Advertise on Bikeforums.net
Results 1 to 6 of 6
  1. #1
    Sucking Wheel at the back hodie21's Avatar
    Join Date
    Jul 2009
    Location
    Bristol, VA
    My Bikes
    Parlee Z5, Santa Cruz Tallboy
    Posts
    755
    How much travel do I need?
    I have been riding my Lynskey Pro29 with a Reba RL 100mm fork. It seems that I am constantly bottoming out my fork. (As in the rubberband on the fork tube is always at the top of the fork.
    Is this a sign that I need a longer travel fork?
    Parlee Z5
    Santa Cruz Tallboy
  2. #2
    Senior Member corvuscorvax's Avatar
    Join Date
    May 2011
    Posts
    473
    Quote Originally Posted by hodie21 View Post
    Using all your travel is not necessarily a bad thing, but if you're bottoming the fork out too frequently, you might solve the problem by increasing the air pressure (and therefore the spring rate) in the fork. Could be it's not set up right for your weight.
    My speculation was that it applies to some degree in cycling, and I used the previous proof as my reasoning, but I can't prove how exactly it applies to it and to what degree. That, I have admitted, is speculation based on reasoning, but not at this point provable.
  3. #3
    one less horse cryptid01's Avatar
    Join Date
    Aug 2003
    Location
    East Jesus NY
    My Bikes
    are better than yours
    Posts
    5,590
    You should be bottoming your fork occasionally. If you're bottoming out hard or all the time, that's an indication you would be better suited with a stiffer spring.
  4. #4
    . ed's Avatar
    Join Date
    Oct 2005
    Location
    The Summit of Lee
    My Bikes
    2010 Jamis Parker, 2005 Jamis Komodo, 1998 Jamis Komodo, 198? Raleigh Pointe, 1978 Schwinn Super Le Tour 12.2
    Posts
    10,879
    +1
  5. #5
    Join Date
    Aug 2009
    Location
    Madison, WI
    Posts
    2,152
    ^ What he said and he "+1".
    90 Miyata 914 with full Dura-Ace
    74 Ellis-Briggs, full butted 531
    80s Cierra Professional 5000, Tange Champion 2 and Shimano 600
    2011 New Belgium Cruiser
    Fetish Cycles "Discipline" built up with DJ2 fork and Shimano XTR, LX, Avid BB7.
    Quote Originally Posted by scyclops View Post
    Oh yeah, sure, what if everyone thought that way? Then internet forums would merely be places where rational people exchange useful information and ideas - instead of the chaotic, emotionally-charged circuses that they are.
  6. #6
    Senior Member Thor29's Avatar
    Join Date
    Aug 2005
    Posts
    757
    If I went mountain biking and didn't bottom out the fork, I'd think something was wrong. I use all the travel regardless of how much there is - if the bike has more suspension, I go faster and hit things harder. That's what it's there for.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
