Advertise on Bikeforums.net
Results 1 to 3 of 3
  1. #1
    Make every day count! Old Al's Avatar
    Join Date
    Jul 2009
    Location
    Sarasota, FL
    Posts
    10
    EZ Sport Idler Replacement
    I am trying to replace the idler wheel on the EZ Sport that I recently bought used. I've got it down to the threaded bolt that goes through the frame which is bent. (the bolt not the frame) I've tried to straighten the bolt and have made some progress getting it out about a half an inch. The problem is I am getting close to stripping the head in the bolt. Any helpful suggestions appreciated. BTW, I have the aluminum frame.
    Old Al
    1984 Trek Single Speed Coversion (For Sale)
    1997 Waterford 1250 Sport Touring
    2008 Surly LHT
    2008 Sun EZ Sport AX (Purchased Used 1/2012)
    2010 Brompton
  2. #2
    Senior Member Capecodder's Avatar
    Join Date
    Jul 2010
    Location
    Somewhere Between The Beginning And The End
    Posts
    2,071
    Cut the head off the bolt and push it through the opposite way. You will obviously need a new bolt, but one should be available.
    Amy, I'll always remember you...... I miss you so much, for you filled my days with so much joy.
  3. #3
    Join Date
    Jul 2005
    Posts
    2,895
    Buy a new idler wheel kit from Hostel Shop online. It comes with a new bolt. bk
Posting Permissions
  • You may not post replies
  • You may not edit your posts
