How to set up this straddle cable
Old 02-29-12 | 10:52 AM
Bikes: Giant Peloton Lite
You'll have to forgive my ignorance, but I'm fairly clueless when it comes to cantilevers. I bought a second hand set the other day for my Kona JTS frameset and I can't work out how I would route the cable and housing for this straddle cable to work. Am I missing a component? It looks like the cable housing goes into the black bit then the brake cable continues on to the side of the brake that has the cable clamp on it, but this just doesn't work. Any advice. I could quite easily buy a different straddle cable and use a cable housing stop if need be.
File Type: jpg
File Type: jpg
martyn3200 is offline
Reply
Old 02-29-12 | 10:59 AM
Shimagnolo's Avatar
That looks like the Cannondale "Force40" brake cable.
Short answer is: You can't unless you have the special threaded post on your frame and fork into which it bolts.
https://www.vintagecannondale.com/can...structions.pdf
(I had this on my mid-90's C'dale M700)
Shimagnolo is offline
Reply
Old 02-29-12 | 12:54 PM
Bikes: 8
yea just get a common straddle cable and a normal brake cable hanger.
fietsbob is offline
Reply
Old 02-29-12 | 02:29 PM
Cheers
Reply
Old 03-23-12 | 12:45 AM
tonyjaja
Guest
Posts: n/a
+1
Reply
bartturner
Tandem Cycling
10
11-04-12 03:10 PM
r0ckh0und
Bicycle Mechanics
3
02-19-12 04:59 PM
atelierf.lab
6
10-02-10 03:39 PM
himespau
Bicycle Mechanics
6
09-19-10 07:10 PM
y036d
Bicycle Mechanics
1
07-22-10 10:36 AM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
