Advertise on Bikeforums.net
Results 1 to 8 of 8
  1. #1
    Senior Member Paul01's Avatar
    Join Date
    Sep 2010
    Location
    Tampa Bay, Fl
    My Bikes
    Vitus 979, KHS Montana Comp
    Posts
    531
    HELP! Polar FT1 abnormal readings problem
    I got on the bike for ride today and and my month old FT1 said 130 bpm. When I got the corner, 50 yards at at real slow pace, it read 190. On the MUP it locked in at 240 for a while and, typing at my desk now, it reads 136 when it would normally read about 60. Normal range would be 90ish leaving the house and riding on local streets and 125-135 riding hard with a max about 150.
    I've washed the transmitter,and taken the wrist thingy off the bike and in the house. No change.
    My FT1 got the fever. Any one here got the cure?
  2. #2
    Senior Member socalrider's Avatar
    Join Date
    Mar 2004
    Location
    Upland, CA
    My Bikes
    Litespeed Liege, Motorola Team Issue Eddy Mercxk, Surly Crosscheck Cyclocross bike, Fisher Supercaliber Mtn. Bike
    Posts
    5,007
    your battery needs to be replaced..
  3. #3
    Join Date
    Sep 2010
    Location
    Tampa Bay, Fl
    My Bikes
    Posts
    531
    You think so ? Its a brand new HRM. Which one?
  4. #4
    Join Date
    Mar 2004
    Location
    Upland, CA
    My Bikes
    Posts
    5,007
    polars many time use strange watch batteries, you need to check manual.. Make sure the chest strap is firm against the chest and if you ride near high power lines you will get odd readings..
  5. #5
    Join Date
    Sep 2010
    Location
    Tampa Bay, Fl
    My Bikes
    Posts
    531
    I tried it again this morning and it says60 bpm sitting at my desk.
  6. #6
    Quack! sacrifice's Avatar
    Join Date
    Jun 2008
    Location
    Juneau, AK
    Posts
    41
    I have had a Polar for years and have had this problem occasionally. The problem is not the battery but the chest band. The instruction manual mentions (assuming they still provide manuals) that the band needs to be rinsed after every use and washed every couple of uses. This is accurate advice as I have found out by not washing the band. I now wash mine after every use with Dr Bonners hand soap and every few weeks put it in the washing machine with my wool laundry and use woolite (place it in a small laundry bag or a sock), and never have the problem, even with low batteries. The problem and solution has also been discussed on the Polar forums.
  7. #7
    Join Date
    Sep 2010
    Location
    Tampa Bay, Fl
    My Bikes
    Posts
    531
    Quote Originally Posted by sacrifice View Post
    OK. So I stared washing it religiously after every use with soap and water and, voila, it worked fine.
    That was until yesterday when it pegged my efforts at between 30 and 60 bpm -- even during a long, hard interval. Then, today, it had my heart pumping at 120 bpm sitting still and more than 240 for most of a mild effort ride so, either I'm going to be the first senior citizen on the pro tour or my HRM is having a major psychiatric event.
    Now what ?
  8. #8
    Join Date
    Sep 2010
    Location
    Tampa Bay, Fl
    My Bikes
    Posts
    531
    So, I put it on yesterday and today and and it worked fine. Huh????
Posting Permissions
  • You may not post replies
  • You may not edit your posts
