Advertise on Bikeforums.net
Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 55
  1. #26
    SuperGimp TrojanHorse's Avatar
    Join Date
    Mar 2010
    Location
    Whittier, CA
    Posts
    5,004
    I hear you. I just missed out on a nice SRAM crank today on fleabay. Dangit! They're really cheap right now but slightly less cheap than I am. Ha ha.
  2. #27
    Senior Member volosong's Avatar
    Join Date
    Apr 2011
    Location
    Antelope Valley, SoCal
    Posts
    1,747
    Quote Originally Posted by jmX View Post
    I use a 50-34 up front, 11-28 out back. Anything over 10% grade is still a chore...
    I'm finding this Spring that a 50-34 / 12-28 is working pretty well on the hills I ride. It's good for up to a short/middle length 10-11% grades. I've pretty much retired my triple bike and will only use it when I know that I'll be doing more than that. (I'm 60 and it would serve me well to lose about 30 pounds. I'm also "pretty slow" when climbing, the proof is on Strava.)
    Deut 6:5
    "Ha ha! You fool! You fell victim to one of the classic blunders - The most famous of which is 'never get involved in a land war in Asia'".
    - Vizzini during his "battle of wits" with the Man in Black
  3. #28
    Join Date
    Aug 2011
    Location
    Fullerton
    Posts
    226
    Quote Originally Posted by TrojanHorse View Post
    Ha ha - that's funny. I may go with an Ultrega 11/28 since it costs less than half of the Dura Ace and yet weighs about 40 gr more. Given my current weight, I doubt the few grams saved will help too much going up the mountain. But then again...
    _______
  4. #29
    got the climbing bug jsigone's Avatar
    Join Date
    Jan 2005
    Location
    Escondido>>>>San Diego, CA
    Posts
    5,406
    used to run 53/39 and 12-25, but switched over to compacts 50/34 and 11/23. Great for group rides and feels about the same going up palomar or GMR. BTW i'm about 210lbs if it matters...
    ...mad as a box of frogs
  5. #30
    [IMG]http://i4.photobucke jeepseahawk's Avatar
    Join Date
    Apr 2011
    Location
    san bernardino
    Posts
    591
    I have chicken legs, run 50/34 12-32 up the hills. Getting better though, only drop down to 28 on rear lately, even up a 10 % grade.
  6. #31
    shut up and ride
    Join Date
    Nov 2005
    Location
    noho
    Posts
    1,908
    Quote Originally Posted by jimxyz View Post
    I would do a 32 in back but I'm told it wouldn't work with my Dura Ace set up (?). The 53 was great for hauling ass on a decline, but I haven't missed it.
    i think you can swap a longer cage from another derailleur, not sure which one, xtr or ultegra long cage. also you can typically go more than shimano specs as the limit. adjusting the 'b' screw can get you a few more teeth range in the back. it's the one that sets the angle that the derailleur hangs at
    i would borrow a few parts and see if you can make it work. try a 9 speed 11-32 mtn cassette (if you've got one lying around)on a road wheel with your bike on a stand and grab the cable with your hand to shift and see if the derailleur has the range to reach the big cogs. you've got to experiment to see if it works, shimano's (and any other manufacturer) recommendations are always going to be on the conservative side, you won't now til you try...
  7. #32
    Join Date
    Aug 2006
    Location
    Valley Glen Ca.
    Posts
    1,134
    30 some post and not one mention of gear inches. That is the true gauge as to what gear ratio you are in,Goggle it.
  8. #33
    Join Date
    Mar 2010
    Location
    Whittier, CA
    Posts
    5,004
    Quote Originally Posted by vertical bob View Post
    You obviously missed the original post.
    Just wondering what people use for their drive train. I currently have a 53/39 and 12/26 which requires a fair amount of pedal pressure to get up a big hill.
    For some of the hillier centuries around here, do folks use compact cranks or is this just a matter of needing to HTFU?
    My current line of thinking is that a 50/34 and 11/28 (I think a normal SRAM RD will accommodate 28 but not 32) will improve my success rate with hills. That nets me a low gear of 31.9 inches instead of my current 39.5 inches.
    Thoughts?
    Honestly though, I know what 39/26 feels like, I have no idea what 32 gear inches feels like.
  9. #34
    Join Date
    Nov 2003
    Location
    Conejo Valley, CA
    Posts
    2,216
    My triple is a 30-42-52 paired with a 12-26 rear. The gives me about 31 gear inches for climbing. Living in the Conejo, I ride the SM's nearly every weekend and honestly, I wouldn't mind having a 27 in the cassette! If I replace my almost 10 year old bike in the next year, I think I'll opt for the triple again, rather than deal with a compact and the larger gear jumps. Okay, there is a little weight penalty....but my knees don't care!
    [insert clever quote here]
  10. #35
    Join Date
    Aug 2011
    Location
    Fullerton
    Posts
    226
    Thanks zzzzwillzzzz, I'll look into it. I may also google the info bob mentioned because, although i hate to admit it, I have no idea what gear inches factor means... I just know that I'd like a little, or a lot more leverage when trying to climb up the mountain. I'm in for BA this year, but I am getting real nervous.
    _______
  11. #36
    Senior Member triplebutted's Avatar
    Join Date
    Jun 2008
    Location
    SoCal
    Posts
    1,866
    A 39/28 will get you most places in Socal. If you are thinking Orange County. But yah, as most people said, Mulholland, Mt. Laguna, Big Bear, Baldy, you'll need a 34/28 at the min. Depends how strong you are. And a 50/11 ain't too shabby either for the flats. Its like 119 inch gear which is bigger than a 53/12. I think once you go lower than a 28 in the rear, you may have to change the derailleur, really depends on what you got there. I'll just grind it out on a 34/28 instead of buying a medium cage rear derailleur.
