Advertise on Bikeforums.net
Results 1 to 14 of 14
  1. #1
    Senior Member Binxsy's Avatar
    Join Date
    Nov 2009
    Location
    South Central Minnesota
    My Bikes
    79 Peugeot UO8, 89 Peugeot Triathlon, 1969 Shwinn Suburban, 99 Schwinn Super Stock 2, 60's Hiawatha
    Posts
    455
    2 lever one brake. I wanna see your setups
    Im building up a polo rig, This is the first season I have played and I have been borrowing bikes. I am left handed but I have had to play a couple rounds on right handed bikes. No problem really since I have always been good with both my hand in sports and so on. But I want a ambidextrous rig...
    In between the barrel adjusters there will be a piece of steel with the cables coming from the lever bolted to it then a single cable running down to the brake arm I cut off and attached to the fork.
    I had this all figured out, but it was connected to a "U" brake hangar and it was starting to bend and would not hold out much longer.
    Also the stem is a old stlye flex stem so it made the brakes less effective since the stem would tilt down when the levers where pulled. I took out the rubber brushing so it does not flex. But the problem of the way the cables are attached to the metal plate still bothers me. If one lever pulls it will pull from the side, it should pull from the middle so it makes a straight line, less cable wear more efficient for and so on.
    Any thoughts????
    I know problem solvers makes a thing for this, but it is 60 bucks and I would rather not spend that much on this.
    Or if anyone has a primo pervert they wanna sell I would gladly take it
    So It Goes.....
    89 Modernized Peugeot Triathalon
    79 Peugeot U-08 single speed
    8? Sekai Grand Tour 2500 single
  2. #2
    Gordon FreeDan. IthaDan's Avatar
    Join Date
    Jan 2012
    Location
    Ithaca, NY
    My Bikes
    More than I have Fingers, it's a revolving door.
    Posts
    3,805
    HOLY WHAT THE F*CK? What the hell were you trying to do? Where did the brake mount if your "hanger" was already taking up the hole in the fork? YOU MOUNTED A CABLE HANGER ON A FLEX STEM?
    I'm so confused, and that is SO DANGEROUS.
    That primo thing wouldn't help you, and you already know why, if you think back to the problem solvers 2-1 adapter, it works in a straight line with either lever, with the primo one, either lever is pulling off angle.
    (click for album of my bikes)
    Just call me "Dan".
  3. #3
    Join Date
    Nov 2009
    Location
    My Bikes
    Posts
    455
    Hahaha, Its going to the rear brake. Yeah I never rode on it, just realized it wouldn't work. Like I said I removed the rubber brushing from the stem so its solid now. If I can get the levers to pull straight it will be fine. I will probably replace the bottom with some steel plate like pictured attached to the stem.
    So It Goes.....
  4. #4
    Join Date
    Jan 2012
    Location
    Ithaca, NY
    My Bikes
    Posts
    3,805
    Just buy a bottom gyro cable and run each end of the Y to a lever? $5.
    Just call me "Dan".
  5. #5
    Habitual (Bike) Tweaker ATX 6Speed's Avatar
    Join Date
    Mar 2010
    Location
    Austin, TX
    My Bikes
    2011 Specialized Allez Comp E5, 2011 Specialized Langster Steel
    Posts
    182
    This is my setup:
  6. #6
    Join Date
    May 2011
    Posts
    49
    Dia Compe Gran Compe Shot Lever
  7. #7
    Join Date
    Nov 2009
    Location
    My Bikes
    Posts
    455
    Quote Originally Posted by ATX 6Speed View Post
    This is my setup:
    What are those called? Im having trouble finding them...
    So It Goes.....
  8. #8
    Join Date
    Nov 2009
    Location
    My Bikes
    Posts
    455
    Works, maybe overly complicated but I thought of it....
    So It Goes.....
  9. #9
    Join Date
    Mar 2010
    Location
    Austin, TX
    My Bikes
    Posts
    182
    Quote Originally Posted by Binxsy View Post
    I bought it from here:
    http://jtekengineering.com/AeroBrake.htm
    It's called the Model-S DoubleControl Cable Splitter. It was a bit pricey, but does the job and looks really nice to boot.
  10. #10
    Join Date
    Nov 2009
    Location
    My Bikes
    Posts
    455
    47 isnt to bad, if my method requires to much fine tuning all the time I will probably go with that option...
    So It Goes.....
  11. #11
    Join Date
    Dec 2010
    Posts
    118
    If you just put 2 levers on the bars you could just pop the cable out of one and into the other in about 10 seconds. I initially thought you would be speaking of one lever pulling two brakes as that is common in polo, but was surprised to find the opposite I would highly recommend picking a hand and sticking with it, being a left has many advantages.
  12. #12
    Senior Member ThisJauntyGent's Avatar
    Join Date
    Jul 2009
    Location
    Nashville
    Posts
    218
    This is my setup:
    What bars are these?
    Quote Originally Posted by rustybrown View Post
    Obvious bro has mastered zen of fixie gear riding. Really feel the road, snow and black ice included, while clenching NJS steel betwixt his 510-laden staunches. He hovers over any potential obstacles like an urban Jesus, performing miracles of barspinnnz and no-handsies skiddz for the non-believers. That spoke card is actually a pamphlet inscribed with the Word, tentatively awaiting passage to the newest disciple.
  13. #13
    Join Date
    Mar 2010
    Location
    Austin, TX
    My Bikes
    Posts
    182
    Nitto B260AA (same as the B259AA but post-recall).
  14. #14
    Join Date
    Nov 2009
    Location
    My Bikes
    Posts
    455
    Quote Originally Posted by Clif View Post
    Yeah I Know and I primarily will play left since the group that plays where I live only has a few lefties. But sometimes I want to switch mid game so I dont have to cirlce around quick...
    Can you explain that more, maybe im just tired and I will get it after I get some sleep....
    So It Goes.....
Posting Permissions
  • You may not post replies
  • You may not edit your posts
