Advertise on Bikeforums.net
Results 1 to 10 of 10
  1. #1
    Newbie Kelly I's Avatar
    Join Date
    Nov 2011
    Posts
    2
    A good recumbent for a dirt tour?
    I just purchased a lightly used Status XP in Aluminum for an upcoming eleven day tour in Colorado.
    http://www.crazyguyonabike.com/doc/?...c_id=9864&v=1o
    The wheels are 26" with 1.4 tires. When I wear those our I plan to install 1.5's or 1.75's with a bit of tread.
    Have you done any dirt riding with your bent? How was the experience?
  2. #2
    I am the Snail~! Peter_C's Avatar
    Join Date
    Sep 2009
    Location
    Near Akron, Ohio
    Posts
    1,642
    Over on the BROL forums is a thread that might interest you? http://www.bentrideronline.com/messa...ad.php?t=80168 The title is, My new Lightfoot Ranger!
    FYI, while I watch the recumbent section here on BF, it seems all the recumbent action is over on BROL.
    Peter_C
    My Photos
    DFL > DNF > DNS <---Stolen from another
    Quote Originally Posted by TB
    This time we wended (Trikes are allowed to wend. Roadies find this too slow.)
  3. #3
    Join Date
    Feb 2006
    Location
    Sin City, Nevada
    Posts
    347
    I hate to crash
    My experience riding an Haluzak Horizon short wheelbase bike on a packed gravel road in central Nevada wasn't good. The bike has underseat steering, a 20 X 1+1/8" front wheel and a 26" City Marathon tire on the rear. I remember going down at least once on loose gravel in a fairly short ride. I'd hate to think how it would handle with the extra gear added. It handles just fine on regular roads and paved trails.
  4. #4
    too fat to be a 3 Creakyknees's Avatar
    Join Date
    Jan 2007
    Location
    Texas
    Posts
    3,723
    Back when I rode a bent, I did lots of dirt / singletrack.
    With any 2 wheeler off pavement, traction and front tire contact patch is your main concern. With an upright bike, you can shift your weight somewhat to enhance traction; not so much with a bent.
    Front tire "washout" is the number one risk. I did it several times; it's just physics - a bent has a lower % of weight on the front tire, more on the back. Therefore, traction will be less for the front than the back (this is exactly opposite of what you want / need for control). Generally, all you can do is keep the speed under control, especially on descents and in the loose stuff.
    Basic tips from dirt riders:
    - braking with the rear is better (especially if you must brake while turning); because first, the rear has more traction (weight) and second, braking transfers weight toward the front, improving traction there.
    - you can lean forward and pull downward on the bars to shift your weight forward a bit. I found this also helps when traversing bumpy terrain, allows the bike to move around more freely than if you're back against the backrest.
    - Lower psi's and knobbier treads are better on the front.
    Clearing obstacles is of course another biggie on singletrack, but on graded / gravel roads should be no prob.
    "If there is one thing I know about bike racing, it's that people on bike forums would have done it better."
    - an internet post
  5. #5
    Join Date
    May 2005
    Location
    IL-USA
    Posts
    1,407
    Short-wheelbase recumbent bikes handle poorly in loose gravel or loose dirt, especially if they have smaller (20") front tires. Mounting a fat front tire helps, but doesn't totally cure the issue.
    For better gravel/dirt handling, you can either get a SWB that uses bigger wheels (26") or get a LWB that uses a small front wheel--but then, the 'highracer" bike will be more difficult to ride just because of the longer straddle distance, and the LWB will be more difficult to maneuver just due to its length.
    Recumbent bikes are great for road use and they even do well on gravel roads and fire roads, but they're not much good for technical off-roading.
  6. #6
    Senior Member Cyclebum's Avatar
    Join Date
    Jan 2007
    Location
    NE Tx
    Posts
    1,813
    A front rack loaded with gear should easy the washout issue a bit. I understand the op is arranging for that. Maybe she'll post a picture when she gets it set up.
    The bicycle is one of the great inventions of mankind. Delights children, challenges young men to feats of daring, and turns old men into boys again
  7. #7
    Senior Member Dchiefransom's Avatar
    Join Date
    Jan 2003
    Location
    Newark, CA. San Francisco Bay Area
    Posts
    5,929
    Not too much off road, just unpaved sections of trail on a Cycle Genius Sparrow with 1.95 tires. Loose gravel I was destined to crash on my Stratus LE with 1.35 front tire. I'd fit the largest tires you can get on the XP, and don't wait until the 1.4's wear out. I'd also keep the seat as upright as I could.
    Silver Eagle Pilot
  8. #8
    weirdo
    Join Date
    Jan 2008
    Location
    Reno, NV
    Posts
    1,463
    Kelly, have you gotten any input from Wayne Estes on this? I know his tours often feature a lot of dirt miles, and his bike is nothing at all like what usually comes to mind at the mention of off road recumbents.
    As for me, either my bent is totally unsuited for offroading, or my technique is seriously lacking (probably a combination of both), so I just went back to the skinniest tire I found comfortable and decided that it stays on the pavement. I love playing in the dirt, but I`m sticking with my DFs for that.
  9. #9
    Join Date
    Feb 2010
    Posts
    23
    Dirt roads and recumbent trike sounds fine. I would rather have three wheels on a dirt road. Love my Catrike Trails ( I am on my third one).
  10. #10
    Join Date
    Feb 2012
    Posts
    5
    3 wheels is the way to go. We did the Hiawatha trail both ways on our Ice Adventure's, just put on 2.35 Big Apple's all around and it's even better in the gravel
Posting Permissions
  • You may not post replies
  • You may not edit your posts
