Specifically oversize down tube to standard headtube?
Obviously there would be no buildup of braze around the sides of the join, added to that the fact it's a relatively high stress area, so instinct tells me it's not the best of ideas - can anyone assure me otherwise?
I guess it's not something one would ordinarily consider since you'd just use an oversize headtube (which I'll probably end up doing) or standard DT, but the friend I'm building for is fairly insitent on having fillet brazed frame with a quill stem, and a 28.6 DT would probably be a bit on the noodly side for him.
I know there are ways 'round this with ahead/quill converters or sleeving the standard dia. headtube etc - or simply persuading him away from a quill stem altogether.
So I suppose i ask out of intrigue as much as anything.
Appreciated as ever.
