Advertise on Bikeforums.net
Page 1 of 2 12 LastLast
Results 1 to 25 of 26
  1. #1
    Join Date
    Apr 2012
    Posts
    12
    Where can I buy a Pedal Tap In North Dallas
    I messed up the threads where the pedal screws into the crank ( arm) I stopped by a bike shop and said I would need a pedal tap...but they dont carry them.....Anyone know of a place in north dallas where I might find a pedal tap to fix the threads??
    Thanks
  2. #2
    Senior Member WickedThump's Avatar
    Join Date
    Mar 2012
    Location
    Aurora, Colorado
    Posts
    531
  3. #3
    Join Date
    Apr 2012
    Posts
    12
    have called several.....and sears...and some parts stores....No luck locally.....only online really wanted to fix it quick!
  4. #4
    Join Date
    Sep 2010
    Posts
    1,905
    You could try the taps, the size is 9/16" X 20TPI, right hand thread for the right crank, left hand thread for the left one. You could also try starting the pedals in from the inside and seeing if you can re-form the distorted threads enough to thread them in the right way. Understand that a tap can only remove metal so if the fit is too loose due to the metal being stripped out there will be nothing to tap into. In this case the repair is to drill the hole oversize and using a special tap make new, oversize threads and then install a Helicoil threaded insert. This will make stronger threads than the original aluminum. An older bike shop or a machine shop would be places to inquire about this. It is a quick and relatively simple job but the cost of the specialized tooling (taps and insertion tool) required makes it uneconomical to do yourself.
    Grease the pedal threads and start them by hand so that you do not damage the threads again; if they do not go smoothly STOP and find out why. I use Tef-Gel anti-seize paste and also stainless pedal washers to help prevent the pedals binding or galling and to ease removal.
  5. #5
    Join Date
    Sep 2007
    Location
    Gaseous Cloud around Uranus
    Posts
    2,911
    Call around for the Park Tool set-up,should be about $35.It will cost you more than that for a HHS left hand thread tap from a machine tool place.
    Or like they said above,use the pedal to chase the threads from the back with some anti-seize or grease.
    Everything should be as simple as possible...But not more so.---Albert Einstein
  6. #6
    Join Date
    Jan 2011
    Location
    South Yorkshire, England.
    Posts
    204
    I did the same thing about a year ago, enquired at the LBS about getting the crank re-threaded, no dice, enquired at a local engineering works about it, maybe helicoil? no dice. I ended up throwing the crank and bought a new one on ebay for £8.00.
    Colnago CX-1 Record 11sp. Carbon Epic Expert 29er
  7. #7
    Join Date
    Apr 2012
    Posts
    12
    ya...i have tried putting the pedal in from the back....its just not quite long enought to get the last two threads. So...I either need the tap...or the Crank puller to take it off and take it to a bike shop......Finding either the puller or the Tap locally seems to be impossible......UGH..( i can find it on the net...just want to walk in somewhere and grab it and go! )
  8. #8
    Join Date
    Jun 2011
    Location
    Winnipeg, MB, Canada
    Posts
    156
    Any decent LBS should have a crank puller for sale.
  9. #9
    Join Date
    Apr 2012
    Posts
    12
    what does LBS stand for?
  10. #10
    Join Date
    Sep 2010
    Posts
    1,905
    Quote Originally Posted by keithsm2 View Post
    If it is the right hand crank you might be able to find a 9/16-20 bolt that is long enough to do the job, or maybe pull the axle out of an old set of pedals and use that; yes, I'm stretching here. Are there any machine shops around that you could check with?
  11. #11
    Join Date
    Apr 2012
    Posts
    12
    Quote Originally Posted by dsbrantjr View Post
    no...its the left crank......right prolly wouldnt be such a problem......I thought these were suppose to tighten as you pedal?? came right out while pedaling.....My fault for not getting it tight enough...needed an open end wrench instead of monkey wrench.....Think monkey wrenchs cause more problems than they fix!
  12. #12
    Join Date
    Jun 2011
    Location
    Posts
    156
    LBS stands for Local Bike Shop, to differentiate LBSes that mainly sell bikes from places that might sell, for example, groceries, clothes, cheap sporting goods, and BSOs (Bicycle-Shaped Objects). If an LBS doesn't sell very basic tools like crank pullers, though, they are probably not very good.
    You might be able to improvise a pedal tap out of an old pedal, as dsbrantjr said above, if you can grind off some of the wide bit with the wrench flats just above the threads to give yourself more length. You are probably better off finding an LBS with a pedal tap, though; even if they don't have one for sale, some place in your area must have one for them to use.
  13. #13
    Join Date
    Apr 2012
    Posts
    12
    think i found a Crank puller at a LBS ......so....guess ill remove it and bring it to them to chase the threads.......Thanks so much to everyone for the quick reply....
