too much time on his hands”, and, as my wife likes to say, might be another example of “painting legs on a snake”. I consider myself to be an expert painter.
    MATERIALS: I decided that since I have very little experience turning steel on a lathe, and since this first attempt was to be a prototype, I would use something more forgiving that I had on hand, a piece of nickel silver bar stock and some .062 nickel silver plate. Nickel silver is nothing more than brass alloy with twelve or 18% nickel added. Not the ideal material for the parts but tougher than brass, with added corrosion resistance, and a heck of a lot easier to work with than steel.
  4. #4
    Join Date
    Apr 2005
    Location
    Sand Spit East
    Posts
    4,319
    Making the bolt: The diameter and length of the bolt needed to be very precise. Since the new bolt would bear against the new stop plate, which would in turn be clamped between the bolt and the surface of the dropout hanger, I machined a small shoulder on the end of the bolt to fit the bore through the stop plate. The shoulder serves to register the stop plate to the bolt and is only half the thickness of the plate so it effectively clamps the plate to the derailleur hanger. The bolt was drilled and tapped to M6 X .1 prior to machining.
    When the female end of the bolt was completed I cut it off and reversed the part in the lathe to finish the head, a recipe for eccentricity but I managed to
    get it fairly well centered again. The head of the bolt provided a challenge. Milling a hex-shaped hole in the head for a 6 mm wrench is beyond my capabilities but since the bolt will be cinched down from the rear there’s no absolute need for a hex hole. Still, it would be nice to have something to hold on to. I wanted to do a straight knurl but could find only cross hatch patterned cutters in my stuff. Somehow the idea of cross hatch pattern on the head of the bolt didn’t seem like it would look right to me. The first bolt has a sort of “self-knurled” head as a result of an accident when during one of many amateur mistakes the work piece “climbed” the cutter, which was set too low, setting up a nearly perfect chatter pattern around the head of the bolt.
    What the heck. I left it. I turned a second bolt later, to fine tune the length and diameter a hair and do a head shape more closely representative of the original. I left the head on the second bolt smooth but for a tiny concentric groove. Not enough to hold on to, but it works. I may do another one with fancy indexed cuts in the perimeter. There’s that snake again.
  5. #5
    Join Date
    Apr 2005
    Location
    Sand Spit East
    Posts
    4,319
    THE STOP PLATE
    The stop plate was very tricky. The idea was to use the stop boss protruding from the rear of the Campy body to register on a notch cut in the plate, with a bent leg like the Simplex plate to register against the outside diameter of the hanger. Easier said than done as those three aspects need to be in precise relationship to each other. It took me four tries. Two of them broke when I heated the alloy to bend the little leg. I ended up using the first one after having initially rejected it because I thought the notch location allowed the derailleur to sit too far forward. So it goes. It’s a prototype and I would like to perhaps mill a plate out of a little thicker material to provide a heavier, more robust stop. Not sure this part will stand up to rigorous use as is, but it works. Subject to further modification.
  6. #6
    Join Date
    Apr 2005
    Location
    Sand Spit East
    Posts
    4,319
    THE BOSS
    The stop boss on the rear of the derailleur has to be modified slightly to clear the diameter of the Simplex hanger. The pics show me laying out the alteration and using the Dremel to remove a bit from the inside of the boss.
  7. #7
    Join Date
    Apr 2005
    Location
    Sand Spit East
    Posts
    4,319
    Time for a road test. The set up works fine on the stand although I do have a little misalignment and vague looseness, but I think the old Pat. ’72 derailleur may just be worn out. All in all I’m pleased with the result.
    After that, to make one out of tool steel. Maybe later. Many legs to paint.
  8. #8
    Senior Member Alan Edwards's Avatar
    Join Date
    Apr 2011
    Location
    Lancaster,CA the desert north of Los Angeles
    Posts
    706
    WOW, thats all I can say. I thought I was pushing the envelope fixing old RDs, you are making new parts that never existed. You are da man.
    Totaly cheap wieght weenie. Totaly cheap bike snob. But I love Italian hand made stuff. 84' Ciocc, 85' Raleigh Super Course, 96' Sakae Litage, 2000 Lemond Maillot Jaune,
    2010 Nashbar SRAM RED, 86', 87', 89' Ironmen, 96' Schwinn Super Sport, 79' Shogun 1500, and ten projects.
  9. #9
    Senior Member shnibop's Avatar
    Join Date
    Aug 2009
    Posts
    722
    Bravo! excellent work, now patent the parts/design, send it off to Velo-Orange or something for mass production
    i had a similar idea (if not identical) a while back... but no means of realizing the idea, it got filed away somewhere in the back of my head.
  10. #10
    Senior Member auchencrow's Avatar
    Join Date
    Apr 2009
    Location
    Detroit
    Posts
    7,336
    You're a genius Rootboy.
    - And I'm sure the envy of every Simplex-derailluered French-bike-owner the world over.
    - Not many would have thought of this, much less realized it.
    ( Of course, it might have been good if you had done this 40 years sooner for the tour of the coast of Washington and Oregon - but better late than never. )
    - Auchen
  11. #11
    Join Date
    Apr 2005
    Location
    Sand Spit East
    Posts
    4,319
    Thanks guys. It was a real challenge and much blue language ensued, but it came out pretty well. I hope it works under load.
    Auchen' , If I had attempted this forty years ago, it would have had to be with an old, corded electric drill, some files and a hammer.
