Advertise on Bikeforums.net
Results 1 to 7 of 7
  1. #1
    billy chuck eschlwc's Avatar
    Join Date
    May 2011
    Location
    on the beach
    Posts
    903
    bearing sizes - campy/sugino
    gentlemen!
    [and women...]
    and women.
    still bulding the '71 falcon and need to source bearings.
    what i know:
    record lf front hub size -- 7/32"
    record lf rear hub size 1/4"
    what i think i know:
    sugino mighty competion era bb -- 1/4"
    what i do not know:
    n.record headset bearing size -- 3/16" or 5/32"?
    and before setting me straight, tell me your thoughts concerning using retainers vs loose balls. (yes, still talking ball bearings here.) are you more likely to use retainers for headsets vs bbs?
  2. #2
    Join Date
    Nov 2004
    Posts
    9,311
    Camapgnolo Record Strada (road ) headsets used 3/16" bearings while the Pista (track) version used 5/32" bearings. 1/4" is correct for the BB. I tend to use caged bearings in headsets and bottom brackets for convience, though loose bearings are perfectly acceptable. Some of the newer synthetic greases tend to be a little less tacky and loose bearings sometimes do not stay in place, falling out and becoming contaminated.
    A picture is worth a thousand words, but only if it is taken from the drive side. Otherwise, it's virtually useless.
  3. #3
    Join Date
    Feb 2008
    Posts
    1,059
    Also, one nice thing about using loose balls in those headsets is that you can insert more bearings than the retainers hold (22 + 22 in the road headset case, vs. 20 + 20 in the factory retainers), which distributes the load better. It also can help mitigate some of the 'indexed steering' issues (a.k.a. brinelling).
  4. #4
    Join Date
    May 2011
    Location
    on the beach
    Posts
    903
    i wonder why the track and road versions of campy headsets use different sized bearings. i noticed loose screws sells a tange headset retainer only in the track size, 5/32". i'll probably go the 'loose' route on the headset for this reason, the relative ease of installation, and the load issue you described above. but i'd like to use a retainer to replace the sugino 9-ball retainer. loose screws sells tange 9-ball and 11-ball bb retainers. sheldon says never to use the 9-ball variety in your bb, but i wonder if these retainers are the same diameter and can fit the same bb cups. whaddya think?
  5. #5
    Join Date
    May 2011
    Location
    on the beach
    Posts
    903
    follow up... re: replacing the sugino bb 9-ball 1/4" retainer with the tange 11-ball retainer... even though these retainers appear the same diameter, the tange retainer does not fit as perfectly as did the original sugino. so i scrapped the 11-ball idea and reused the original retainer, after a thorough cleaning and installation of new balls. i understand loose balls might be an improvement, but if was good enough to begin with ...
  6. #6
    Old fart JohnDThompson's Avatar
    Join Date
    Nov 2004
    Location
    Appleton WI
    Posts
    10,350
    Quote Originally Posted by eschlwc View Post
    Larger balls can take more abuse and thus were considered more appropriate for the road, where surface conditions may be rough at times. The track is more likely to have a smooth surface and less need for the larger balls.
    FWIW, the Campy "Sport" headset also used the smaller balls, and in fact appears to be identical to the Pista headset except for the threaded cup, which has only two wrench flats vs the octagonal flats on the Pista. Sport headsets are often confused for Pista headsets, but it really only matters to hipsters anyway.
  7. #7
    Join Date
    Nov 2004
    Location
    Appleton WI
    Posts
    10,350
    Yes, they're interchangeable. 9-ball retainers are a cost-saving measure for manufacturers.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