    This is on a Proform Tour de france stationary bike.......Had it two weeks and its been completely functional for about 20 minutes......Came with some loose parts in front hub.....Couldnt get covers off to tighten ( No crank puller )......then after those got tightened...the pedal fell off....( My fault )......so......anyway.....looking forward to some competitons on IFIT...
  14. #14
    Join Date
    Aug 2005
    Location
    Pittsburgh, PA
    Posts
    22,370
    Most decent bike shops will have a set of pedal taps for use by their own mechanics but won't have extra sets for sale. See if the shop can clean up the threads using their own taps rather than asking if they have a set for sale. I hope you don't need your own taps routinely.
  15. #15
    30 YR Wrench BikeWise1's Avatar
    Join Date
    Aug 2005
    Location
    Oxford, OH
    Posts
    1,894
    UGH..( i can find it on the net...just want to walk in somewhere and grab it and go!)
    Ahhh.....those days are mostly gone thanks to the low-price-at-all-costs internet shopping experience. And those of us who still bother to stock such things grow very tired of hearing people say "thanks, but I can get it cheaper online"....
    Unless you or your shop have a drill press, it's unlikely you will have success with a Helicoil. Very annoying to go through all that grief only to end up with a pedal that isn't exactly straight. Sounds like the pedal wasn't fully tightened during assembly.
  16. #16
    coprolite fietsbob's Avatar
    Join Date
    Jun 2010
    Location
    NW,Oregon Coast
    Posts
    25,537
    the bike shop can order you a pair for home use,
    but will not have a set to buy on Spec.waiting..
    Call first and they should be there in a fortnight.
  17. #17
  18. #18
    Join Date
    Apr 2012
    Posts
    12
    got it fixed.....Found a CP 22 crank remover.....took it off and brought it back to the bike shop.....they chased the thread and all is good....And your are correct....."I" didnt get the pedal tight......but ....i thought the whole reason to have reverse thread was to prevent it from backing out while riding.......but in the end....I didnt get it tight....
    Thanks again everyone....I was able to get 30 minutes in last night with everyones help.
  19. #19
    Bianchi Goddess Bianchigirll's Avatar
    Join Date
    Apr 2009
    Location
    Somewhere within 175 miles of Harrisburg PA.
    Posts
    17,989
    I know I have been out of the business for quite some time but how do you run a shop without pedal taps? I know you don't use them everyday but still for the cost of a tool that will last 20+ years why not have them.
    Bianchis '87 Sport SX, '90 Proto (2), '91 Boarala 'cross, '93 Project 3, '88 Trofeo, '86 Volpe, '89 Axis, '79 Mixte, '99 Mega Pro XL Ti, '97 Ti Megatube, , '90 something Vento 603, 87 Mondiale for sale, '88 Grizzly sold
    Others but still loved,; '80 RIGI, '80 Batavus Professional, '87 Cornelo, '86 Bertoni (sold), '09 Motobecane SS, '98 Hetchins M.O., '09 K2 Mainframe, '9? Univega Rover 304 Sold , '89 Trek 2000, '?? Jane Doe (still on the drawing board)
  20. #20
    Join Date
    Apr 2012
    Posts
    12
    its not that the shops dont have a pedal tap......its that they dont stock them to sell......
  21. #21
    Old fart JohnDThompson's Avatar
    Join Date
    Nov 2004
    Location
    Appleton WI
    Posts
    10,364
    Thanks
    A pedal tap is an expensive purchase for a one-off job. Surely there is a bike shop in your area that can re-tap the arm for you.
  22. #22
    Join Date
    Apr 2009
    Location
    Posts
    17,989
    So your saying you basically had a "failure to communicate" on the part of you and the shop employees?
  23. #23
    Join Date
    Jun 2010
    Location
    NW,Oregon Coast
    Posts
    25,537
    Sometimes if you bugger up the threads, you can make it work
    by threading the pedal in to the back side of the crank, and straighten out the threads,
    then screw in the pedal the proper way..
  24. #24
    Join Date
    Aug 2005
    Location
    Pittsburgh, PA
    Posts
    22,370
    Quote Originally Posted by fietsbob View Post
    Sometimes if you bugger up the threads, you can make it work by threading the pedal in to the back side of the crank, and straighten out the threads,
    He already tried exactly that. Read post #7.
  25. #25
    Elitist Troglodyte DMF's Avatar
    Join Date
    Jun 2006
    Location
    Atlanta
    Posts
    6,927
    Richardson Bike Mart ?? http://bikemart.com/
    One of the best shops in the country. Especially the Richardson location.
    Stupidity got us into this mess - why can't it get us out?
    - Will Rogers
Posting Permissions
  • You may not post replies
  • You may not edit your posts