    197? Mercier
    197? Gios Torino
    1984 Centurion Comp TA
    1984 Lotus Legend Compe (year corrected by Snydermann, thanks!!)
    1996 Lemond Zurich
    2001 Trek 8000 MTB
    2006 Fuji Tourer
    2009 Voodoo Rada
  12. #37
    Join Date
    Aug 2006
    Location
    Valley Glen Ca.
    Posts
    1,134
    Your right I did miss your mention of gear inches, sorry. To answer your other question, 32 gear inches can feel great when things get steep for many mile like Horseshoe Meadows or a number of other climbs in the Sierra's, Baldy too.
  13. #38
    Join Date
    Mar 2010
    Location
    Whittier, CA
    Posts
    5,004
    Well, that's what I'm looking for. Now if only evilbay would cooperate. People seem to be dumping SRAM Red compact cranks right now - they're cheaper than Force.
  14. #39
    Senior Member JSMaxwell's Avatar
    Join Date
    Jun 2011
    Location
    Southern California
    Posts
    72
    I don't think I've ever wished I had a 53 up front, and the only time I use the 34 chainring is on climbs so I don't know why I'd ever want to make that harder with a 39 (unless I somehow gained 200w of power).
    +1
  15. #40
    Join Date
    Aug 2011
    Location
    Fullerton
    Posts
    226
    50/34 x 11/28 installed and ready for BA, hoping I don't need one more gear as that is it with my current set up!
    _______
  16. #41
    Join Date
    Mar 2010
    Location
    Whittier, CA
    Posts
    5,004
    interesting. I landed a crank with two sets of chainrings, so 52-36 is on there right now and that's pretty swell. I ordered a 11-28 for the back and it just arrived last night, so I think I'll stick it on and go find a hill.
  17. #42
    Spit out the back tinrobot's Avatar
    Join Date
    Aug 2005
    Location
    Silverlake, CA
    Posts
    1,004
    50/34 with an 11-34 on the back. I plan to spin my way through the tough parts.
  18. #43
    #5639 robertkat's Avatar
    Join Date
    Mar 2007
    Location
    San Diego, CA
    Posts
    1,202
    38/26 low gear gets me up everything I've come across so far, although climbing out of Barrett Junction heading east on Hwy 94 says a triple isn't such a bad idea. My randonneuse has a 46-34 with a 12-32 cassette. Perfect gearing for the long haul, plus a few on the low end "just in case".
  19. #44
    Certifiably crazy! Carloswithac's Avatar
    Join Date
    Jun 2011
    Location
    San Diego, CA
    Posts
    373
    34/28 gets me up almost anything in San Diego. I'm doing the Alpine Challenge this Saturday, so hopefully I won't eat my words.
    '11 Felt Z5
    '12 Felt Nine Race
  20. #45
    Join Date
    Nov 2010
    Posts
    103
    One day I'll need something smaller than my 39-28, but I'm hoping that day is far, far away.
  21. #46
    Join Date
    Mar 2012
    Location
    SoCal
    Posts
    265
    I thought that as well. I have a triple 52-39-30 and prior to Mulholland I was using a 12-25 in back. I swapped to the 11-28 for Mulholland. Now I love having that 52-11 combo. Coming down Highway 38 from Angelus Oaks last weekend, I didn't spin that gear out until I was close to 40mph. I think it actually helped my recovery to be able to spin my legs with some resistance on the downhills.
    I was thinking of switching to a compact crank so that I could upgrade to Ultegra Di2, but now I'm thinking that giving up that 52-11 would be a bad thing.
  22. #47
    shut up and ride
    Join Date
    Nov 2005
    Location
    noho
    Posts
    1,908
    Quote Originally Posted by cdp8 View Post
    go with a 52/36 compact as opposed to the more standard 50/34, almost as low as a 34 and you'll keep the 52 big ring
  23. #48
    Join Date
    Mar 2012
    Location
    SoCal
    Posts
    265
    Quote Originally Posted by zzzwillzzz View Post
    But then my low goes from a 30x28 to 36x28. Besides, Di2 is limited to 16 tooth difference in front with a max 28 tooth in back according to the Di2 shop manual. More training can probably allow me to use a 34x28, but not the 36. No way I finish Mulholland this year without that 30x28. If the Ultegra Di2 system could handle an 11/28 in back with a 52/32 in front I'd be all over it. If they could just push the FD to 18t, I'd probably make the jump.
    90% of my riding is done in hills and mountains, so I'll just stick with what I have until they make a triple compatible Di2 system.
  24. #49
    Join Date
    Aug 2011
    Location
    Southern California
    Posts
    323
    I wouldn't hold my breath for a triple compatible Di2. Chances are equally good that Shimano will go the other way and start dropping triples from their mechanical groups too. They are already paving the way for that, by extending ranges of their RDs to 30T.
    At best, we might see electronic versions of their mountain bike drivetrains some time soon, and those may or may not support triples. (And even then, the first groupset will be the electronic XTR, and it will cost way more than Ultegra Di2.)
    Have you seen this? http://velonews.competitor.com/2011/...ossible_199407
  25. #50
    Join Date
    Mar 2012
    Location
    SoCal
    Posts
    265
    Quote Originally Posted by eugenek View Post
    That was very interesting...
    (old)52x11=124gi
    (new)50x11=119gi I think I could live with that because it's still better than 52x12(114gi).
    (old)30x28=25gi
    (new)34x32=28gi I'm not sure I would notice that difference.
    Hmmm... might be getting some new components this fall.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
