Advertise on Bikeforums.net
Results 1 to 6 of 6
  1. #1
    Legs; OK! Lungs; not! bobthib's Avatar
    Join Date
    Apr 2009
    Location
    Coral Springs, FL
    Posts
    1,980
    Once bitten, twice shy. Twice bitten, ???
    So tonight Joy and I did the Ft Lauderdale Urban ride on our tandem. It's a 20 mi ride with 4 stops to regroup, and boasts 20 - 25 riders on all types of bikes. It's a fun and social group that we have enjoyed riding with for a few years now, on both our 1/2 bikes and the tandem. Joy's broken foot last summer has dictated that we need to ride the tandem to keep her "in the mix." By summer's end, she'll be back in single shape. There's another couple who ride a tandem now and again.
    Anyway, we were all lined up for the start when the tell-tale "gunshot" betold a blow out. Everyone looked around and squeezed tires to see who it was. No flats. Finally someone noticed the bulge in my front tire. There it was. The tube was peeking out between the rim and the bead. It had popped and resealed.
    I quickly pulled the wheel and got to work on the tube. With help we had the tire change and back on the bike in no time, using the tube from my tool bag.
    I guess here is a good time to fill in some of the facts. I had recently pulled the 28mm tires off my wife's 1/2 bike and swapped them for the 23s I had on the Tandem. All went well, except for 2 things: failing to properly inspect the seating of the tire on the tandem front wheel, and failing to changed the spare tubes between the two bikes.
    Sooooo, you guessed it. When I put the tube from the tandem's tool bag on the flatted tire, it was still the 18-23mm tube from when I was running the 700 x 23s. Doh!
    Well, 10 miles into the ride and fortunately not on the 30+ mph hill descent, the front tube failed. So in the middle of the Ft Lauderdale beach A1A run, with a great little tail wind, we pulled of to change the front tire AGAIN. When I pulled it I realized it was the wrong size. Dumb!
    We knew that about 3/4th of the group was ahead of us at the next rest stop/meet up at the boardwalk. The rest came by and asked if we were OK. I said yes, as I was putting on my last tube. Ernie the sweep came by and stopped. I finished putting the tube in and started inflating only to hear the sound that makes your heart sink. An air leak. I gave Ernie the keys to my van, and he was off to get it and come back to puck us up. Just before he was out of earshot, Joy picks up a new tube and says "what's this tube?" We realized just in that I had put the bad 1st tube back in. (Being a good citizen I was carrying until I found a trash can) We called Ernie as I ripped out the tube and installed the new tube.
    We were soon on our way, good as new. Better actually.
    The only other problem was that I had turned off my Garmin when we sent Ernie off to get the van, and I forgot to restart when we got riding again. So I missed recording our heroic efforts on the last 10 mi of the ride.
    None the less, it was a beautiful night for riding and we had a few unexpected laughs.
    So, once bitten, twice shy. Twice bitten, trice as happy?
    BT
    '09 Motobecane Immortal Pro, with lollipops
    '09 Fuji Aloha 1.0 TT build. with lollipops
    '09 Lamborghini Viaggio Tandem
    '06 Mongoose Commuter
    '02 Diamondback Hybrid
    "Oh, to be 60 again!"
    http://tickers.TickerFactory.com/ezt...c/exercise.png
  2. #2
    just another gosling Carbonfiberboy's Avatar
    Join Date
    Feb 2007
    Location
    Everett, WA
    Posts
    5,997
    We run Performance Ultralight 19-26 long valve tubes in everything up through 28. I haven't had a tube failure like that or a pinch in a very long time - 15 years? I don't even do the tire pinch inspection anymore. You had a bum tube. Don't buy that brand again. Except for slime, I find that every tube flats once the glass or whatever comes through the inside of the tire. The downside of slime is that it gets all over everything if one gets a sidewall cut. Plus the weight and it wouldn't have prevented your two flats.
    I have had Vredestein tubes that failed at the valve stem attachment. I have had Salsa tubes which were too long and had to be folded into the tire. Those didn't work.
    One does get rattled when changing under group pressure. I find it helps to have two or three helpers and to organize them into different tasks. Goes quick then.
  3. #3
    Senior Member rdtompki's Avatar
    Join Date
    Nov 2008
    Location
    Hollister, CA
    Posts
    3,323
    You have our collective sympathy. Stuff happens.
    Rick T
    daVinci Joint Venture
    Volagi
    Strava Tandem Club
  4. #4
    Join Date
    Nov 2008
    Location
    Bay Area, Calif.
    Posts
    3,865
    Sorry to hear you had so many problems on a single ride. I'm curious about the second flat - what did the hole in the tube look like? I usually use the same tubes in my touring bike with 38mm tires that I do in my road bike with 20 - 23mm tires and haven't had any problems. Our tandem has 27" wheels with Schrader valves, so it has its own supply of tubes.
  5. #5
    Senior Member PMK's Avatar
    Join Date
    May 2008
    Location
    Royal Palm Beach, Florida
    Posts
    965
    FtL beach at that hour was probably a pleasant stop...
    PK
    2006 Co-Motion Roadster, flat bars, discs and carbon fibre fork, size 22 / 19
    2006 Ventana ECDM full suspension mountain tandem
    Some single bikes and a couple of KTM's
    And most important, someone special that enjoys them with me (except the KTM's)
  6. #6
    Half Fast mwandaw's Avatar
    Join Date
    Sep 2010
    Location
    Southern California
    Posts
    398
    Almost every enthusiast solo biker or tandem couple has gone through something similar to what the OP described. The answer is simple... live and learn, and next time you'll finish the ride with a smile!
    Not slow, not fast, but Half Fast!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
