Originally Posted by
dougmc
But it's wavelength that matters here, not frequency. (And yes, I'm aware of the relationship between the two.) That said, a 40 kHz sound wave and a 30 GHz microwave have roughly the same wavelength, so I would expect a similarly sized emitter/receiver to be needed in both cases to get a similarly tight beam.
But you're right -- the beam would have to be quite tight to fit in 3' at 100'. If needed we could increase the microwave frequency, but going higher on the sound frequency would increase the attenuation by air (which may already be a problem at 40 kHz). Some sort of IR, optical or UV laser might work better -- that could easily be as tight as we wanted it to be. I imagine the electronics needed would be more complicated than with the ultrasonics, but of course this is 2012, not 1978 (thinking of the Polaroid cameras again) -- I imagine it's still going to be small, cheap, and efficient.
Putting this on a bicycle is not going to be very effective, especially pointed backwards -- it would either give you lots of false positives, or give you a half second of warning before a serious collision, neither of which is particularly useful. But put on a car, aimed forward, connected to the brakes it could be very useful.
Detecting cars would be easy -- they're big and metal, reflecting ultrasonics and microwaves easily, and their license plates reflect lasers very well. Detecting bicycles would be harder -- the metal might reflect some ultrasonics and microwaves, and shiny bits might reflect lasers adequately. Pedestrians might be the hardest to detect of all -- little metal anywhere, clothes might be all black and therefore not reflect lasers well.
Detecting stopped cars/bikes/pedestrians might be a problem, as the reflected signal might be indistinguishable from the reflected signal from the environment around -- the road, curbs, etc. Having the system be able to stop a car going 70 mph from hitting something stopped might not be practical -- by the time the car realizes that a collision is imminent, it may not have time to stop, and no way would we let a system turn the car (not without a much much more elaborate system.) But even so -- if the car does slam on it's brakes before collision, that would certainly be better than nothing.
I guess in practice there would be a lever on the steering wheel to disable the system while the lever is pushed -- that would be used by drivers who like to change lanes at the last second before a collision, to stop the system from second guessing them. I'd prefer that such an override not be there (and people just stop doing that), but the drivers would probably demand it.
Interesting problem -- one I think that can be at least partially resolved by a technical solution.
I imagine the car makers have already worked all this out, as such systems are already available as options. Hopefully they're as effective as I think they could be, and they'll soon become as ubiquitous as ABS brakes are today -- they could save a lot of lives. (And a lot of cyclists if the system is sensitive enough to detect bicycles. "Run over from behind" collisions may be a small percentage of the total, but they are disproportionately deadly compared to other collision types.)
