Advertise on Bikeforums.net
Results 1 to 7 of 7
  1. #1
    Senior Member nrowensby's Avatar
    Join Date
    Dec 2011
    Location
    Columbia, SC
    Posts
    233
    Pulling kids w/Specialized Allez?
    Debating on whether or not my Allez will be able to pull a trailer with my two children? Any issues pulling a trailer with a road bike?
  2. #2
    Is a real super guy. Henry III's Avatar
    Join Date
    Aug 2010
    Location
    Medford, Or
    Posts
    1,763
    It's made out of aluminum...not glass. It's just depends on what the seatpost is made out of if it mounts that way.
  3. #3
    Join Date
    Apr 2012
    Posts
    16
    It's doable, I've done it once or twice while the mtb was out of commission. Just watch out for sharp corners turns. I would say if you plan to do this a lot just buy a beater off CL, it will be much more comfortable.
  4. #4
    Join Date
    Aug 2010
    Location
    Medford, Or
    Posts
    1,763
    Pulling kids with a road bike make it handle really twitchy. I'd suggesting getting some wider bars, turn it into a flat bar road bike or just get a mtb. I used to pull my son on my Salsa Vaya which used had 42cm bars instead of the normal 40cm I usually used and it still made the bike handle really squirrely.
  5. #5
    SuperGimp TrojanHorse's Avatar
    Join Date
    Mar 2010
    Location
    Whittier, CA
    Posts
    5,004
    I had a trailer for my kids and towed it behind my old steel bianchi. I hated it. The trailer clamped to the chain stay on the left side, and there was a pretty stiff spring that gave the trailer some "give" when I pedaled. Well, it felt like I was being pushed at all the wrong times and pulled when I was trying to push, but not consistent in any way that I could become accustomed to. It was awful. And heavy. It's hilly where I live so the trailer hasn't been used in years. I'd rather floss my teeth with barbed wire than use that damn trailer.
    If you can test one out. There are probably much better models that are pleasant to use.
  6. #6
    Carpe Velo Yo Spiff's Avatar
    Join Date
    Dec 2011
    Location
    Fort Worth, Texas
    Posts
    2,194
    I used to pull my kids in a Burley trailer on an older model steel Allez. Never had a problem. I finally decided they were getting too heavy for it when they turned 15.
    2000 Bianchi Veloce, '88 Schwinn Prologue, '88 Trek 900, '92 Trek T100, 2000 Rans Tailwind
  7. #7
    Join Date
    Mar 2010
    Location
    Whittier, CA
    Posts
    5,004
    Quote Originally Posted by Yo Spiff View Post
    You just need to HTFU!
    I think my trailer was a Bell so get a Burley instead.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
