Originally Posted by
eugenek
There's no such thing as the "anaerobic zone" of the heart rate, it is not a well defined scientific concept. Don't trust Strava on that one. You should be thinking in terms of power output, not heart rates.
Some basics (you might know some of this, but bear with me):
* You have a certain maximum capacity for oxygen intake called VO2max. You can get that measured at a sports clinic if you want.
* When you exercise at a sufficiently low intensity, your power output is proportional to your breathing rate.
* If you try to raise your power output slowly and gradually, you pass through the "lactic threshold" (when lactic acid begins accumulating in your bloodstream), then through the "ventilatory threshold" (when you have to start huffing and puffing), and eventually you can get to VO2max. Everyone's different, but, as a ballpark figure, your lactic threshold is somewhere around 70% of VO2max and your ventilatory threshold is somewhere around 80%. Using this procedure, you can measure your maximum heart rate and your power at VO2max. That is mostly a useless number because it is very difficult to sustain that kind of power output for long. It's easier and less painful to estimate your power at LT/VT and use that as a starting point. The 2x20 test mentioned above should give you a number close to your VT.
* In interval training, the idea is to get your power output close to, or even above VO2max. You can't sustain that power for more than a few minutes, and your heart rate simply may not have time to rise that much. That's exactly what you were seeing in your attempt. Getting the heart rate up is not the point. You work for a few minutes, stop, rest, and repeat. The higher you go, the less time you will last. You can go as high as 200% of VO2max for 30 seconds and 300% of VO2max for 5-10 seconds.