    It's been a long time itch, but I didn't scratch it 'til now.
  12. #12
    Join Date
    Apr 2009
    Location
    Detroit
    Posts
    7,336
    Quote Originally Posted by rootboy View Post
    --- If I had attempted this forty years ago, it would have had to be with an old, corded electric drill, some files and a hammer. ...
    Like this?
    - Auchen
  13. #13
    If I own it, I ride it CV-6's Avatar
    Join Date
    Nov 2005
    Location
    Cardinal Country
    Posts
    2,822
    So when do you go into production?
    Lynn Travers
    Hazelwood, MO
    Photos
    ISO: Lejeune Champion du Monde Ultra Leger Reynolds 753, 53-56cm
  14. #14
    Selling Chrome Paramounts cudak888's Avatar
    Join Date
    Sep 2005
    Location
    Southern Florida
    Posts
    23,544
    A standing ovation for Rootboy for coming up with the best solution ever devised in 30 years to solve this issue.
    You should be proud of your invention there - you have every right to be.
    -Kurt
  15. #15
    Rustbelt Rider mkeller234's Avatar
    Join Date
    Oct 2008
    Location
    Canton, OH
    Posts
    7,424
    Wow, that deserves a standing ovation. Nice work.
  16. #16
    Join Date
    Jun 2010
    Location
    Work in Asia, now based in Vienna, VA
    Posts
    1,007
    +1,000. Very, very clever, and an excellent implementation of the concept.
    Better yet, very well documented and explained. It really is the best solution ever. I'm afraid to expose my butchered '71 TdF to public eyes, as it was done the old-fashion hacked way.
    This is a truly elegant solution.
    This thread should be included in the permanent solutions/collections sticky!!!
    Congrats!
    1959 Hilton Wrigley Connoisseur (clearly my new favorite!)
    1963 Hetchins Mountain King
    1971 Gitane Tour de France
    1971 Gitane Super Corsa
    1984 Tom Ritchey Team Competition
    (replacing the stolen 1981 Tom Ritchey Everest custom)
  17. #17
    Join Date
    Apr 2005
    Location
    Sand Spit East
    Posts
    4,319
    Quote Originally Posted by cudak888 View Post
    -Kurt
    Thank you so much Kurt. And Mkeller234 and LeicaLad. That's high praise indeed. Thanks.
  18. #18
    Join Date
    Jul 2008
    Location
    Nampa Idaho
    Posts
    713
    Very cool! Very enjoyable read too!
    Thank you for sharing
    Cheers,
    Chris
  19. #19
    Just is...he just is. Henry III's Avatar
    Join Date
    Aug 2010
    Location
    Neenah WI
    Posts
    1,320
    Dang that's pretty impressive if I do say so myself. Well done Rootboy! So how does it shift to the composite Simplex derailleur. Are you going to put on a matching front derailleur and shifters or just do the rear NR derailleur?
  20. #20
    aka Tom Reingold noglider's Avatar
    Join Date
    Jan 2009
    Location
    Maplewood, NJ
    Posts
    12,360
    You da man.
    Dorothy to Scarecrow: What would you do with a brain if you had one?
    Please email me rather than sending me a private message. My address is noglider@pobox.com
    Tom Reingold
    Maplewood, NJ
    South Orange Maplewood Bicycle Coalition
  21. #21
    Join Date
    Apr 2005
    Location
    Sand Spit East
    Posts
    4,319
    Quote Originally Posted by Henry III View Post
    Thank you Henry III. Already got the NR front and shifters mounted. Pics will follow in another thread when I get the bar wraps done.
  22. #22
    Senior Member Chris_in_Miami's Avatar
    Join Date
    Nov 2007
    Posts
    3,419
    Very nice work rootboy! I've been eyeing old lathes and mills for a while now, and this thread is really chipping away at my self-control
  23. #23
    Join Date
    Apr 2005
    Location
    Sand Spit East
    Posts
    4,319
    Quote Originally Posted by CV-6 View Post
    That's a good question CV-6. I had thought about it, in case anyone asked. There's a few variables. First, I have to make sure this thing works. I have no doubt it will but want to test it a bit. Secondly, I'm thinking steel would be the best option for long term service, but that presents a problem. I cut out the stop plate on my woodworking band saw. Not possible with steel. Not sure how I'd tackle that without a metal cutting saw of some sort. Hack saw and grinder? Ugh. Plus, this required a bit of hand fitting. Most Nuovo Record derailleurs are built to precise enough specs, and a person could certainly modify their own derailleur with a Dremel. Pretty easy. The outside diameter of the Simplex dropout might inject some inconsistencies but stop plate built to fit mine might work on others. Still brainstorming this. Thanks.
  24. #24
    Senior Member Michael Angelo's Avatar
    Join Date
    May 2010
    Location
    Hurricane Alley , Florida
    Posts
    1,578
    That exemplifies the word "Mechanic" in every sense. Very good work.
  25. #25
    Join Date
    Aug 2005
    Location
    Northern Virginia
    Posts
    290
    Rootboy! That's great work.
    The 'stop plate' you made... I bet I am not the only one looking for a Mavic SSC rear derailleur stop plate. I and many others will be willing to buy them off you if you decide to go into production.
    This ebay auction shows the washer/plate: http://www.ebay.com/itm/Vintage-Mavi...item27c18a7fa4
    And here:
    And you could probable sell them on Ebay also... What do you say ?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
