Advertise on Bikeforums.net
Results 1 to 7 of 7
  1. #1
    Join Date
    Jul 2011
    Posts
    133
    25.8 Handlebar In a 25.4, Four Bolt Open Face Stem?
    I really wanted to get the Eighth inch track drops but my stem is 25.4mm and the bars are 25.8 mm.
    I've googled it but I got some mixed answers.
    I have a 4 bolt open face stem, can I safely fit 25.8 mm handlebars in it?
    Or is there anywhere I can get a 25.8 size stem for cheap? The only ones seem to be Ritchey stems for like $60+
  2. #2
    Magnets, how do they work solipsist716's Avatar
    Join Date
    Jun 2010
    Location
    Buffalo
    Posts
    938
    I believe the fact that they list the bars as 25.8/26.0 is indicative that the bars are really effectively just 26.0's. Find other bars, or use google shopping man. It's pretty easy to find good deals if you just search.
    Quote Originally Posted by cianm View Post
    How do i tweak my brakes so it will be good for skidding?
    Quote Originally Posted by Sixty Fiver View Post
    As Minchin said, praying before a sporting event and winning does not mean that god took time out from torturing and killing babies in Africa to ensure your team's win.
  3. #3
    Senior Member jpsawyer's Avatar
    Join Date
    May 2011
    Location
    Providence, RI
    Posts
    521
    If you want shallow track drops for cheap you can now get the charge racer drops which are little shallower than the 1/8th inch ones but they come in 25.4. citygrounds was the only place i saw that had them in stock though
    http://store.citygrounds.com/store/p...op-Bar-Silver/
  4. #4
    old legs
    Join Date
    Aug 2009
    Posts
    849
    I've used Kalloy's bars they felt great Ben's has them in stock
  5. #5
    NaCl
    Join Date
    Dec 2011
    Location
    East Bay
    Posts
    8,175
    it'll bend the stem. May cause it to break, which will lead to the loss of teeth.
  6. #6
    Join Date
    Nov 2006
    Location
    duluth
    Posts
    3,395
    It might work.... And it might result in catastrophic failure at the worst possible time. I wouldn't bet my life on a janky, ghetto, bar/stem setup.
    Quote Originally Posted by Santaria View Post
    because physics has more street cred than tarckstars.
  7. #7
    Veteran Racer TejanoTrackie's Avatar
    Join Date
    Jul 2009
    Location
    Ciudad de Vacas, Tejas
    Posts
    5,651
    Just get a cheap 26.0mm stem like this >>>> http://www.universalcycles.com/shopp...9&category=630
    Even if the bars are truly 25.8mm, the difference is insignificant and you won't be prying the stem clamp apart.
    What, Me Worry? - Alfred E. Neuman
    Quote Originally Posted by Dcv View Post
    I'd like to think i have as much money as brains.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
